Problem With Maximum Acceleration up Hill
The problem involves a cross-country skier attempting to accelerate uphill on a slope inclined at 5º. The skier relies solely on her skis for propulsion, with given coefficients of static and kinetic friction. The objective is to determine the maximum possible uphill acceleration.
  • Participants discuss the skier's ability to accelerate uphill without using ski poles, questioning the mechanics of propulsion through static friction. There are attempts to clarify the role of the normal force and the distribution of weight on the skis.
The discussion is ongoing, with some participants suggesting corrections to the original poster's calculations and assumptions regarding the normal force and friction. There is a focus on understanding the forces at play rather than reaching a conclusion.
Participants note potential errors in geometry and trigonometry related to the normal force calculation, and there is an emphasis on the assumptions regarding the skier's weight distribution across the skis.
olski1
Problem With Maximum Acceleration up Hill!
cross-country skier is going up a slope at angle 5º to the horizontal. She is skating so only her skis provide the propulsion (i.e. she does not push with her ski poles). The static and kinetic friction coefficients for this situation are μs = 0.12, μk = 0.07 respectively.
Find the magnitude of her maximum possible uphill acceleration?
Fnet=MA
So Far:
Fnet(x)= F(static) - F(kinetic) - Fg = ma
Fnet(x) = (0.12 x m x 9.8cos85) - (0.07 x m x 9.8cos85) - (9.8cos85 x m) = ma
Divide by m you get:
Fnet(x) = (0.12 x 9.8cos85) - (0.07 x 9.8cos85) - 9.8cos85 = a
Therefore a= - 0.81m/s^2
But this gives me a negative accelleration, Where did I go wrong? as it asks for the Max acceleration up the hill and that acceleration would point down hill.
HELP PLEASE!
How can she possibly accelerate uphill?
She uses her skis to push against the ground which propells her forward through static friction.
I thought the question said "i.e. she does not push with her ski poles".
she DOES NOT use her poles, but she DOES use her skis - the same way people ice skate
Please do not double post.
https://www.physicsforums.com/showthread.php?t=386703
You should first correct your geometry/trig/normal force calculation errors. Friction is a function of the normal force. The normal force is not mgcos85; what should it be?
Then, once you make your correction for the normal force equation, you must make certain assumptions about the distribution of the skiers weight ...that all of it is one one ski as she pushes back against the snow, causing static friction to propel her forward, while the gravity component downhill (which you have calculated correctly) is at the same time working against her. But what about the sliding friction on the other ski..what's the normal force on the other ski with all her weight initially shifted to the 'propelling' ski??
13K
  • · Replies 37 ·
