Probability of measuring an eigenstate of the operator L ^ 2
The discussion focuses on calculating the probability of measuring the angular momentum operator \(L^2\) for a particle with the normalized wave function \(\Psi(r,\theta,\varphi)=\sin^2(\theta)e^{-i\varphi}f(r)\). The key conclusion is that for \(L^2\) to be strictly greater than \(12\hbar^2\), the quantum number \(l\) must be greater than 3. The normalization constant \(N\) was determined to be \(\frac{15}{32\pi}\), leading to the probability expression \(P(L^2>12\hbar^2)=1-\frac{15}{32\pi}(|f_{1}^{-1}|^2+|f_{3}^{-1}|^2)\).
  • Understanding of quantum mechanics concepts, particularly angular momentum operators.
  • Familiarity with spherical harmonics and their properties.
  • Knowledge of normalization techniques in quantum mechanics.
  • Experience with integration in spherical coordinates.
  • Study the properties of spherical harmonics in quantum mechanics.
  • Learn about normalization of wave functions in quantum systems.
  • Explore the implications of angular momentum quantization in quantum mechanics.
  • Investigate the use of numerical methods for calculating coefficients in quantum states.
Students and researchers in quantum mechanics, particularly those focusing on angular momentum, wave function normalization, and probability calculations in quantum systems.
Marioweee
psb
$L^2Y^{m}_l=\hbar^2l(l+1)Y^{m}_l$
Calculate, with a relevant digit, the probability that the measure of the angular momentum $L ^2$ of a particle whose normalized wave function is
\begin{equation}
\Psi(r,\theta,\varphi)=sin^2(\theta)e^{-i\varphi}f(r)
\end{equation}
is strictly greater than ##12(\hbar)^2##.
My solution:
First of all, if the measure is sitrictly greater than ##12(\hbar)^2## then l has to be greater than 3 because:
\begin{equation}
\end{equation}
Then, to apply the operator ##L^2## I have tried to express the wave function as linear combination of spherical harmonics.
\begin{equation}
sin^2(\theta)e^{-i\varphi}=\sum_{l=0}^{\inf}\sum_{m=-l}^{l}f^{m}_{l}Y^{m}_{l}
\end{equation}
with the coefficients ##f^{m}_{l}##:
\begin{equation}
f^{m}_{l}=\int_{0}^{2\pi}d\varphi\int_{0}^{\pi}d\theta sin^2(\theta)e^{-i\varphi}(Y^{m}_{l})^{*}
\end{equation}
Realizing that the only nonzero integrals are those with the coefficients l=1,3,5,7... and m=-1.
Therefore, it follows that:
\begin{equation}
sin^2(\theta)e^{-i\phi}=\sum_{l=1,3,5,...}^{\inf}f^{-1}_{l}Y^{-1}_{l}
\end{equation}
Next I have calculated with a software the coefficients ##f^{-1}_{l}## and the probability of measuring a value lower ##12\hbar^2## should be:
\begin{equation}
P(L^2<12\hbar^2)=1-|f^{-1}|^2_{1}-|f^{-1}_{3}|^2
\end{equation}
The problem is that the sum of the infinite coefficients f is not 1 (at least that seems to be when adding quite a few terms) so they cannot indicate the probability. How can I normalize the infinite linear combination so that the sum of the terms is 1 and indicates the probability of measuring an eigenstate of ##L^2##. Would there be another method to solve the exercise?
Thank you very much for your attention and help.
Here's an idea for making the calculation more manageable. If you let ##P(l,m)## be the probability of finding ##L = l## and ##L_z = m##, then you have:
##\sum_{l=0}^\infty \sum_{m=-l}^{+l}P(l,m) = 1##
Now, we can break it up into two parts:
##\sum_{l=0}^3 \sum_{m=-l}^{+l}P(l,m) + \sum_{l=4}^\infty \sum_{m=-l}^{+l} P(l,m) = 1##
The second part is what you're being asked to calculate, but you can rewrite it as:
##\sum_{l=4}^\infty \sum_{m=-l}^{+l} P(l,m) = 1 - \sum_{l=0}^3 \sum_{m=-l}^{+l}P(l,m)##
Now, the right-hand side only involves 4 terms.
Marioweee said:
\begin{equation}
\end{equation}
If you want ##|f^{m}_{l}|^2## to represent a probability, then you should first normalize the function ##\sin^2\theta e^{-i\varphi}##.
When integrating over ##\varphi## and ##\theta##, ##\int d\varphi \int d \theta## should be ##\int d\varphi \int \sin \theta \, d \theta##
This is what I have tried to express with equation 6. Anyways, thank you very much for your attention and for your help.
I had not even thought about it since the statement said that the function was already normalized but this must be the solution. Thank you very much, in a while I will try and if I have any questions I will comment. Again, thank you very much.
The wavefunction involves the radial function ##f(r)##. The normalization, therefore, puts a condition on ##f(r)## to balance the angular function you are given.
For example, we can rewrite the normalized wavefunction as:
\begin{equation}
\Psi(r,\theta,\varphi)=N sin^2(\theta)e^{-i\varphi} (\frac 1 N f(r))
\end{equation}
Where ##N## is a normalization constant needed for the spherical harmonic decomposition.
I've calculated N which is equal to ##\dfrac{15}{32\pi}##. Therefore, the probability of measuring ##L^2## greater than ##12h\hbar^2## would be:
\begin{equation}
P(L^2>12\hbar^2)=1-\dfrac{15}{32\pi}(|f_{1}^{-1}|^2+||f_{3}^{-1}|^2)
\end{equation}
Sorry for so many obvious questions but I am new to quantum mechanics and I still miss the basics but I want to make sure I do things correctly.
\begin{equation}
\end{equation}
Are you sure that's not ##N^2 = \frac{15}{32\pi}##?
Yes, you are right, that's ##N^2##.
\begin{equation}
\end{equation}
That looks right.
Okey, I finally got the answer. Thanks for everyone's help, for my part I conclude this post.
  • · Replies 0 ·
  • · Replies 21 ·
