Understanding Probability of Bias in Coin and Dice Tosses
  • Context: High School
  • Thread starter Thread starter bsharvy
    Bias Probability
The discussion revolves around the probability of bias in coin and dice tosses, exploring how to calculate the likelihood that a coin or die is biased based on observed outcomes. The conversation touches on concepts from both frequentist and Bayesian statistics, including the implications of prior probabilities and significance levels.
  • One participant suggests that the probability of bias can be calculated using the formula 1 - (0.5)^n for coin flips and 1 - (1/6)^n for dice rolls, but expresses confusion about the implications of these calculations.
  • Another participant corrects this view, stating that whether a coin is biased is not a random variable with a probability, emphasizing the need to reject the null hypothesis based on low probabilities of observed outcomes.
  • A later reply discusses the necessity of a prior probability when determining the likelihood of bias, illustrating this with examples of extreme cases where either all coins are biased or none are.
  • One participant notes that the discussion is framed within Bayesian statistics, indicating that the probability of bias can be treated as a random variable in that context, contrasting with frequentist perspectives.
  • References to external resources, such as Insights articles on Bayesian inference, are provided to support the discussion.
Participants express disagreement on whether the probability of bias can be treated as a random variable, with some advocating for a Bayesian approach while others adhere to frequentist principles. The discussion remains unresolved regarding the proper methodology for calculating bias probabilities.
Limitations include the dependence on prior probabilities and the distinction between Bayesian and frequentist interpretations of probability, which are not fully resolved within the discussion.
bsharvy
TL;DR
Can you find the probability that a coin or die is loaded?
I was thinking that the probability of a set of events not happening is the same as the probability of that the die/coin is biased.
So, if I flip a coin 10 times and get heads every time, the probability the coin is biased is 1- (.5)^7.
Roll a die 5 times, get "4" all times, probability of bias = 1 - (1/6)^5
But that suggests the probability of bias after one coin toss is 50%, which can't be right. I'm also not sure how to calculate when the results are mixed, such as flipping a coin 10 times and getting heads 7 times.
Help!
Your question has a subtle, but important, mistake. Whether a coin is biased is not a random variable with a probability. So you should not talk about its probability. The only probability that you can talk about is that of getting a certain result from a fair coin. If that probability is too low, you are justified in rejecting the assumption that the coin is fair. This is called "rejecting the null hypothesis". There are certain standard levels of small probability, called "significance levels", that allow you to reject the null hypothesis. They include 0.05, 0.025, and 0.01. These are the probabilities of rejecting the null hypothesis even though it is true, so smaller is better. For something like the discovery of a new elementary particle in science, the significance level required is extremely demanding. It is "5 sigma", which is a probability of ##3\times 10^{-7}## or about one in 3.5 million.
bsharvy said:
TL;DR Summary: Can you find the probability that a coin or die is loaded?
Help!
You cannot compute the probability that a coin is biased without a prior probability of the coin being biased. Consider the two extreme cases:
1) There are no biased coins.
2) All coins are biased.
To take a more realistic example: assume that one coin in a hundred is biased (and to keep things simple comes up heades every times). Out of approximately every 1100 coins we have:
1000 fair coins that give ten heads in a row approximately once;
11 biased coins that come up heads every time.
If we get 10 heads in a row, then the probability is about 11/12 that the coin is biased.
If we assume that one coin in a thousand or one coin in a million is biased, we will get very different answers.
It certainly can be considered a random variable with a probability distribution in Bayesian statistics. But in frequentist statistics it would not be a random variable.
Yes, I agree, the prior probability is needed.
@bsharvy basically this is an exercise in Bayesian statistics. I have a set of Insights articles on this topic. In particular, the third one may be useful for you since I specifically examine the fair coin question in some depth:
https://www.physicsforums.com/insights/how-bayesian-inference-works-in-the-context-of-science/
  • · Replies 21 ·
  • · Replies 20 ·
  • · Replies 41 ·
9K
  • · Replies 126 ·
9K
  • · Replies 45 ·
