How Do You Calculate Static Pressure Drop in a Laminar Flow Channel?
The discussion focuses on calculating the static pressure drop in a laminar flow channel, specifically under steady state and incompressible conditions. The key approach involves solving the Navier-Stokes equations, with an emphasis on using the Darcy friction factor and the Moody Diagram for analysis. The user has already determined the inlet velocity based on the Reynolds number but seeks guidance on the pressure drop calculation across a circular channel. Analytical solutions for simplified cases, such as flow between parallel plates, are also suggested for obtaining lower bounds on pressure drop.
  • Understanding of Navier-Stokes equations
  • Familiarity with Darcy friction factor
  • Knowledge of Moody Diagram
  • Concept of hydraulic diameter
  • Study the application of the Navier-Stokes equations in laminar flow scenarios
  • Learn how to utilize the Moody Diagram for friction factor calculations
  • Research methods for calculating hydraulic diameter in various channel geometries
  • Explore numerical methods for solving fluid dynamics problems
Engineers, fluid dynamics researchers, and students studying laminar flow in channels will benefit from this discussion, particularly those focused on pressure drop calculations in fluid systems.
Darcy30
Hallo. Since I'm new in this field, I hope someone can help me.
I have a laminar, steady state, incompressible flow in a channel (a fully developed).
Geometry of the channel is on the photo.
How should I calculate the drop of static pressure across the channel?
Since I have Re, I did calculate a inlet velocity, but now I'm stuck.
Thanks
To do this, you need to solve the Naiver Stokes equations, probably numerically. To get a lower bound to the pressure drop, you can at least solve analytically for the case where you remove the constriction and have rectilinear flow between parallel plates.
Hi Darcy30,
Was it intentional that your username would hint at the solution?
I understand the problem as follows:
  • Assume laminar, steady state, constant density (incompressible), fully developed flow.
  • Channel Geometry and Fluid Properties are known (I will assume the channel is circular)
  • The inlet velocity is known
Goal:
  • Find the pressure drop across a channel.
Solution Hint:
Darcy Friction Factor, Moody Diagram
Solution:
The pressure drop down a pipe is related to the friction factor.
For Laminar flow,
$$ f_D = \frac{64}{Re} $$
If not, then you will need to assume smooth walls or know the surface roughness.
The pressure drop is related to the following.
$$ dP = f_D * \frac{\rho*V^2*L}{2*D} $$
Break the problem into 3 sections. Inlet straight pipe, the circular restriction, and the outlet straight pipe. The inlet and outlet is straight forward. You will add up the dP for each section to find your answer.
The tricky part of this problem is that you need to integrate the friction factor (hence pressure drop) over the circular restriction. You need a formula for the relationship of Pipe Diameter, D, to length across the channel, x. Something like this:
$$ Dtube = 2 * R - R*sin(acos(R/x)) $$
Additionally, the velocity changes based on cross-sectional area. Use the conservation of mass to find that
$$ mdot = \rho*Area*Velocity $$
There is symmetry, so we only need to consider a 1/4 circle and multiply the friction factor by 2. Integrate from x = 0 to R. Or solve it numerically in a spreadsheet program with small steps of x.
PS: If the channel is indeed non-circular, then use the hydraulic diameter Dh in place of D.
$$ Dh = \frac {4*Area}{Perimeter} $$
References:
[1] Moody Diagram https://en.wikipedia.org/wiki/Moody_chart?msclkid=7b62d23aaee911ec823e165de974644a
[2] Hydraulic Diameter https://en.wikipedia.org/wiki/Hydraulic_diameter?msclkid=0899a52baef711ec890e442c37cca7b6
What is the exact statement of the problem?
  • · Replies 0 ·
