Problem with Merge Sort Alg Implementation
  • Context: Java
  • Thread starter Thread starter zak100
    Sort
3 replies · 2K views
zak100
Hi,
I am trying to implement merge Sort Alg in Java. I am not getting any error but its not printing sorted list . can some body please guide me? My code is:
Java:
import javax.swing.*;
public class MergeAlg2{
   static int[ ] arr={2, 4, 5, 7, 1, 3, 6, 8};
   int [ ] L;
   int [ ] R;
   void merge(int [ ] arr, int p, int q, int r){
      int n1 = q- p +1;
      int n2 = r-q;
      L = new int[n1+1];
      R = new int[n2+1];
      int i=0;
      int j=0;
      for(  i=0;  i< n1; ++i)
         L[I] = arr[p +i -1];
      for(j=0; j<n2; ++j)
         R[j] = arr[q+j];
      L[n1] =100000;
      R[n2]= 100000;
      i=0;
      j=0;
      int k=0;
      for(k=p-1; k<r; ++k){
         if(L[ i ] <= R[j]){
            arr[k] = L[ i ];
           i++;
         else{
            arr[k] = R[j];
            j++;
   void merge_sort(int[ ] a, int left, int right){
      int i=0;
      String str="";
      if(left <right) {
         JOptionPane.showMessageDialog(null," Enters left = " + left  + "right= " + right );
         int center = (left + right)/2;
         merge_sort(a, left, center);
         merge_sort(a, center + 1, right);
         merge(a, left, center, right);
       for(i=0; i<=7; ++i){
         str= str + a[ i ];
      JOptionPane.showMessageDialog(null, "Sorted List is" + str);
   public static void main(String[ ] args){
      MergeAlg2 obj = new MergeAlg2();
      obj.merge_sort(arr, 1,8);
      int i=0;
      String str="";
         str= str + arr[ i ];
      JOptionPane.showMessageDialog(null, str);
My initial list is: {2, 4, 5, 7, 1, 3, 6, 8};
But after sorting i am getting: 2, 3, 4, 5, 6, 7, 1, 8
Zulfi.
It would be helpful if you would use the code tags so your code would be readable.
Have you tried stepping through your code via a debugger or using print statements?
Look at where the sort makes a decision and decide if that's what it should do.
The first thing you need to do is decide what the p,q,r parameters mean and then follow that decision throughout your code.
Since your use is somewhat unintuitive, you may need to add comments such as
Java:
//first chunk:  a[p-1] to a[q-1]
//second chunk: a[q] to a[r]
You may want to change the arguments p,q,r so that the first call would become
Java:
mergesort(arr, 0, 8)
and the split would be
Java:
mergesort(a, left, center)
mergesort(a, center, right)
