Problem relating to skateboarding down a ramp
  • Thread starter Thread starter marcus1255
    Ramp
The discussion centers on calculating the height of a ramp for a skater rolling down at a 35-degree angle, with a 4-foot drop to level ground. The skater's initial speed is 3.0 m/s, and the maximum allowable speed is converted to 11 m/s. The solution involves applying the conservation of energy principle, where potential energy at the top equals kinetic energy at the bottom. The calculated height of the ramp is approximately 5.6 meters, confirming the use of energy equations without the need for mass in the calculations.
  • Understanding of conservation of energy principles
  • Familiarity with potential and kinetic energy equations
  • Basic trigonometry for ramp angle calculations
  • Ability to convert units (e.g., km/h to m/s)
  • Study the conservation of mechanical energy in physics
  • Learn how to apply energy equations in real-world scenarios
  • Explore the effects of ramp angles on projectile motion
  • Investigate the relationship between speed, height, and distance in jumps
This discussion is beneficial for physics students, educators, and anyone interested in understanding the mechanics of motion and energy conservation in practical applications like skateboarding.
marcus1255
here is the problem:
skater is to roll down a ramp with a 35 degree angle from horiziontal. the ramp then levels off to horizontal, with a 4 foot drop to level ground. the winner is the skater who can jump the furthest after leaving the ramp. your task is to determine the height of the starting gate at the top of the ramp. the typical skater pushes off from start at a speed of 3.0 m/s. for safety reasons, a skaters speed should never exceed 40 km/hour. Don't take friction or air resistance into account.
I converted the 40 km/hr to 11 m/s. I then drew out a rough sketch of what this whole thing would look like, but now i am at a loss of what to do next.
You have a pretty good start! That 11 m/s is the key number.
I think you can do it with energy, and fairly simply because no energy is lost. Looks like the skater has potential and kinetic energy at the top and just kinetic at the bottom. If you write that out in symbols and put in the known numbers, you will be able to solve for the height.
Can I just plug anything in for the mass? There is no mass given in the problem and I believe that I need one to calculate potential energy.
I solved it. Thanks for the advice!
I got a height of 5.6 meters. Does that sound about right?
Yes, sounds good. The question is just a little unclear - do we have the limit of 11 m/s at ground level or at the 4 foot level? Anyway, about 5.7 m above whatever it is. Did you cancel the m's like this:
½mv² + mgh = ½mV²
½v² + gh = ½V²
16K
35K
