Probability - Girl visiting local pubs
In summary: The probability of finding her in the last bar is ##P(N) = \frac{M}{24}-\frac{N-1}{N}\frac{M}{24} = \frac{1}{N}\frac{M}{24}##.
Robin04
260
A girl spends M hours daily (out of 24) in local pubs. The town has N pubs but she doesn't have a preference so she can be found in any of them with an equal chance. We start looking for her. After checking N-1 pubs we still haven't found her. What's the probability that she's in the last one?
What I can't understand from the problem is that whether she stays at a certain pub for M hours, or she visits more pubs and goes home after M hours.
If it's the first case, then I think the answer is ##\frac{M}{24}\frac{1}{N}##.
This problem is posted as a harder one so I suppose it has to be the second case but I don't see where does this make the answer more complicated.
Robin04 said:
Problem Statement: A girl spends M hours daily (out of 24) in local pubs. The town has N pubs but she doesn't have a preference so she can be found in any of them with an equal chance. We start looking for her. After checking N-1 pubs we still haven't found her. What's the probability that she's in the last one?
Relevant Equations: -
I read this as saying she spends a total of M hours in all the pubs, not M hours in any single pub.
Likes Robin04
So she spends ##\frac{M}{N}## hours in each meaning the answer is ##\frac{M}{24*N}\frac{1}{N}##?
I haven't worked the problem, but it seems to me that you need to use a conditional probability; namely, the probability that she's in the last pub, given that she is not in any of the other N-1 pubs.
Likes Robin04
It doesn't say how long the search is taking either. But I think at least you have to consider the possibility that the M hours may have already expired when you're searching, and she's already gone home. Or that she might not have gone out yet.
Because if the assumption is that she is guaranteed to still be in one of the N pubs and she isn't in the first N - 1, then the conditional probability of being in the last one is obviously 1.
So the amount of time by which your search is overlapping her pub-hopping is a random variable.
Likes Robin04
The way I interpreted the text is that in this model the search doesn't take time, so basically we can say that momentarily the girl is in neither of the N-1 pubs, so she must be in the last one or she's not in any of the pubs. Or it's more complicated?
Well the problem could be stated in a more clear way apparently.
But I assume that we can interpret the statement "A girl spends M hours daily (out of 24) in local pubs" like this:
(at any moment) the probability that we find the girl in any of the local pubs is ##\frac{M}{24}##.
Let's define event ##i## as the girl is sitting in the ##i##-th bar, where ##i = 1, 2, ..., N##. Thus
$$P(1 \cup 2 \cup ... \cup N) = \frac{M}{24}$$
From here, it cannot be any easier to find the result (just realizing that the events are disjoint) :wink:
Likes Robin04
So given that the events are disjoint: ##P(1 \cup ... \cup N) = P(1) + ... + P(N)##, and also ##P(1)=...=P(N)##, because
We're looking for ##P(N) = \frac{M}{24}-\frac{N-1}{N}\frac{M}{24} = \frac{M}{24}(1-\frac{N-1}{N}) = \frac{1}{N}\frac{M}{24}##
Is it really this simple? This exercise is worth a lot a points in my assignement.
Robin04 said:
So given that the events are disjoint: P(1∪...∪N)=P(1)+...+P(N)
Correct.
Robin04 said:
and also P(1)=...=P(N),
That is generally true, but you have an additional info to work with: you already checked bars ##i = 1,2,...N-1## and she wasn't there... So what is the probability of finding her in the last bar, when you know that ##P(1 \cup 2 \cup ... \cup N) = \frac{M}{24}## must hold?
Likes Robin04
lomidrevo said:
Correct.That is generally true, but you have an additional info to work with: you already checked bars ##i = 1,2,...N-1## and she wasn't there... So what is the probability of finding her in the last bar, when you know that ##P(1 \cup 2 \cup ... \cup N) = \frac{M}{24}## must hold?
Oh, so ##P(1)=P(2)=...=P(N-1)=0## as it's known that she's not there and then ##P(N)=\frac{M}{24}##?
Likes lomidrevo
Exactly! It may look surprising at the first glance that the result doesn't depend on ##N##, but when you think about more deeply, it make sense.
Likes Robin04
No, that's not correct. Let's put in some numbers and look at the frequencies. Assume that ##M = 4## and ##N = 4##, say.
You decide to look for her at a certain time. There is a probablity of ##1/6## that she is in a pub somewhere and ##5/6## that she is at home.
As she is equally likely to be in each pub, there is a probablity of ##1/24## that she is in each pub.
Now, run the experiment ##24## times. We can ignore the ##3## cases where she is found in one of the first three pubs and concentrate on the cases where she is not.
There are ##20## times that she will not be found in any pub and ##1## time that she will be found in the last pub. So, in ##21/24## cases she will not be in any of the first three pubs. And, in only one of these cases will she be found in the last pub.
The conditional probablity of finding her in the last pub, given she is not in one of the first three is, therefore, ##1/21##.
I know that this gives the answer to the OP, but you have totally led him astray, so we needed to get this post back onto the right lines.
