Probability of finding an electron
3 replies · 8K views
stunner5000pt
Consider the probability of finding an electron in the region defined by the cone of half angle 23.5 degrees measured from the z axis
a) If the electron were eqally likely to be found anywhere in space, then what would be the proability of finding it inside the cone?
b) Repeat the same calcuculation but for an electron in a n=2, l=1, m=0 state
[tex]\int_{all space} \Psi^*(r') \Psi(r') dr'[/tex]
for part a do they mean the electron in the ground state [itex]\Psi_{000}[/itex]??
In whiuch case the integral we need to do is
[tex]\int_{0}^{\0}^{\infty} (rR_{00}(r))^2 dr \int_{0}^{\frac{47\pi}{360}} \int_{0}^{\pi} (Y_{00}(\theta,\phi})^2 \sin \theta d\theta d\phi[/tex]
And apply the similar concept to get the answer for part b??
Meir Achuz said:
Part A means to put in a WF that is a constant.
The answer is then just the solid angle of the 23.5 degree cone.
For part B, put Y_{10}^2 into the integral.
doesnt the radial density matter as well??
