Probability of Getting 10 Pairs from a Box of 30 Socks
  • Thread starter Thread starter juanitotruan77
    Probability
The problem involves determining the most probable number of tries needed to obtain 10 pairs of socks from a box containing 30 pairs. The context includes considerations of probability distributions and sample spaces related to sock pairs.
  • Participants discuss the nature of the pairs required (e.g., left and right socks) and the conditions for an acceptable pair. There are suggestions to lay out the sample space and consider simpler cases to understand the probability distribution better.
The discussion is ongoing, with various interpretations and approaches being explored. Some participants have provided insights into the sample space and probability calculations, while others express uncertainty about the validity of certain methods. No explicit consensus has been reached regarding the most probable number of tries.
There are constraints regarding the assumptions about sock pairs, such as whether left and right socks are treated differently. Additionally, some participants mention the complexity of calculating probabilities and distributions for different scenarios.
  • #31
haruspex said:
P(r,t) is the probability that you will have r pairs after t selections. But you want the probability of needing t selections to get r pairs. You might have had r pairs already after t-1 selections.
So i how do i do that?
  • #32
juanitotruan77 said:
but what about the 22=0?
Check your program, 22 should not be 0.
  • #33
i don't know if I am wrinting the formula correctly.
Prob= NCr * (N-r)C(t-2r) * ((2^t-2r) / (2N)Ct)
  • #34
P(r, t) = NCr × (N-r)C(t-2r) × 2^(t-2r) / (2N)Ct
  • #35
Does the division affect the whole term or just the 2^(t-2r) ?
  • #36
You want the probability that the tth selection took you from r-1 pairs to r pairs. so first you had to have r-1 pairs after t-1 selections (for which you have a formula now), then the tth had to complete one more pair.
  • #37
Since the other terms are just multiplied together, it should not make any difference.
  • #38
duh, yeah you're right. I redid the code and i got this result
Code:
1 -0.31666666666667
2 -0.010169491525424
3 -0.00049678550555231
4 -3.2811426579306E-5
5 -2.7464921801875E-6
6 -2.7964284016454E-7
7 -3.3660712242028E-8
8 -4.6900266694263E-9
9 -7.4409076966859E-10
10 -1.3263650083219E-10
11 -2.6262027164774E-11
12 -5.7169038726038E-12
13 -1.3547871156431E-12
14 -3.4590309335568E-13
15 -2.6318713624889E-13
16 -1.5573994348188E-12
17 -1.4601455216145E-11
18 -1.4060631661627E-10
19 -1.3993681163211E-9
20 1.4334985450147E-8
21 1.5051734735179E-7
22 8.0661860450918E-7
23 2.9292991423064E-6
24 8.0753652026503E-6
25 1.7945256006232E-5
26 3.3326904011481E-5
27 5.2930965194649E-5
28 7.2980573222738E-5
29 8.8184859310981E-5
30 9.3874205072845E-5
31 8.8184859310998E-5
32 7.29805732227E-5
33 5.2930965194717E-5
34 3.3326904011596E-5
35 1.7945256006425E-5
36 8.0753652023174E-6
37 2.9292991415367E-6
38 8.0661860563958E-7
39 1.5051734559838E-7
40 1.4334988312849E-8
41 1.3993583354239E-9
42 1.40595506151E-10
43 1.4544640215304E-11
44 1.6242406122789E-12
45 3.0078529857016E-13
46 1.4989134045413E-12
47 5.2256074460519E-12
48 2.0009163554113E-11
49 8.4622087530938E-11
50 3.9790950249657E-10
51 2.0969830781569E-9
52 1.2506737785137E-8
53 8.544642338361E-8
54 6.7913261182817E-7
55 6.4084817537707E-6
56 7.3825709803439E-5
57 0.0010812390414962
58 0.021468926553672
59 0.65
60 40
  • #39
So i have to multiply the result from the formula with the probability that i'll get the last sock in the tth draw?
  • #40
A minor issue but you need to fix your combination calculation so that if (t-2r) > (N-r), or if (t-2r) < 0 (and (N-r) > 0), then (N-r)C(t-2r) = 0 (this is how aCb is mathematically defined). This will fix the cases t= 0 through t = 19 and t = 41 through 60 where the probability should be zero.
