Problem involving irreducible element -Ring theory
  • Thread starter Thread starter chwala
    Element Theory
7 replies · 2K views · last reply
chwala
see attached...
Ring theory
Hey guys, i need insight on the highlighted part...the steps before this are quite clear:
Typeset page of number theory text with theorems 2.4.11 to 2.4.14 on irreducible elements, GCDs and the ring Z[sqrt(-2)], followed by a proof using Euclid's algorithm with norms; two red annotations mark the bound 3/4 M and the note that the argument fails for n = -3.
where is the ##\dfrac{3}{4}M ## coming from? and how to show the argument does not work for ##n=-3##? i should be able to check on this ...later.
and why is the Norm of say;
##ϒ =a+c\sqrt b##
taken as
##N(ϒ)=a^2-c^2b##
and not
##N(ϒ)=a^2+c^2b##?
cheers
In [itex]\mathbb{Q}[X : X^2 \in \mathbb{Q}] \supset \mathbb{Z}[X][/itex] we have [tex](a + bX)(a - bX) = a^2 - b^2X^2 \in \mathbb{Q}.[/tex] If this is zero, then we have either [itex]a + bX = 0[/itex] or [itex]a - bX = 0[/itex] and in either case [itex]a = b = 0[/itex]. Hence for [itex]a + bX \neq 0[/itex] we have [tex] (a +bX)^{-1} = \frac{a - bX}{a^2 - b^2X^2}.[/tex] Note that if [itex]X^2 = - N < 0[/itex], as in your case, then [tex] a^2 - b^2 X^2 = a^2 + Nb^2.[/tex]
chwala said:
Homework Statement:: see attached...
Relevant Equations:: Ring theory
##ϒ =a+c\sqrt b##
taken as
##N(ϒ)=a^2-c^2b##
and not
##N(ϒ)=a^2+c^2b##?
cheers
I am trying to follow this with a practical example...i still have doubts on the highlighted, let us consider; the gcd ##(7,4)## with ##n=-2## for example, then we shall have (using Euclid algorithm),
##7=1⋅4+3##
##\dfrac{7}{4}= \dfrac{7(l-m\sqrt{-2})}{l^2+2m^2}=\dfrac{7l}{l^2+2m^2}-\dfrac{m\sqrt{-2}}{l^2+2m^2}##
that is by following the attached literature... then
##\dfrac{t}{M}=\dfrac{7l}{l^2+2m^2}##
and
##\dfrac{s\sqrt{n}}{M}=\dfrac{m\sqrt{-2}}{l^2+2m^2}##
...let ##X, Y## be the closest integers to the two ratios on the right...not quite understanding this statement...do they mean ##X## an integer value i.e close to ##\dfrac{7l}{l^2+2m^2}## and ##Y## an integer value close to ##\dfrac{m\sqrt{-2}}{l^2+2m^2}##?
##7=1⋅4+3##
and
I think i now understand this part;
Typeset text: Now let X, Y be the integers closest to the two ratios on the right, that is |t/M - X| ≤ 1/2 and similarly for Y. Next set q = X + Y√n.
It basically means;##|\frac{t}{M} - X|≤\frac{1}{2}##
and
##|\frac{s\sqrt {n}}{M} - Y|≤\frac{1}{2}##
i.e
##-\frac{1}{2}≤\frac{t}{M} - X≤\frac{1}{2}##
and##-\frac{1}{2}≤\frac{s\sqrt{n}}{M} - Y≤\frac{1}{2}##
it is true that, (on adding them)
##0≤\frac{t}{M}+\frac{s\sqrt{n}}{M}- X-Y≤1##
where is the ##\dfrac{3}{4}M ## coming from? and how to show the argument does not work for ##n=-3##? i should be able to check on this ...later.cheers
The proof uses an arbitrary value for the integer, ##n##, through the point where
##\displaystyle N(r) \le M( (1/2)^2-(n)(1/2)^2)## .
Then substituting ##\displaystyle n=-2## one sees that ##\displaystyle M( (1/2)^2-(-2)(1/2)^2)=\dfrac{3}{4}M<N(b)## .
What do you get for ##n=-3## ?
##7=1⋅4+3##
and
This is not a particularly good example of two elements in ##\displaystyle \mathbb{Z} [\sqrt{-2\,} \,] ## .
Writing them as elements of ##\displaystyle \mathbb{Z} [\sqrt{-2\,} \,] ## , we have ##\displaystyle 7= 7+0\sqrt{-2\,}## , and ##\displaystyle 4= 4+0\sqrt{-2\,}##
So, we have ##l=4\,,\ m=0\,,\ \text{ and } M=16## .
This gives ##\displaystyle \dfrac{t}{M}=\dfrac{7l}{M}=\dfrac{28}{16}\, ,## which reduces to ##\displaystyle \dfrac 7 4 = 1.75## . And for ##\displaystyle \dfrac{s\sqrt{-2\,}}{M}## we have ##\displaystyle \dfrac{m\sqrt{-2\,}}{M}=0 ## .
Being the integer closest to ##1.75##, we have ##X=2## . It should be apparent that ##Y=0## . This gives ##\displaystyle q= X+Y\sqrt{-2\,}=2+0\,\sqrt{-2\,}=2##
Therefore, ##\displaystyle \ r = a-q\,b = 7-2\cdot 4 =-1##.
This is very similar to the standard version of Euclidean Division, except that here the remainder falls in the interval ##\displaystyle [-b/2 \,, \ b/2]\, ##. (The author should clean that up to make one of the ends of the interval be open.)
The Euclidean Algorithm goes further than this. The next step: Promote ##b## to take the role of ##a## and ##r## to take the role of ##b##, i.e. - divide ##4## by ##-1## find a quotient and a remainder.. If the remainder is zero, you are nearly (or half) done. If the new ##r\ne 0##, promote ##(b,\ r)## to ##(a,\ b)## and repeat . . . until some ##r=0## . The previous value of ##r## is the ##\gcd (a,\ b)## .
The final step in the Euclidean Algorithm has you backtrack through your previous steps to express the gdc as ##\displaystyle \gcd (a,\ b)=ua+vb ## for some ##u## and ##v##.
Thanks @SammyS ...i will go through your remarks later...cheers.
Am trying to substitute your values into the final inequality but it seems it does not satisfy unless i am not getting it correctly, since ##Y=0## then,
From this line,
##M\left[\dfrac{t}{M} - X\right]^2 ≤ M[(0.5)^2-n(0.5)^2] ≤ 0.75M##
given that, ##\dfrac{t}{M}=1.75##, ##M=16##, ##X=2##, ##n=-1## and ##m=0##.
We shall have
##16(1.75-2)^2 ≤16(0.25+0.25) ≤12##
##1≤8≤12##
Looks fine i had made a mistake on the value of ##X##. Next question suppose we had a value for ##m## how would that work out? Cheers.
Note
Author indicated that the argument works for ##n=-1,2,3## but not for ##n=-3##. I have verified this in the following step; When ##n=-3## we shall have,
##1≤16≤12##
which is a contradiction.
