Calculating Lid Pressure at Different Altitudes
  • Thread starter Thread starter warrior2014
    Pressure
This discussion focuses on calculating the force required to lift a lid from a box under different atmospheric pressures. The box dimensions are 10cm long, 20cm wide, and 8cm tall, leading to a calculated area of 0.02m². At sea level, with an internal pressure of 72000 Pa, the force required to lift the lid is 586.5 N. In Denver, where the atmospheric pressure is 67.5 kPa, the calculations reveal that the internal pressure is higher than the external pressure, indicating that the lid would pop off without any additional force required.
  • Understanding of pressure calculations using the formula P=F/A
  • Knowledge of basic physics concepts related to force and area
  • Familiarity with atmospheric pressure variations at different altitudes
  • Ability to interpret and analyze pressure differentials in closed systems
  • Study the effects of atmospheric pressure on fluid dynamics
  • Learn about pressure differentials in vacuum systems
  • Explore practical applications of pressure calculations in engineering
  • Investigate the behavior of gases under varying pressure conditions
Students in physics or engineering courses, educators teaching pressure concepts, and anyone interested in understanding the principles of force and pressure in real-world applications.
warrior2014
Pressure of a lid!
A lid is put on a box that is 10cm long, 20cm wide and 8cm tall and the box is then evacuated until its inner pressure is 72000 Pa.
1.How much force is required to lift the lid at sea level?
2. How much force is required to lift the lid in Denver on a day when the atmospheric pressure is 67.5 kPa (2/3 the value at sea level)?
P=F/A
A=L x W
I got #1 where I did the following:
A= L x W= 0.1 x 0.2= 0.02m^2
P=F/A
(101325 - 72000)= F/ 0.02
586.5 N= F
I attempted to do #2 as shown below and got both methods wrong:
so first I did: P=F/A
(67500- 72000)= F/0.02
-90N= F (wrong answer)
so then I did: P=F/A
67500= F/0.02
1350N= F (wrong answer again)
I am unsure how to answer this question, so any help is appreciated! It's online homework so there's no given answer either. thanks!
Your first attempt at #2 is along the right lines, you just didn't analyze the result closely enough. Suppose the lid were secured in place with some kind of fastener. If the pressure inside is higher than outside, what would happen when you undid the restraints? If there were no restraints in place when the outside pressure dropped below the inside pressure, what would happen to the excess pressure in the box?
so if you undid the restraints then the pressure inside would decrease? I'm still confused on how to solve the problem.
Look at the data: where is the pressure higher, inside or outside? What happens to a lid if the pressure inside the container is higher than the outside pressure? Do you have no kitchen experience with boiling milk in a covered pot? :wink:
ehild
no kitchen experience at all! but if the pressure inside the container is higher than the outside, wouldn't the lid pop off? I still don't get how this will help me get the question...
Think it through. If the lid pops off by itself, how much force is required to remove the lid?
Oh okay I get it. thank-you for all of your help :)!
  • · Replies 23 ·