  • #41
Done
Code:
1 0
2 0
3 0
4 0
5 0
6 0
7 0
8 0
9 0
10 0
11 0
12 0
13 0
14 0
15 0
16 0
17 0
18 0
19 0
32 7.29805732227E-5
41 0
42 0
43 0
44 0
45 0
46 0
47 0
48 0
49 0
50 0
51 0
52 0
53 0
54 0
55 0
56 0
57 0
58 0
59 0
60 0
  • #42
Yes. At this point, you have r-1 pairs and (t-1)-2(r-1) odd ones. The remaining 2N-t+1 socks consist of the same number of odd ones and N+r-t pairs. So what are the chances the next sock drawn will complete a pair?
  • #43
so let's take 30 for the example. If you have already 9 pairs in 29 tries, so there're 31 socks and you've 11 odd socks So you've 11 possible pairs with you. So the probability of you getting one of the 11 probable pairs is 31n11?
  • #44
What is "31n11"? Do you mean 31C11? That would be the number of ways of choosing 11 things from 31, a huge number, and certainly not a probability.
As you say, there would be 31 socks left, and you want the prob of choosing one out of a particular 11 of them...
  • #45
Yeah 31C11, sorry. mmm 11/31?
  • #46
Yes. can you now generalise that using N, t, r?
  • #47
Having in mind that P(r, t) is the probability of having r-1 pairs in t-1 tries, then:
Q(r,t) = P(r, t) x ((t-1)-(2r-2)))/(2N-(t-1))
Just one more thing, why does that formula give me the probability of having r-1 in t-1 tries, and not r pairs in t tries if we're using t and r and not r-1 And t-1.
  • #48
I was checking my code and i noticed that i was doing something wrong. When i corrected it, it gave me the following:
Code:
1 0
2 0
3 0
4 0
5 0
6 0
7 0
8 0
9 0
10 0
11 0
12 0
13 0
14 0
15 0
16 0
17 0
18 0
19 0
20 7.1674927250735E-9
21 1.5051734722654E-7
22 1.6132372087358E-6
23 1.1717196568712E-5
24 6.460292162209E-5
25 0.00028712409609818
26 0.0010664609283647
27 0.0033875817724524
28 0.0093415133725204
29 0.022575323983591
30 0.048063592997323
31 0.090301295934364
32 0.14946421396033
33 0.21680523343696
34 0.27301399766135
35 0.29401507440453
36 0.26461356696408
37 0.19197454858178
38 0.10572511371171
39 0.039457219471355
40 0.0075156608516866
41 0
42 0
43 0
44 0
45 0
46 0
47 0
48 0
49 0
50 0
51 0
52 0
53 0
54 0
55 0
56 0
57 0
58 0
59 0
60 0
It seems its wrong, because I'm pretty sure that the one with the bigger probability should be 30 or 29
  • #49
No, P(r, t) was defined as the probability of having r pairs in t tries. We want P(r-1,t-1): ##Q(r,t) = \frac{{^NC_r} ^{N-r}C_{t-2r} 2^{t-2r}}{^{2N}C_t}\frac{t+1-2r}{2N-t+1}##
To find the peak value in a unimodal sequence, just look for two consecutive terms that are about equal. Algebraically, that will all but cancel out all the factorials, leaving a relatively simple polynomial, probably a quadratic. Solving that will almost certainly give you a non-integer. The value you're looking for will be either the next integer up or the next one down.
  • #50
I didn't understand that, can you explain it, please?
  • #51
You have the expression for Q(r,t). We want the peak value as t varies. At the peak, consecutive terms will be about equal (same principle as finding maxima with calculus). So you write Q(r,t) = Q(r,t+1). Because of all the factorials involved (see the formula I posted for nCr), there will be a lot of cancellation of terms. When the smoke clears, you should have a relatively simple polynomial for t. This won't give a whole number, so try the whole numbers either side of what it does give. One of these two will be the peak term in the sequence.
  • #52
So i equal them and replace the values in the full formula with all the factorials? You said at the beginning that you got 27 by doing this, how? i tried and it didn't reduced to a cuadratic t term.
