Undergrad The Prisoner Paradox: Examining the Relativity of Probability in Everyday Life
The discussion centers around the Prisoner Paradox and the relativity of probability, particularly in scenarios involving independent events. Participants analyze the implications of a constant 50% probability of survival each day, concluding that while daily probabilities remain constant, the cumulative probability of survival changes based on prior outcomes. The conversation references the mathematical principles of probability and self-reference, highlighting the logical inconsistencies that arise when assumptions about probability are not well-defined. Key examples include the coin flip analogy and the radioactive decay formula, illustrating how probabilities are influenced by prior events.
  • Understanding of basic probability theory
  • Familiarity with independent events in probability
  • Knowledge of self-reference in logical reasoning
  • Awareness of paradoxes in mathematics, such as the Unexpected Hanging Paradox
  • Study the principles of conditional probability
  • Explore the implications of the Law of Large Numbers
  • Investigate the concept of self-reference in logic and mathematics
  • Examine the mathematical foundations of paradoxes, including the Barber Paradox
Mathematicians, statisticians, philosophers, and anyone interested in the complexities of probability and logical reasoning.
lukka98
For example, If I have a constant probability of 50% to death per day (sorry for the macabre example but I find it good);
Every day I wake up, I can say:"Today, at the end of the day, I have a probability of 0.5 to be live( or to be dead)!".
Now, one can calculate the probability that after some numbers of day I am death:
is equal to: 0.5 (prob. 1st day death) + 0.5(1st.live)*0.5(2nd death) + ... and so on , and it tends to 1.
For example after 2 days: P = 0,75 to be death.
If I calculate the probability to death exactly the 2nd day is: P = 0.5*0.5 = 25%, and it decrease with day number.
And the probability to be live at the "end of the n-day is" : (0.5)^n.Now there is my question:
If I wake up the second day, I can say:"Today I have a probability to live of 0.25 ( 0.5 1st day * 0.5 2nd day) "
But If I cannot say when I start to have "a life on probability" I can say:"Today I have 0.5 of probability to live!".
But this is wrong, because probability cannot change from different observer, so what I can say?
Thank you
  • Skeptical
Likes PeroK
You can't say this. Each day is independent of they other, just like flipping a coin. I could flip a coin heads up 5 times in a row and on the sixth flip the probability of getting heads is still 50%.
Likes lukka98
No. You can say that "Today I HAD a probability to live of 0.25.". The events of yesterday have changed the probabilities.
Probability CAN change with new events. If you lived through yesterday, that changed today's probabilities.
Likes PeroK and lukka98
So what I calculate is the probability to be live "2 days consecutively?"
Your calculation fully applies to decay of radioactive nulcei
N(t)=N(0) 2^{-t/t_{1/2}}
where ##t_{1/2}## is named half life of nuclei.
If probability were relative as you say, the big radioactive waste problem should have been removed.
Likes lukka98
Ok, but every day I have always a probability of 0.5 to survive, is correct?
and for example each 4 days i have always a probability of 0.0625 to survive, now or after 1 year?
GIVEN that you live to that day, you are correct. Of course, if you die before that day the probability changes.
Likes lukka98
Of course, if you are considering the real-world situation of the actuary tables, the probabilities do change as you age.
Likes lukka98
My situation was ideal, just for this question.
there is a thing that I have difficult to accept:
If, instead of a person I take an atom ( only for more real example) with the same 0.5 prob. to decay per day.
After 1 million of year of him "creation" there is a probability of 10^-50 that is already live, I know every day it survive with 0.5 prob. (numbers are only for example).
But If I start to observe it tomorrow, the probability to survive is 0.5. is correct?
"there is a small probability that resist up to there , but once I have the probability is always the same 0.5."
Sure (assuming it hasn't already decayed). Just like flipping a coin: The probability of getting 10 heads in a row is small, but if you've already gotten 9 heads then the probability is 0.5 that you'll get 10.
Likes lukka98
fresh_42 said:
Here is a famous example which I stumbled upon in a book from Martin Gardner:
https://en.wikipedia.org/wiki/Unexpected_hanging_paradox
I thought the solution to this was simply that there's a self-reference in the assumptions. It boils down to the logically invalid formulation of an assumption:
Assumption 1: You cannot predict (i.e. logically deduce) using assumption 1 ...
In other words, this is an assumption about what you can deduce using the assumption being put forward.
That's self-reference (like "this statement is false"), which cannot legitimately be used in logical reasoning.
This is what's called a mental block. It's become a bit of a problem for you. We can only repeat the same answer (which you always "like"), so it's up to you to try to free your mind.
Likes pinball1970
One final attempt to explain this. Let's stick with the macabre. You have 64 prisoners. Every day each prisoner has to toss a coin. If it's heads, then they get executed that day; and, if it's tails they stay alive for at least one more day.
On the first day 64 coins are tossed. Let's say 32 are heads - and 32 prisoners are taken away to be executed - and 32 are tails, hence 32 prisoners escape exceution.
On the second day, there are only 32 prisoners left and 32 coins tossed. Let's say there are 16 heads and hence 16 prisoners are taken away to be executed.
