Probability in a dice game
  • Level: High School
  • Thread starter Thread starter Norway
    Dice Game Probability
41 replies · 8K views
Although the idea of using the expected number works, that was only necessary because I thought the rules were more complicated. As it stands, here is a way to do it that could be programmed:
For ##n = 0## to ##7## (##n## is the number of 1's).
Calculate ##p(n)## (it's a binomial distribution - I'll not put too many details in this thread).
The criterion for success is to have at least one number occurring ##7-n## times, from ##14 - n## dice. We need all the patterns that meet this. For example, for ##n = 0##, the successful patterns are:
7, 7, 0, 0, 0
7, 6, 1, 0, 0
7, 5, 2, 0, 0
7, 5, 1, 1, 0
7, 4, 3, 0, 0
7, 4, 2, 1, 0
7, 4, 1, 1, 1
7, 3, 3, 1, 0
7, 3, 2, 2, 0
7, 3, 2, 1, 1
7, 2, 2, 2, 1
You could write a subroutine that would do this for any number. In this case, input ##14, 7, 5## and it would generate all patterns of ##5## numbers that have at least one ##7## and sum to ##14##.
Or, do a subroutine to do them all and then select any with a ##7##.
That's programming challenge #1!
Next, you need to calculate the probability of each of these patterns. In this case with five random possibilities - as we are assuming we are given the number of 1's. For example, for 7, 6, 1, 0, 0, you need the probability of getting 7 of one number, six of another and 1 of a third number. The way I would calculate this is:
60 sub-patterns (where a sub-pattern would be 7 x 2, 6 x 3, 1 x 4) - i.e. 60 is just 5 x 4 x 3.
For each of these the number of possibilities is ##\binom{14} {7} \binom {7} {6}##.
I.e. there are ##60 \times \binom{14} {7} \binom {7} {6}##. ways of getting the pattern 7, 6, 1, 0, 0.
You can add them all up and divide by ##5^{14}##, which is in general ##5^{14-n}##. We could call this ##q(n)## - the probability of success given ##n## 1's.
That's programming challenge #2!
Once you've done this, the total probability is just the sum of ##p(n)q(n)##.
Obviously an alternative is to do something similar for all 6 dice and work the addition of the 1's into the logic.
I can't see any short-cuts.
I still wonder whether I understand the rule rightly so I rewrite the problem.*********************************************************
Is the number of cases we want is written as
[tex]\sum_{n=7}^{14} \ _{14}C_n*N(n)[/tex]
where N(n) is the number of cases in game of n dices of five faces,
satisfying 7-of-a-kind or (n-7)-of-a-kind with no redundant count ?
Here 14-n is number of Jokers and ##\ _{14}C_{14-n}=\ _{14}C_n## is number of their appearance.
Some N(n) is easy to get,
[tex]N(7)=5[/tex]
[tex]N(8)=5*\ _8C_1 * 4^7[/tex]
[tex]N(14)=\ _{14}C_7(5*(4^7 - 4)+\ _5C_2)[/tex] if not mistaken.
I should appreciate it if you confirm/correct my understanding.
EDIT to post #32
Revision of N(8)
I found N(8) in #32 is wrong. The following is the revision.
Say five face of dice is ABCDE. We think 1-of-a-kind cases by its numbers.
