Problem with function approximation
  • Context: Undergrad
  • Thread starter Thread starter boniphacy
    Approximation Function
12 replies · 2K views
boniphacy
We have a function:
## f(x,y)=\sqrt{\frac{1−2x}{1−y^2}} = \frac{\sqrt{1−2x}}{\sqrt{1−y^2}}##
for small x and y, we can use standard approximations:
## 1/\sqrt{1−x}=1+x/2+... ##
and
##\sqrt{1−x}=1−x/2−... ##
Ok. Now we can approximate the whole function f(x,y)
First method:
## \sqrt{\frac{1−2x}{1−y^2}}≈\sqrt{(1−2x)(1+y^2)}=1−x+y^2/2−xy^2 ##
Second method:
##\frac{\sqrt{1−2x}}{\sqrt{1−y^2}}≈(1−x)(1+y^2/2)=1−x+y^2/2−xy^2/2 ##
the both approx. are not equal, difference is: ##xy^2/2 ##!
So, which approximation is the correct one?
boniphacy said:
We have a function:
and
First method:
Second method:
What about putting some small values for ##x## and ##y## into a calculator?
Even worse, if x and y are equally small, you've thrown out at least a ##x^2## term that is more important than the ##xy^2## term.
You took two first order approximations, and then you tried to assume you had a good second order approximation at the end. As you learned, that's not guaranteed to work.
boniphacy said:
OK. We assume x ~ y^2, then: what is correct now?
I'd say they are both wrong, as you have a cross term in ##xy^2##, but no terms in ##x^2## or ##y^4##, which should be of the same order.
PS Perhaps the first one is more wrong than the second one!
for x = y it is:
## \sqrt{\frac{1-2x}{1-x^2}} \approx 1 - x^2 - x^3 - x^4/2 + ... ##
so, the first looks is correct.
now try: y^2 = x
## \sqrt{\frac{1-2x}{1-x}} \approx 1 - x/2 - 5/8 x^2 + ... ##
fantastic.
I think the point we are really trying to get across is, if you want to use the ##xy^2## term then you need to include more terms in each of your original approximations.
Like ##\sqrt{1-x}\approx 1-x/2-x^2/8## instead of just taking the first term.
This is forbidden. We can use the first terms only.
This function is used in the GR fantastic theory, exactly:
## E = mc^2 \frac{\sqrt{1-2GM/c^2r}}{\sqrt{1 - (r'^2 + h^2/r^2)/c^2}} ##
boniphacy said:
for x = y it is:
now try: y^2 = x
This makes no sense. The original approximation doesn't have any terms involving y, so how can you replace x with ##y^2## or ##y^2## with x, or whatever it is that you're doing?
The original question had a y in the denominator...
A first order approximation cannot give a good second order term. It might produce something that looks like a second order term but it's just meaningless. Use second order approximations if you want a useful second order term.
OK.
what is correct approximation of this equation, up to second order?
## E = mc^2 + mr'^2/2 + mh^2/2r^2 - mGM/r + the second order term ##
we can see 'the first order part' is perfectly Newtonian version.
