How Do You Calculate the Phase Constant φ from a Wave Displacement Graph?
  • Thread starter Thread starter jhans11
    Phi
To calculate the phase constant φ from a wave displacement graph, start with the wave equation y(x, t) = ym sin(kx - ωt + φ). The graph indicates that at t = 0 seconds, the displacement is +6 mm, which can be used as Y(x,t), while the maximum displacement (Ym) is 18 mm. To find φ, substitute these values into the equation and solve for φ, considering the sine function's properties. The discussion highlights the importance of knowing the wave's angular frequency (ω) and the wave number (k) for accurate calculations. Understanding these parameters is crucial for determining the phase constant effectively.
jhans11
Warning! Posting template must be used for homework questions.
1. The figure shows the displacement y versus time t of the point on a string at x = 0, as a wave passes through that point. The scale of the x axis is set by ys = 18.0 mm.The wave has form y(x, t) = ym sin (kx - ωt+φ). What is φ?
http://edugen.wileyplus.com/edugen/courses/crs7165/art/qb/qu/c16/pict_16_62.gif
2. y(x, t) = ym sin (- ωt+φ)3. reading off my graph, it crosses the Y axis at 6mm, i used that as my Y(x,t) and 18 as my Ym, but i have no idea how to get the time or omega
Your graph did not display.
At t = 0 seconds the displacement is +6 mm and you have ym.
  • · Replies 26 ·
  • · Replies 21 ·
