Problem with Gravitation inside the Earth
  • Thread starter Thread starter xnitexlitex
    Earth Gravitation
To determine how deep a mine shaft must be for gravitational acceleration to decrease by a factor of five, the relationship between gravitational force and depth must be understood. The equation g = r(GME/RE^3) is central to this problem, where r represents the distance from the Earth's center. The discussion emphasizes the need to consider the mass of the Earth below the shaft, assuming uniform density, which simplifies calculations. Participants clarify the derivation of the gravitational acceleration formula and suggest methods to eliminate constants like G and ME for easier computation. Ultimately, the key takeaway is that the gravitational force decreases with depth due to the reduced mass of Earth acting on the object.
xnitexlitex
How deep would a mine shaft have to be for the gravitational acceleration at the bottom to be reduced by a factor of 5 from its value on the Earth's surface?
g=r(GME/RE3)
G = 6.67 * 10-11
ME = 5.97 * 1024 kg
RE = 6.38 * 106 m
I set g/5 equal to the equation g=r(GME/RE3). I got it wrong. I also tried dividing the result by 5, and it still didn't work. What else am I supposed to do?
That should work. First simplify the equation to show g(r) in terms of g at the Earth's surface. (You shouldn't have to use G or ME.)
You have to take into account that the mass of the Earth below you is less. You'll probably want to assume that the Earth is of uniform density to to that.
Do you see how?
Good point, Fewmet. However, how would I calculate the mass below if I don't know the depth?
The equation he has assumes just that. It assumes the Earth is of uniform density.
hmm... I hastily read g=r(GME/RE3) as g=GME/RE2. My mistake.
I don't immediately see where g=r(GME/RE3) comes from. Is r depth or the radius of the Earth beneath you when you are at depth?
I assume the derivation involves g=GME/RE2. I was thinking that assumes a point mass rather than a uniform density of the planet. (Sorry if that seems like quibbling.)
xnitexlitex:
My reply was in the context of approaching the problem as though you were standing on a smaller planet when down in the mine shaft. You are closer to the center of the Earth and are being attracted by a lesser mass. If you are at depth d, your are at radius RE-d, the mass is ρ(4/3)∏(RE-d)3.
Alternatively, you could subtract the mass of the outer shell (whose thickness is d).
While you don't know d, it is the only unknown in g=GME/RE2.
Looking again at g=r(GME/RE3), doesn't that tell you that acceleration is g/5 at r/5?
As I said, I do not know what r represents, so I do not know how helpful that observation is.
r is the distance from the center of the Earth.
The final answer involves g, but that answer is derived assuming a uniform density.
Let r = the distance from the Earth's center and then derive the effective g(r). You'll get the equation this thread started with.
Doc Al said:
...You'll get the equation this thread started with.
Cool. I've got the derivation now. Thanks for taking time to sketch that out.
I'd long known that the g increased linearly with distance from the center of the Earth, but only as a qualitative piece of information. I hope my clumsy approach hasn't robbed xnitexlitex of the joy of discovering that.
I'm glad that you figured out the derivation, but it still isn't helping.
You could go with Doc Al's original suggestion and eliminate G and ME in
g=r(GME/RE3)
using
g=GME/RE2
If that doesn't make clear how to proceed, go back to what I said in the seventh post in this strand (which probably gives it away too easily). If not, post again to let us know.
Why not just work out the mass of Earth below you when you at r from the centre (using volume and density) and then work out the gravitational force from that mass at distance r ( using G and mass).
It all falls out very nicely and gives a laughably simple answer.
Show exactly what you plugged in where. Even if you didn't simplify the expression as I suggested, it should still work just fine. Realize that the formula gives you r, the distance from the Earth's center; you then have to use that to calculate the depth below the surface.
  • · Replies 23 ·
  • · Replies 18 ·