FOUR 1-of-a-kind
Type of occurrence is expressed as
ABCDEEEE or 1+1+1+1+4
[tex]\frac{8!}{1!1!1!1!4!}*5[/tex]
coefficient 5 : choice of ETHREE 1-of-a-kind
ABCDDDDD or 1+1+1+5
[tex]\frac{8!}{1!1!1!5!}*5*4[/tex]
coefficient 5*4 : choice of D,E
ABCDDEEE or 1+1+1+2+3
[tex]\frac{8!}{1!1!1!2!3!}*5*4[/tex]
coefficient 5*4 : choice of D,ETWO 1-of-a-kind
ABCCCCCC or 1+1+6
[tex]\frac{8!}{1!1!6!}*5*\ _4C_2[/tex]
coefficient ##5*\ _4C_2## : choice of C,(AB)
ABCCCCDD or 1+1+4+2
[tex]\frac{8!}{1!1!4!2!}*5*4*3[/tex]
coefficient 5*4*3 : choice of C,D,E
ABCCCDDD or 1+1+3+3
[tex]\frac{8!}{1!1!3!3!}*5*\ _4C_2[/tex]
coefficient ##5*\ _4C_2## : choice of E,(AB)
ABCCDDEE or 1+1+2+2+2
[tex]\frac{8!}{1!1!2!2!2!}*_5C_2[/tex]
coefficient ##\ _5C_2## : choice of (AB)
ONE 1-of-a-kind
ABBBBBBB or 1+7
[tex]\frac{8!}{1!7!}*5*4[/tex]
coefficient 5*4 : choice of A,B
7-of-a-kind count is included here. No new counting is necessary.
ABBBBBCC or 1+5+2
[tex]\frac{8!}{1!5!2!}*5*4*3[/tex]
coefficient 5*4*3 : choice of A,B,C
ABBBBCCC or 1+4+3
[tex]\frac{8!}{1!4!3!}*5*4*3[/tex]
ABBBCCDD or 1+3+2+2
[tex]\frac{8!}{1!3!2!}*5*4*3[/tex]
coefficient 5*4*3 : choice of A,B.ESum of these cases gives [tex]N(8)=3,118,240[/tex]
Similarly for N(9)
FOUR 2-of-a-kind
AABBCCDDE 2+2+2+2+1
[tex]\frac{9!}{2!2!2!2!1!}*5[/tex]
multiplied by choice of E.
THREE 2-of-a-kind
AABBCCDDD 2+2+2+3
[tex]\frac{9!}{2!2!2!3!}*5*4[/tex]
multiplied by choice of D,E.
TWO 2-of-a-kind
AABBCCCCC 2+2+5
[tex]\frac{9!}{2!2!5!}*5*\ _4C_2[/tex]
multiplied by choice of C,(AB).
AABBCCCCD 2+2+4+1
[tex]\frac{9!}{2!2!4!1!}*5*4[/tex]
multiplied by choice of C,D.
AABBCCCDE 2+2+3+1+1
[tex]\frac{9!}{2!2!3!1!1!}*5*\ _4C_2[/tex]
ONE 2-of-a-kind
AABBBBBBB 2+7 (*)
[tex]\frac{9!}{2!7!}*5*4[/tex]
multiplied by choice of A,B.
AABBBBBBC 2+6+1
[tex]\frac{9!}{2!6!1!}*5*4*3[/tex]
multiplied by choice of A,B,C.
AABBBBCCC 2+4+3
[tex]\frac{9!}{2!4!3!}*5*4*3[/tex]
AABBBBBCD 2+5+1+1
[tex]\frac{9!}{2!5!1!1!}*5*4*3[/tex]
multiplied by choice of A,B,E.
AABBBCCCD 2+3+3+1
[tex]\frac{9!}{2!3!3!1!}*5*4*3[/tex]
multiplied by choice of A,D,E.
AABBBBCDE 2+4+1+1+1
[tex]\frac{9!}{2!4!1!1!1!}*5*4[/tex]
7-of-a-kind
In addition to above (*)
AAAAAAABC 7+1+1
[tex]\frac{9!}{7!1!1!}*5*\ _4C_2[/tex]
multiplied by choice of A,(BC)
N(9) is given by summing up the above.
sysprog said:
@Norway: In my opinion, you exhibit a (not especially unusual) propensity for adding new conditions subsequently to the statement of the problem.
