Problem involving Negative Temperature
39 replies · 3K views
tanaygupta2000
Consider an isolated system of N>>1 distinct particles, each with possible energy states 0 and ε.
(1.) Give the range of energies for which the system has negative temperature.
(2.) If A and B are two subsystems of the given system, each having N/2 particles, and A having energy E(A) = Nε/8 and B having energy E(B) = 5Nε/8, which of these has positive/negative temperature?
(3.) The two systems are kept in thermal contact, what is the equilibrium temperature of two subsystems?
Population inversion, n(2)/n(1) = exp[-(ε2 - ε1)/kT]
n(1`) < N/2
The partition function of the given system is given by, Z = 1 + e(-ε/kT)
So in the '0' energy state, number of particles, n1 = [1/(1 + e(-ε/kT))]N
and in the 'ε' energy state, number of particles, n2 = [e(-ε/kT)/(1 + e(-ε/kT))]N
Now according to condition of population inversion, n1 < N/2
Upon substituting the values, I am simply getting e(-ε/kT) > 1
How am I supposed to find the 'range of energies for negative temperature'?
What are the possible values for the total energy if ##n_1 < N/2##?
If n1 < N/2
=> 1/(1 + e-ε/kT) < 1/2
=> e-ε/kT > 1
=> ε > 0
If n1 < N/2
=> e-ε/kT > 1
=> ε > 0
No.
You have to calculate the total energy of the ##N## particles.
DrClaude said:
No.
Total energy, E = n1ε1 + n2ε2
= e-ε/kt/(1 + e-ε/kT) × Nε
which is Nε/(1 + eε/kT)
There is no need to introduce temperature explicitly. You need to consider only that it is negative, and therefore that ##n_1 < N/2##.
Using ε > 0, I am getting total energy, E < Nε/2
It means that the energy of the upper level must be greater than (2/N) times the total energy E of the system.
Is this the answer of first part ?
Small edit: deleted "yes, but"
that is not the form of answer requested. Your answer should be a range of values of E in terms of N and ε
haruspex said:
Yes, but that is not the form of answer requested. Your answer should be a range of values of E in terms of N and ε
It means 0 < E < Nε/2
haruspex said:
How do you get that?
haruspex said:
You are forgetting that T<0.
Anyway, it is much simpler: you know n2>N/2 and you have E in terms of n2 and ε.
On applying n1 < N/2 < n2 and using E = n2ε = Nε/(1 + eε/kT)
I am getting 2ε/(1 + e-ε/kT) < ε < 2εe-ε/kT/(1 + e-ε/kT)
which becomes eε/kT < ε/2 < 1
You are making it far more complicated than it is. You need an inequality involving E, N and ε. Only. Don't involve T.
You were fine this far:
Sir I cannot obtain an inequality involving E, just as I cannot obtain for T, since both of them are not defined in the question.
The best I am getting from n1 < N/2 < n2 is -ε < 0 < ε.
The best I am getting from n1 < N/2 < n2 is 0 < ε < 0
N and ε are given. You are asked to find the range for the total energy. You were not given a label for that, but you have chosen to call it E. Therefore the answer should be a range for E in terms of N and ε.
0 < ε is uninteresting. It is necessarily true.
haruspex said:
You are still making it far too complicated and you should not have T in your answer.
Just use n1 < N/2 < n2 and E = n2ε, no other equations, to obtain an inequality relating only E, N and ε.
n1 < N/2 < n2
=> (N-n2) < N/2 < n2
Using E = n2ε => n2 = E/ε
=> N - E/ε < N/2 < E/ε
Adding (E/ε - N/2) all sides,
=> N/2 < E/ε < 2E/ε - N/2
=> Nε/2 < E < 2E - Nε/2
Is this correct?
Is this correct?
No. You can't have E on both sides of an inequality for E.
n1 < N/2 < n2
Sir was this approach correct for obtaining an inequality relating only E, N and ε ?
Yes, although it is not how I would set up the problem. Since ##E = n_2 \varepsilon##, I would write an inequality for ##n_2## and convert it for one for ##E##.
Sir how do I write an inequality for n2 starting from n1 < N/2 < n2 ?
Don't use ##n_1##, just set bounds on ##n_2##.
If I have to use just N/2 < n2
then N/2 < E/ε
=> Nε/2 < E < ∞
then N/2 < E/ε
=> Nε/2 < E < ∞
Ins't there an upper bound on ##n_2##?
N/2 < n2 < N
=> N/2 < E/ε < N
=> Nε/2 < E < Nε
N/2 < n2 < N
=> N/2 < E/ε < N
=> Nε/2 < E < Nε
Can I proceed with this solution ?
How do I solve the third part?
I know that for A, N/2 = [e(-5Nε/8kTA)/ {e(-5Nε/8kTA) + e(-Nε/8kTB)} ]N
and for B, N/2 = [e(-Nε/8kTB)/ {e(-5Nε/8kTA) + e(-Nε/8kTB)} ]N
how do I find the equilibrium temperature of these two ?
Do I have to first add TA and TB and then equate the derivative to zero?
