Principal Virtual Work Theories - Cylindrical Pipe Application
The discussion centers on the application of the Principal Virtual Work theory, specifically in relation to cylindrical pipe behavior under conditions of collapse and buckling. Participants highlight the relevance of this theory for analyzing ovalisation, external pressure, and hoop strain in pipeline applications. Additionally, API Bulletin 5C3 is referenced as a key resource for understanding pipe collapse resistance, while Euler Buckling is noted as the standard method for buckling analysis. The conversation emphasizes the complexity of analyzing multi-layer pipes with varying material properties.
  • Understanding of Principal Virtual Work theory
  • Familiarity with API Bulletin 5C3 guidelines
  • Knowledge of Euler Buckling principles
  • Experience with material properties in multi-layer pipe analysis
  • Research the application of Principal Virtual Work in engineering contexts
  • Study API Bulletin 5C3 for pipe collapse resistance methodologies
  • Learn about Euler Buckling and its calculations for cylindrical structures
  • Investigate the behavior of multi-layer pipes with differing elastic moduli and yield strengths
Engineers, particularly those specializing in pipeline design and analysis, as well as researchers focused on structural integrity and material behavior in multi-layer systems.
akmalhisham75
Dear All,
I did post this issues in the physics forum, however there is somebody ask me to post it in the engineering forum. With this I re-post it here.
Does anyone here familiar with a theory called Principal Virtual Work (Equilibrium theory) ?
I read somewhere that with this theory, i could relate(for pipeline application - collapse & buckling) the components for ovalisation, external pressure and hoop strain.
Appreciate if somebody could guide me on this matter.
Thank you
Regards
-Akmal-
akmalhisham75 said:
Dear All,
Thank you
Regards
-Akmal-
Principle of Virtual Work: http://www.public.iastate.edu/~e_m.274h/deformable body virtual work.pdf
I've never used this principle for determining collapse or bucking of pipe. API Bulletin 5C3 gives lots of guidance on how to determine pipe collapse resistance.
Buckling is normally determined based on Euler Buckling.
CS
CS,
yes agreed in general...and it works well for a single layer pipe...however for a multi-layer pipe I'm trying to analyse the behaviour of each individual layer (which have different E and Yield) properties. So each individual layer has its own allowable strain value...so this where i want to have the relation between the properties I've mentioned earlier.
thanx anyway.
  • · Replies 17 ·