Likes Robin04 and lomidrevo
No, you've been completely led astray by @lomidrevo.
You must use the techniques of calculating conditional probabilities. I prefer the frequency/probability tree approach described above.
Likes Robin04
Oh gosh, you are probably right... your counting looks very convincingly. Due to my oversimplified strategy I didn't exclude the cases when she is found in some of the first N-1 bars.
I have one supplementary question:
In your approach (during all 24 trials), are you visiting the bars always in the same order? I.e. you have (implicitly) labeled them ##1, 2, 3, 4## and the bar ##4## is always the last one to check. Correct?
Does it make any difference when during each trial you visit the bars in a random order?
My guess would be that it does not matter, as the trials are independent, but I am not sure.
Likes Robin04
If we imagine that the girl is at home ##20## times and in each of the pubs ##1## time out of a typical set of 24 trials.
Before we do anything the probability she is in pub 4 is ##1/24##. If we look in pub 1 and she is not there, then that excludes that case, leaving all remaining 23 cases unchanged. Now, there is a ##1/23## probability she is in each of the remaining pubs 2-4. If we then look in a second pub and she is not there, that rules out that case. Then, there would be a probability of ##1/22## that she is in each of the remaining pubs 3-4. And, finally, if we look in pub 3 and she is not there, then the probability she is in pub 4 is ##1/21##.
Note that the probability of all the other options increases each time we eliminate one option.
A second way to look at it is that before we do anything there is a ##1/6## chance that she is in a pub. But, each time we check a pub and find she is not there the probability she is in a pub reduces. After looking in the first pub, the probability has reduced to ##3/23##, then ##2/22## and eventually ##1/21##. In other words, after we have looked in three pubs and not found her there is significantly less chance that she is in a pub somewhere.
The way we label the pubs does not matter. It only depends on being a pub not yet looked in.
@Robin04 sorry for misleading you! I should have think about the problem a bit longer before I came out with my naive solution.
@PeroK, thanks a lot for you detailed explanation!
Lesson for me: Don't refuse the conditional probability just because the events seems to be disjoint at first glance. (Events "girl not sitting in bar 1, 2 or 3" and "girl sitting in bar 4" are definitively not disjoint!)
Likes Robin04
Okay, I'm a bit confused now but I'll try. So we're looking for P(she's in the Nth pub| she's not in any other pub) = P(she's in the Nth pub and she's not in any other pub)/P(she's not in any other pub)
P(she's in the Nth pub and she's not in any other pub) = ##\frac{M}{24}\frac{1}{N}##
P(she's not in any other pub) = ##1-\frac{M}{24} + \frac{M}{24}\frac{1}{N} ##
Maybe?
Maybe?
Yes, those look correct. You could also look up Bayes's Theorem.
Likes Robin04
Thank you very much! So the answer is ##\frac{\frac{M}{24N}}{1+\frac{M}{24}(\frac{1}{N}-1)}##
I think you've mixed up a minus sign.
If you plug in ##M = N = 4## you should get ##1/21##.
Likes Robin04
I don't get 1/21 with any change of sign. I must have made some other mistake.
Sorry, I misread it. Try plugging in ##N = M = 4## to what you have. To be honest, you should have done that in any case!
Oh wait, I mistyped it in my calculator, it's 1/21 for N=M=4. Thank you very much! :)
You can go and have a drink at the local pub now!
  • Haha
Likes Manasan3010, StoneTemplePython and Robin04
Haha, at least now there's a formula that can help in finding me! :biggrin:
Likes PeroK
1. What is the likelihood of a girl visiting local pubs?
The likelihood of a girl visiting local pubs depends on several factors, such as her age, interests, and social circle. It is difficult to determine an exact probability without more specific information.
2. How can we calculate the probability of a girl visiting local pubs?
To calculate the probability of a girl visiting local pubs, we would need to collect data on the number of girls in the area, the number of local pubs, and the frequency at which girls visit those pubs. This data can then be used to calculate the probability using statistical methods.
3. Is the probability of a girl visiting local pubs different from that of a boy?
It is possible that the probability of a girl visiting local pubs may differ from that of a boy, as it may depend on societal norms and gender roles. However, it is also possible that the probabilities may be similar, as individuals of any gender may have a variety of interests and preferences.
4. How do other factors, such as location and time, affect the probability of a girl visiting local pubs?
Other factors, such as location and time, can greatly influence the probability of a girl visiting local pubs. For example, a girl living in a busy city may be more likely to visit local pubs compared to a girl living in a small town. Similarly, the time of day or day of the week may also impact the probability, as certain pubs may be more popular during certain times.
5. Can we accurately predict the probability of a girl visiting local pubs?
While we can use statistical methods to estimate the probability of a girl visiting local pubs, it is difficult to accurately predict the exact probability. This is because there are many variables and factors that can influence an individual's decision to visit a pub, making it challenging to account for all of them in a prediction.
  • Precalculus Mathematics Homework Help
  • General Math
  • Set Theory, Logic, Probability, Statistics
