Pressure reported from a water line, gauge or absolute?
5 replies · 2K views
EastWindBreaks
I thought the pressure in a water line is in gauge pressure, but the solution suggests that 1630 kPa is in absolute pressure, do we always assume absolute pressure unless otherwise specified?
How does the solution imply gauge or absolute? It's simply asking you to change units isn't it?
I thought psia means psi as in absolute pressure? if it is, then I would need to add 1630 kpa( if its gauge pressure) to atmospheric pressure, which would be 246.42 psi+14.7 psi, but the correct answer is just simply 246.42 psia.
A pressure gauge typically gives the pressure in a water line as gauge pressure. So, you are absolutely right in your criticism of question. I would have given the same answer you gave.
haha, I am not sure if i was criticizing the question or just confused, thank you for clarification!
I didn't notice the "psia" next to the answer box. The question itself just says psi.