On the third day, there are only 16 prisoners, 8 of whom get heads and get executed and 8 of whom escape again.
As the days go by, there are half as many prisoners each day and half as many executions. Until eventually there is no one left.
This is a thinker.
pinball1970 said:
This is a thinker.
A crude analogy would be to compare the following assumptions:
1) Assume there are only finitely many primes.
That is a logically valid assumption, which turns out to be false.
2) Assume we cannot prove there are infinitely many primes.
That is not a valid assumption, because it refers to what we can prove using the assumptions. This sort of self-reference leads to problems. Although, it is tricky to see precisely how and where the logic break down.
Sort of circular reasoning?
I read the discussion and it was a little technical
I tried working through it and twisted myself in knots.
The liar/Barber paradox seem more obvious in terms of a self reference, (not when I first read about them. )
For discussion among the two on probability, they should agree that which state has probability 1, 100%.
It may be "He is living this morning 100%." or "He was living yesterday 100%" or so. Probability is assumption based on our current knowledge. It depends on how much we know about it and is to be renewed by new knowledge.
My point is that is unnecessary. It is perhaps interesting precisely where this particular example breaks down, but the whole concept of having an assumption that says what you can and can't prove is invalid. "Being surprised" is one way of describing what you can and cannot deduce from the given assumptions. So, "being suprised" cannot be part of an assumption.
For example, if you proposed an alternative Group Theory where we have the usual group axioms plus something like:
5) You cannot prove Lagrange's theorem.
Then that cannot be taken seriously as mathematics. What precisely goes wrong with this version of group theory may be very difficult to untangle. But, the basic concept of an axiom such as 5) is invalid from the outset.
I'm going to go out on a limb here, as I'm not quite sure I follow this thread and I'm probably misinterpreting something, so I'll simply phrase it from my own perspective. I could go assuming things and proposing some new axioms along with perhaps countable choice and a simple correction for the axiom schemas of specification and replacement, etc. (ZF'CC maybe, lol, I don't know), but I simply don't care to. Real mathematicians can handle that sort of thing. Same with the probability question originating in this thread which I may have an answer to, but only because I put the problem into a slightly different context that I won't be able to put my finger on in this thread so to speak (my apologies).
Anyways, I hope you find what you're looking for lukka98. PeroK too.
Edit: There is no formula that can be applied to a set so as to generate the class of ordinals, so I think the axiom schemas are still ok. Just countable choice would probably work just fine and we're back to good. Again, shooting from the hip here and not really caring (sorry), but hopefully that helps.
Warning: off-topic.
I propose:
5) You cannot prove the continuum hypothesis.
Do you think anything would go wrong?
pbuk said:
Warning: off-topic.I propose:
My point is that your axiom 5 is invalid. We don't need to get tangled up in what sort of system we have created.
The trap in the prisoner paradox is to dive into the logical system you have been given and try to figure out what goes wrong. That's the approach that leads to arguments, debates and confusion.
Instead, I propose that we step back and first examine the axioms we have implicitly been given. If we identify that those axioms are invalid or not well formed then we shouldn't attempt any logical reasoning on the basis of them.
Continuum hypothesis is solved already, sorry. It was independent from ZF because you need countable choice and it was independent from ZFC because ZFC is inconsistent. that's already been proven. Sorry...
  • Skeptical
Likes pbuk and PeroK
AplanisTophet said:
Sorry...
Rather than post nonsense and apologise, it would be better not to post the nonsense at all.
Likes PeroK
I understand skepticism. Countable choice is enough to show ##\omega_1## can't exist per the "Limits of Two Ordinal Sequences" thread in this forum. If ##\omega_1## can't exist, there are no uncountable ordinals. The axiom of choice is enough to prove the existence of uncountable ordinals, so that is why ZFC is inconsistent. ZF is not enough. ZFCC solves the continuum hypothesis.
I dropped out of college when I learned Cantor's Theorem and then went on to become a CPA instead. I've been auditing the foundations of Mathematics ever since and preparing taxes for a living. CPA stands for certified pain in the ass. I completely understand skepticism. This has been a 20 year journey for me with quite a few scars... I don't take it lightly.
I truly am sorry though... In many ways, this stinks.
  • Skeptical
Likes PeroK
Say professor and students are going to observe a Shroedinger cat in a box.
Professor says "I see living cat two days ago so she is living with probability of 0.25 today."
A student says " I see Box yesterday, at that time the cat was ..."
Professor says " Stop saying it. That would disturb my probability."
The probability for the professor and that of the student are different. Probability depends on "who assumes with how much knowledge" If you say "relative" in this sense I will say yes to the titled question.
How did this thread go from flipping coins to axioms and logical systems??
The OP's question seemed easy enough to answer with a simple example of flipping coins.
Likes pbuk
I posted a long break down of the paradox for my understanding.
I try to rephrase it so it made sense and there were no logical inconsistencies
It was deleted because it looked like I quoted you, I actually wanted you to give it the once over.
Anyway it was deleted, I had just deleted it myself from my mail so I cannot remember what I put!
In short, I think I get it. Thanks @PeroK
EDIT: I do have a copy but I am going off topic so ill leave it
Likes PeroK
thread closed for Moderation...
