Problem for Theorem of Uniqueness
  • Thread starter Thread starter peace-Econ
    Theorem Uniqueness
The discussion revolves around determining the uniqueness of a solution for the initial value problem defined by the differential equation y' = y^(1/2) with the initial condition y(4) = 0. Participants are exploring the application of the theorem of uniqueness in this context.
  • Assumption checking, Conceptual clarification, Exploratory
  • Some participants discuss the continuity of the function and its partial derivative, questioning whether the conditions for the theorem of uniqueness are satisfied. Others suggest examining the integral for proof by contradiction and consider the implications of solving the general equation without initial conditions.
The discussion is ongoing, with participants offering different perspectives on the application of the theorem of uniqueness. There is a recognition that the continuity of the function is critical, and some participants express uncertainty about the validity of the approaches being discussed.
Participants note that the theorem requires continuity in a neighborhood around the initial value point, raising concerns about the inclusion of points where y <= 0, where the function is not continuous.
peace-Econ
Check if the given initial value problem has a unique solution
y'=y^(1/2), y(4)=0
f=y^(1/2) and its partial derivative 1/2(root of y) are continuous except where y<=0. We can take any rectangle R containing the initial value point (4,0). Then the hypothesis of theorem of uniqueness is satisfied.
I want to make sure if this way is correct. Some help please.
Thanks!
The usual way you tackle this kind of thing is proof by contradiction and examine the integral:
[tex] \int \left| \frac{dw}{dx}\right|^{2}dx[/tex]
where [itex]w=u-v[/itex] and u and v solve the original equation.
I think in this case though, you can solve the general equation (without using the iniitial/boundary condition) and show that it's solution depends upon a single parameter. That parameter is determined with the condition you were given.
Did you mean that my way and answer is wrong? This problem should be verified by using the theorem of uniqueness.
I got y(t)=(4x^2)-64. Then can i say that this is a unique solution?
As I don't know the theorem you're using I can't say either way.
sorry, you're right. The theorem I was trying to use is that if f and its partial derivative is continuous on the rectangle containing the given initial value problem, we can say that it has a unique theorem.
y'=y^(1/2), y(4)=0
It would help if you actually stated the theorem you are using. I suspect you are using
"The initial value problem y'= f(x,y), [itex]y(x_0)= y_0[/itex], has a unique solution in some neighborhood of the point [itex](x_0, y_0)[/itex] if both f(x,y) and [itex]f_y(x,y)[/itex] are continuous in some neighborhood of that point."
No, you cannot "take any rectangle R containing the initial value point (4, 0)" because that will necessarily include points where y<= 0, where the functions are NOT continuous.
Thanks!