I agree with your observation. As you suggest, I am indeed interesting in getting things right. English is not my first language, and so I'm struggling to formulate and phrase my thoughts and intentions clearly. If I could, I would want the problem to be clearly and unambiguously stated in the first post. Sadly, as mentioned, many of the great questions asked, I hadn't even considered myself, so some elaboration had to be done subsequently. Hopefully, these "new" conditions did not turn the problem upside-down, but rather clear up some ambiguity. The one notable exception being that the jokers must be counted, which surprised even me. I was almost about to send a long post I had written about how the jokers should be optional, just as the game master called me and told me they are mandatory. I do apologize for all uncertainty, and the extra time and effort it has cost the contributors of this thread. I am very grateful for all participation here.
sysprog said:
Here I'd like to re-state what I see as your current version of the rules:
14 6-sided fair dice ##-##
exactly 7 dice matching wins [if 8 of the dice match, no win is possible] ##-##
1s:
may be any value other than 1 ##-##​
all must be the same value ##-##​
all must be used in any solution ##\cdots##​
[All 3 of those restrictions are significant departures from standard 'jokers wild' rules.]
Is that in your view an accurate and adequate summary of the rules?
Eight of the same kind doesn't immediately disqualify the throw, for instance if the throw includes: {1, 1, 1, 1, 2, 2, 2, 2, 3, 3, 3, 4, ...} then we have eight "2"s (which is not a success), but at the same time we have seven "3"s, which makes the throw successful.
Otherwise, yes, I do think that's accurate. Every time you count a value, you must also count all the "1"s as that value. For instance, counting the number of "2"s in a throw, you would have to also add the number of "1"s. @PeroK: Thank you for laying it out in such a clear and organized fashion! I manage to follow along, and I agree with everything you wrote. And a programming challenge it is indeed! It's a little unsatisfying that there are no easier solution, but at the same time it's nice to know that I wasn't a total buffoon when I was called up in the middle of the night by some friends playing a dice game, querying me for a probability calculation. Usually when they do that, I can answer on the fly, or at the very least within a minute or two, but this time I was completely stumped, and I spent hours and hours on this before I just decided to simulate it. At least I can know that I didn't really "fail" the way it felt like then. :oldtongue:
14∑n=7 14Cn∗N(n)∑n=714 14Cn∗N(n)​
\sum_{n=7}^{14} \ _{14}C_n*N(n) where N(n) is the number of cases in game of n dices of five faces,
I am sorry, but I'm not completely able to take in this statement. I'm not very good at maths, so I don't completely understand your formula either, but I can't seem to relate that to my problem. As I said, English is not my first language, so I have struggles both formulating myself and understanding others, which may be an explanation to why I still haven't been able to properly formulate the problem to you. It seems that both @FactChecker and @PeroK have understood the problem correctly, and they are way better at presenting than I am, so if you're still interested in calculating this further (I think @PeroK has a spot-on solution, and @FactChecker and myself have already simulated it), then I hope you will consider reading their posts. They explain it better than I could. Thank you so much for your participation and interest in my thread!
Evidently I didn't elaborate on the bracketed remark sufficiently. By my interpretation, in the case of exactly 4 1s, 3 3s, and 4 2s, 1 4, and 2 others, you have either 7 or 8 matching. If you assign the 1s such that you have 8 2s matching, the 8 don't win, and the remaining 6 can't win either; if you assign the 1s to make exactly 7 matching 3s, then you don't have 8 matching. Without that clarification, my bracketed remark is open to the interpretation that you presented -- my intention in making that remark was to briefly illustrate the 'exactly 7 matching' rule.
Following up the post ##32 and #33 I show here counting relevant cases of N(10), N(11), N(12), N(13) and N(14). N(n) is introduced in post #32.
