Problem regarding concave mirror
7 replies · 5K views · last reply
sankalpmittal
A point object at 15 cm from a concave mirror of radius of curvature 20 cm is made to oscillate along principal axis with amplitude 2 mm. Find the amplitude of its image.
Mirror formula :
1/v + 1/u = 1/f
Here u=-15 cm , f=-10
Differentiating above formula
dv/dt = -m2 du/dt
Where m= transverse magnification=-v/u
Ok I don't know if it's SHM or just another sort of oscillatory motion. Had it been SHM I would have solved it by putting maximum velocity = amplitude times angular frequency.
SHM: Simple harmonic motion.
My attempt :
1/v + 1/u = 1/f
u=-15 cm , f=-10
v=-30
Thus m=-v/u = -2
Thus
dv/dt = -4 du/dt
Now ?
Please help !
Thanks in advance...
:smile:
Tedius solution method (ignore unless totally stuck):
[STRIKE]What is the range of (i.e. maximum and minimum) object distances for the object, as it is oscillating? That should help get you started.[/STRIKE]
Quicker solution method:
sankalpmittal said:
dv/dt = -4 du/dt
So what would dv/du be?
Maybe quick (I doubt that), but certainly wrong, this would be an approximation for small amplitudes. The amplitude is not large, but there is no reason to use an approximation here.
That's the right approach.
You don't need velocities, or details of the motion. Just the maximal and minimal distance.
Thanks a lot mfb and Radbelly. I got the answer.
However here Radbelly's hint had worked.
Hello sankalpmittal
Is 8mm the correct answer ?
Vibhor said:
Hello sankalpmittal
Yup. Well if you are jee aspirant I will advise you not to study from scattered sources.
