Problem #47: Finding Masses for Center of Mass at Origin - February 18, 2013
  • Thread starter Thread starter Jameson
The discussion focuses on solving a problem involving point masses located at vectors $v_1=<1,0>$, $v_2=<-1,1>$, and $v_3=<-1,-1>$ to find masses $m_1, m_2, m_3$ such that the center of mass is at the origin. The solution involves setting up a system of three equations based on the center of mass formula and the constraint that the sum of the masses equals 1. The final solution yields $m_1=\frac{1}{2}$, $m_2=\frac{1}{4}$, and $m_3=\frac{1}{4}$, confirming the correct application of vector principles and scalar multiplication.
  • Understanding of vector notation and operations
  • Familiarity with the concept of center of mass
  • Knowledge of solving systems of linear equations
  • Basic principles of scalar multiplication in vectors
  • Study the method of solving systems of equations using substitution and elimination techniques
  • Explore the concept of center of mass in multi-dimensional spaces
  • Learn about vector operations, including addition and scalar multiplication
  • Investigate applications of center of mass in physics and engineering contexts
Students in physics or mathematics, educators teaching vector calculus, and anyone interested in understanding the principles of mass distribution and center of mass calculations.
Jameson
Insights Author
MHB
Suppose there are point masses located at the points in the plane described by the vectors $v_1=<1,0>$, $v_2=<-1,1>$ and $v_3=<-1,-1>$. Find masses $m_1,m_2,m_3$ such that the center of mass is the origin of the plane given that the sum of these masses is 1.
Recall that the center of mass vector can be found by the following equation: [math]c = \frac{m_1}{m}v_1+\frac{m_2}{m}v_2+\frac{m_3}{m}v_3[/math], where $m$ is the sum of the masses.
Hint: [sp]Since $m=1$ this is just solving a three variable system of equations. The fact that $m=1$ should be used twice.[/sp]
Congratulations to the following members for their correct solutions:
1) MarkFL
2) Sudharaka
Remark: [sp]This problem is nothing more than solving a three-variable system of equations but using the definition of scalar multiplication of vectors and the bit of information about the sum of the three masses must both be applied to simply this into a form that is recognizable as a three-variable system.
1) For a vector with two real components, $<a,b>$ and a real number $c$ (not a vector, but a scalar) then $c<a,b>=<ca,cb>$. This principle should be familiar to most high school students who have taken math or physics.
2) Since $m_1+m_2+m_3=1$, then all of the terms that divide by $m$ can be written without the denominator. Dividing by 1 doesn't change a real number.
3) If the center, $c$ is desired to be the origin, that's the same as $<0,0>$ in vector form.
Using the above leads to $<0,0>=m_1<1,0>+m_2<-1,1>+m_3<-1,-1>$. Each vector has two components so we get a total of two equations from that, which isn't enough to have a unique solution if there are three variables but if we remember the extra information from the problem that $m_1+m_2+m_3=1$, we now have three equations and can solve for $m_1,m_2,m_3$.[/sp]
Solution (from Sudharaka): [sp]Substituting the relevant values for \(\displaystyle c = \frac{m_1}{m}v_1+\frac{m_2}{m}v_2+\frac{m_3}{m}v_3\) we get,
\[<0,0>=m_1<1,0>+m_2<-1,1>+m_3<-1,-1>\]
So we have the equations,
\[m_1-m_2-m_3=0~~~~~~~~~~~~~~(1)\]
\[m_2-m_3=0~~~~~~~~~~~(2)\]
\[m_1+m_2+m_3=1~~~~~~~~~~~~~(3)\]
Solving these equations we get,
\[m_1=\frac{1}{2},\,m_2=m_3=\frac{1}{4}\][/sp]
  • · Replies 29 ·