N(10)
##Three\ 3-of-a-kind##
For brevity I introduce < > notation for number of multiset multiset permutation of the case AAABBBCCCD
[tex]<3+3+3+1> = \frac{10!}{3!3!1!}[/tex]
##<3+3+3+1>*5*4 ##... choice D,E
##Two\ 3-of-a-kind##
AAABBBCCCC
##<3+3+4>*5*\ 4C_2## ...choice C,(AB)
AAABBBCCDD
##<3+3+2+2>*5*\ 4C_2## ...choice E,(AB)
AAABBBCCDE
##<3+3+2+1+1>*5*\ 4C_2## ...choice C,(AB)
##One\ 3-of-a-kind##
AAABBBBBBB (*)
##<3+7>*5*4## ...choice A,B
AAABBBBBBC
##<3+6+1>*5*4*3## ...choice A,B,C
AAABBBBBCC
##<3+5+2>*5*4*3##... choice A,B,C
AAABBBBBCD
##<3+5+1+1>*5*4*3## ...choice A,B,E
AAABBBBCCD
##<3+4+2+1>*5*4*3*2##... choice A,B,C,D
AAABBBBCDE
##<3+4+1+1+1>*5*4##... choice A,B
AAABBBBCDE
##<3+2+2+2+1>*5*4##... choice A,B
##7-of-a-kind##
In addition to (*)
AAAAAAABBC
##<7+2+1>*5*4*3## ...choice A,B,C
AAAAAAABCD
##<7+1+1+1>*5*4## ...choice A,E********************************************
N(11)
##Two\ 4-of-a-kind##
AAAABBBBCCC
##<4+4+3>*5*\ _4C_2 ##... choice C,(AB)
AAAABBBBCCD
##<4+4+2+1>*5*4*3##... choice C,D,E
AAAABBBBCDE
##<4+4+1+1+1>*\ _5C_2##... choice (AB)
##One\ 4-of-a-kind##
AAAABBBBBBB (*)
##<4+7>*5*4## choice A,B
AAAABBBBBBC
##<4+6+1>*5*4*3## choice A,B,C
AAAABBBBBCC
##<4+5+2>*5*4*3## choice A,B,C
AAAABBBBBCD
##<4+5+1+1>*5*4*3## choice A,B,E
AAABBBCCCD
##<4+3+3+1>*5*4*3## choice A,D,E
AAAABBBCCDD
##<4+3+2+2>*5*4*3## choice A,B,E
AAAABBBCCDE
##<4+3+2+1+1>*5*4## choice A,B
##7-of-a-kind##
In addition to (*)
AAAAAAABBBC
##<7+3+1>*5*4*3## choice A,B,C
AAAAAAABBCC
##<7+2+2>*5*\ _4C_2## choice A,(BC)
AAAAAAABBCD
##<7+2+1+1>*5*4*3## choice A,B,E
AAAAAAABCDE
##<7+1+1+1+1>*5## choice A
N(12)
##Two\ 5-of-a-kind##
AAAAABBBBBCC
##<5+5+2>*5*\ _4C_2 ##... choice C,(AB)
AAAAABBBBBCD
##<5+5+1+1>*5*\ _4C_2 ##... choice E,(AB)
##One\ 5-of-a-kind##
AAAAABBBBBBB (*)
##<5+7>*5*4## choice A,B
AAAAABBBBBBC
##<5+6+1>*5*4*3## choice A,B,C
AAAAABBBBCCC
##<5+4+3>*5*4*3## choice A,B,C
AAAAABBBBCCD
##<5+4+2+1>*5*4*3*2## choice A,B,C,D
AAAAABBBCCCD
##<5+3+3+1>*5*4*3## choice A,D,E
AAAAABBBCCDD
##<5+3+2+2>*5*4*3## choice A,B,E
AAAAABBBBCDE
##<5+4+1+1+1>*5*4## choice A,B
AAAAABBBCCDE
##<5+3+2+1+1>*5*4*3## choice A,B,C
AAAAABBCCDDE
##<5+2+2+2+1>*5*4## choice A,E
##7-of-a-kind##
In addition to (*)
AAAAAAABBBBC
##<7+4+1>*5*4*3## choice A,B,C
AAAAAAABBBCC
##<7+3+2>*5*4## choice A,B,C
AAAAAAABBBCD
##<7+3+1+1>*5*4*3## choice A,B,E
AAAAAAABBCCD
##<7+2+2+1>*5*4*3## choice A,D,E
AAAAAAABBCDE
