Problem about equation solving
  • Thread starter Thread starter OcaliptusP
13 replies · 2K views
OcaliptusP
What is x ?( Assuming x and y are positive)
1000/x=3600 + (3600(y-x)+1000)/x+y
[/B]
Calculator gives it as x=5/36 but I cannot find a way to get that?
[/B]
Do you mean
$$ (1): \; \;\; \frac{1000}{x} = 3600 + \frac{3600(y-x) +1000}{x} + y$$
or do you mean
$$(2): \; \;\; \frac{1000}{x} = 3600 + \frac{3600(y-x) +1000}{x+ y}$$
In either case you have only one equation in two unknowns ##x## and ##y##, so there will generally be an infinite number of different solutions. For example, if you put ##y=0## you will get one solution ##x##, if you put ##y = 1000## you will get a different solution ##x##, and so forth. Are you sure you have not left out some important information?
Ray Vickson said:
In either case you have only one equation in two unknowns x and y, so there will generally be an infinite number of different solutions.
In general, yes.
But here we are given x and y both positive. (1) has no solutions, but (2) has only the given solution for x (y being indeterminate).
Just multiply it out and simplify. Post your working as far as you get.
Ray Vickson said:
Do you mean
or do you mean
It's the second one. I put it on the calculator and give the result as x=5/36?
haruspex said:
In general, yes.
I simplified until x/5=x/36y+ 1/36 but cannot get further
I asked you to post your working. It is wrong somewhere.
There is no y in the final equation.
Post your working so we can see where you went wrong.
Well starting equation was:
1000/x=3600+(3600(y-x)+1000)/(x+y)
Divide all 200
5/x=18+(18(y-x)+5)/(x+y)
Can be written as;
5/x=18+(18y-18x+5)/(x+y)
Multiply 18 with (x+y)/(x+y)
5/x=(18x+18y+18y-18x+5)/(x+y)
5/x=36y+5/(x+y)
Yes it was wrong as I noticed, I've sent my final work
Divide all 200
Can be written as;
5/x=36y+5/(x+y)
Continue to simplify. Multiply out.
Okay I've missed the detail. Thanks for all your help
If we continue
5x+5y= 36xy + 5x
Then x=5/36
Can you explain why do we need information of x and y is positive to derivate that?
No, my post#3 was a bit misleading there. That comment only appiled to the other interpretation of the equation given, i.e. (1) in Ray's post.
Okay. Thanks to everyone who helped.