  • #53
Sorry, I forgot to edit the formula. I meant:
##Q(r,t) = \frac{{^NC_{r-1}} ^{N-r+1}C_{t+1-2r} 2^{t+1-2r}}{^{2N}C_{t-1}}\frac{t+1-2r}{2N-t+1}##
  • #54
Well, i did the Q(r,t) = Q(r,t+1)
and it gave me t=12.50842616853577.
I attached my Mathematica notebook with the procedure, but i can't find with I'm doing wrong.
  • #55
Starting with the same equations, when I do all the cancellation I wind up with t2-t-2N(2r-1) = 0. This gives t = 33.76. (My earlier answer of 27 was wrong.)
I checked it by generating Q(r,t) for t = 20 to 40 in a spreadsheet, and the peak is at t=34 (with prob=0.168).
Code:
t-1	Pr-1t-1	Qrt
19	0.0000	0.0000
20	0.0000	0.0000
21	0.0000	0.0000
22	0.0001	0.0000
23	0.0004	0.0001
24	0.0014	0.0002
25	0.0041	0.0008
26	0.0107	0.0025
27	0.0245	0.0067
28	0.0498	0.0156
29	0.0903	0.0320
30	0.1456	0.0583
31	0.2084	0.0934
32	0.2628	0.1314
33	0.2891	0.1606
34	0.2730	0.1680
35	0.2162	0.1470
36	0.1384	0.1038
37	0.0674	0.0556
38	0.0223	0.0202
39	0.0038	0.0038
(Note that the Q(r,t) add up to 1.)
Here are the cell formulae:
First column (t-1) starts at cell A4. Named cell _r1 represents r-1. These are the formulae in cells B4, C4:
=COMBIN(_N;_r1)*COMBIN(_N-_r1;$A4-2*_r1)*2^($A4-2*_r1)/COMBIN(2*_N;$A4)
=B4*(A4-2*_r1)/(2*_N-A4)
A4 contains 19. A5 etc. increment from there.
  • #56
Code:
t-1	Pr-1t-1	Qrt
19	0.0000	0.0000
20	0.0000	0.0000
21	0.0000	0.0000
22	0.0001	0.0000
23	0.0004	0.0001
24	0.0014	0.0002
25	0.0041	0.0008
26	0.0107	0.0025
27	0.0245	0.0067
28	0.0498	0.0156
29	0.0903	0.0320
30	0.1456	0.0583
31	0.2084	0.0934
32	0.2628	0.1314
33	0.2891	0.1606
34	0.2730	0.1680
35	0.2162	0.1470
36	0.1384	0.1038
37	0.0674	0.0556
38	0.0223	0.0202
39	0.0038	0.0038
The thing is that my physics teacher told me that the answer has to be near 28, that's why I'm so frustrated. I think it has something to do with the fact that you might be considering that the array of posibilities is a binary tree but you can't have a pair in your next move without another not pair sock so is something like
  • #57
I did simulate this and I got
Code:
20 0.000:
21 0.000:
22 0.000:
23 0.000:
24 0.000:
25 0.000:
26 0.001:
27 0.003:*
28 0.009:****
29 0.020:**********
30 0.040:********************
31 0.069:**********************************
32 0.105:****************************************************
33 0.140:*********************************************************************
34 0.160:********************************************************************************
35 0.158:******************************************************************************
36 0.131:*****************************************************************
37 0.089:********************************************
38 0.048:***********************
39 0.019:*********
40 0.005:**
41 0.001:
  • #58
Code:
20 0.000:
21 0.000:
22 0.000:
23 0.000:
24 0.000:
25 0.000:
26 0.001:
27 0.003:*
28 0.009:****
29 0.020:**********
39 0.019:*********
40 0.005:**
41 0.001:
Ohhh i made a mistake in the code, i didn't think that the random number generator could generate more than 1 pair of the same kind of socks. You're both right, and THANKS A LOT FOR ALL YOUR HELP, especially to haruspex for having me so much patience.
  • #59
It was an interesting journey, and I hope it was useful for you. (You can no longer claim to know nothing about probability!)
  • #60
yeah, I've learn more probability here in 5 days than in 6 months of school, thanks!
  • · Replies 24 ·
  • · Replies 16 ·
  • · Replies 29 ·