##<7+2+1+1+1>*5*4## choice A,B
N(13)
##Two\ 6-of-a-kind##
AAAAAABBBBBC
##<6+6+1>*5*\ _4C_2 ##... choice C,(AB)
##One\ 6-of-a-kind##
AAAAAABBBBBBB (*)
##<6+7>*5*4## choice A,B
AAAAAABBBBBCC
##<6+5+2>*5*4*3## choice A,B,C
AAAAAABBBBCCC
##<6+4+3>*5*4*3## choice A,B,C
AAAAAABBBBBCD
##<6+5+1+1>*5*4*3## choice A,B,E
AAAAAABBBBCCD
##<6+4+2+1>*5*4*3*2## choice A,B,C,D
AAAAAABBBCCCD
##<6+3+3+1>*5*4*3## choice A,D,E
AAAAAABBBCCDD
##<6+3+2+2>*5*4*3## choice A,B,E
##7-of-a-kind##
In addition to (*)
AAAAAAABBBBBC
##<7+5+1>*5*4*3## choice A,B,C
AAAAAAABBBBCC
##<7+4+2>*5*4*3## choice A,B,C
AAAAAAABBBCCC
##<7+3+3>*5*\ _4C_2## choice A,(BC)
AAAAAAABBBBCC
##<7+4+1+1>*5*4*3## choice A,(BC)
AAAAAAABBBCCD
##<7+3+2+1>*5*4*3*2## choice A,B,C,D
AAAAAAABBCCDD
##<7+2+2+2>*5*4## choice A,E
AAAAAAABBBCDE
##<7+3+1+1+1>*5*4## choice A,B
AAAAAAABBCCDE
##<7+2+2+1+1>*5*\ _4C_2## choice A,(BC)
N(14)
##Two\ 7-of-a-kind##
AAAAAAABBBBBBB
##<7+7>*5*4##... choice A,B
##One\ 7-of-a-kind##
AAAAAAABBBBBBC
##<7+6+1>*5*4*3## choice A,B,C
AAAAAAABBBBBCC
##<7+5+2>*5*4*3## choice A,B,C
AAAAAAABBBBCCC
##<7+4+3>*5*4*3## choice A,B,C
AAAAAAABBBBBCD
##<7+5+1+1>*5*4*3## choice A,B,E
AAAAAAABBBBCCD
##<7+4+2+1>*5*4*3*2## choice A,B,C,D
AAAAAAABBBCCCD
##<7+3+3+1>*5*4*3## choice A,D,E
AAAAAAABBBCCDD
##<7+3+2+2>*5*4*3## choice A,B,E
AAAAAAABBBBCDE
##<7+4+1+1+1>*5*4*3## choice A,B,E
AAAAAAABBBCCDE
##<7+3+2+1+1>*5*4*3## choice A,B,C
AAAAAAABBCCDDE
##<7+2+2+2+1>*5*4## choice A,E
I spotted a short cut of sorts. We can simply convert the successful patterns from one value of ##n## to the next. Every pattern for seven dice with at least one 0 can be changed to a pattern for eight dice with at least one 1 and vice versa. There are eleven successful patterns for every ##n## from ##0## to ##7##. E.g., from above, the successful patterns for ##n = 0## (must have a ##7##):
7, 7, 0, 0, 0
7, 6, 1, 0, 0
7, 5, 2, 0, 0
7, 5, 1, 1, 0
7, 4, 3, 0, 0
7, 4, 2, 1, 0
7, 4, 1, 1, 1
7, 3, 3, 1, 0
7, 3, 2, 2, 0
7, 3, 2, 1, 1
7, 2, 2, 2, 1
These can immediately be converted to the successful patterns for ##n = 1## (must have a ##6##), which are:
7, 6, 0, 0, 0 [20]
6, 6, 1, 0, 0 [30]
6, 5, 2, 0, 0 [60]
6, 5, 1, 1, 0 [60]
6, 4, 3, 0, 0 [60]
6, 4, 2, 1, 0 [120]
6, 4, 1, 1, 1 [20]
6, 3, 3, 1, 0 [60]
6, 3, 2, 2, 0 [60]
6, 3, 2, 1, 1 [60]
6, 2, 2, 2, 1 [20]
And, to get the patterns for ##n = 2## just take these and replace a ##6## with a ##5## etc.
