Probability student exam problem
The discussion revolves around calculating probabilities for a student who knows how to solve 15 out of 20 exam problems. The main queries include finding the probability of answering all 10 questions, exactly 8 questions, and at least 9 questions correctly. Participants clarify that the total combinations of questions can be calculated using binomial coefficients, specifically 20C10 for the exam questions and 15C10 for the problems the student can solve. The conversation emphasizes the need to determine how many combinations of good and bad problems can be selected for each scenario. Ultimately, the focus is on applying combinatorial methods to derive the required probabilities.
themadhatter1
A class is given a list of 20 study problems from which 10 will be on an upcoming exam. If a student knows how to solve 15 of the problems, find the probability that the student will be able to answer (a) all 10 of the questions on the exam. (b) exactly 8 questions on the exam, and (c) at least 9 questions on the exam.
Well for a I found 20C10 which is the total possible combinations of questions that could be on the test then I found 20C15 which is the total number of combinations of the problems the student solved. Would you divide 20C15 by 20C10? I'm not sure how to solve this problem.
The student can solve 15 problems, but these problems are given. The student knows, which ones he can solve.
From the viewpoint of the student, there are 15 good problems and 5 wrong ones. What is the probability that all the 10 problems in the test are selected from the good ones? What is the probability, that 8 good and 2 wrong problems all selected? What is the probability that at least 9 good problems are selected?
ehild
ehild
Would that be 10/15 or 1/3? because there are 10 problems being chosen and 15 good ones.
The elementary event is which problem is chosen. You said correctly already that 20C10 is the total number of the possible set of questions: you can select 10 out of 20 in (20!/10!10!) ways.
How can you select 10 question out of 15?
ehild
ehild
15C10 ways?
Yes.
ehild
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