The only tedious bit is to check each of these patterns for the first calculation. If the pattern is of the form ##xyyyy##, then we have ##5## sub-patterns; ##xyzzz## has ##20## etc. I've put these in square brackets above.
The second calculation can be done by setting up a rule, where ##k = 14 - n## and the five numbers in each row are ##r_1## to ##r_5##. This is the number of ways to get each sub-pattern:
$$\binom k {r_1} \binom {k - r_1}{r_2} \binom{k - r_1 - r_2}{r_3} \binom {k-r_1 -r_2 - r_3}{r_4} \binom{k - r_1 -r_2 - r_3 - r_4}{r_5}$$
We just multiply this by the number from the first calculation (in square brackets).
This can all just be put in a spreadsheet and cut and pasted. E.g. for ##n = 1## we have:
7​
6​
0​
0​
0​
20​
1716​
1​
1​
1​
1​
34320​
6​
6​
0​
0​
0​
30​
1716​
7​
1​
1​
1​
360360​
6​
5​
2​
0​
0​
60​
1716​
21​
1​
1​
1​
2162160​
6​
5​
1​
1​
0​
60​
1716​
21​
2​
1​
1​
4324320​
6​
4​
3​
0​
0​
60​
1716​
35​
1​
1​
1​
3603600​
6​
4​
2​
1​
0​
120​
1716​
35​
3​
1​
1​
21621600​
6​
4​
1​
1​
1​
20​
1716​
35​
3​
2​
1​
7207200​
6​
3​
3​
1​
0​
60​
1716​
35​
4​
1​
1​
14414400​
6​
3​
2​
2​
0​
60​
1716​
35​
6​
1​
1​
21621600​
6​
3​
2​
1​
1​
60​
1716​
35​
6​
2​
1​
43243200​
6​
2​
2​
2​
1​
20​
1716​
21​
10​
3​
1​
21621600​
140214360​
0.114864​
The probability of success, given one ##1## is ##0.114864##. Then, we just put all this together and we get:
np(n)q(n)p(n)q(n)
0.077887​
0.046058​
0.003587​
0.218082​
0.114864​
0.02505​
0.283507​
0.25962​
0.073604​
0.226806​
0.489781​
0.111085​
0.124743​
0.692675​
0.086406​
0.049897​
0.820961​
0.040964​
0.014969​
0.886374​
0.013268​
0.003422​
0.78496​
0.002686​
0.999313​
0.35665​
That's a final answer of ##p = 0.35665##.
That looks a bit high compared with @FactChecker's Monte Carlo simulation in #6. I wonder why?
0.35665 is close to what I ended up with when the rules were all decided on and I fixed a bug in my code. I made 20 runs just now of 1 million tests each (1 test=14 dice tossed). The 20 results ranged from 0.3561 to 0.3574 and averaged 0.35660.
I translated your code in post #6 into JavaScript almost exactly (I used zero based arrays) and got similar results to those you posted in #6 so I guess this must be before you fixed the bug. My code runs in the browser on jsfiddle.
I don't remember posting code in a post #6. Do you mean post #26? I posted a couple of versions. That first version was in post #19. It had an early bug in the random number generation call which I fixed as mentioned in post #21. The second version was in post #26. The problem in that was that it did not count a success if there were 7 1's and other numbers with 0. It was decided that those should count as a success and that the results of #26 were too low. After fixing that my results agreed closely to the 0.35665.
Yes I linked to post #26 but labelled it as #6 by mistake.
Ah OK, I made the same change and agree with this result.
