Problem with substitution in a difference equation
9 replies · 2K views · last reply
jwxie
Verify that the response of the system governed by the 1st order different equation
[itex]y(k)=bu(k)+ay(k-1)[/itex]
is given by this solution
[itex]y(k)=\frac{b}{1+a}\left [ (-1)^{k}+a^{k+1} \right ][/itex]
for u(k) = (-1)^k
The solution said we can verify this by substitution. I didn't get how we jump to the second step
(sub)
[itex]\frac{b}{1+a}\left [ (-1)^{k}+a^{k+1} \right ]-\frac{ab}{1+a}\left [ (-1)^{k}+a^{k} \right ][/itex]
2nd step
[itex]\frac{b(-1)^{k}[1+a]}{(1+a)}+\frac{ba^{k}(a-a)}{1+a}[/itex]
How did we get the top (1+a) in the first term, and the (a-a) in the second term?
Thank you.
There has to be an error.
Was the first step supposed to be [itex]y(k)-ay(k-1)[/itex]? This would either have been
[tex]\frac{b}{1+a}[(-1)^k+a^{k+1}] + \frac{ab}{1+a}[(-1)^{k}+a^{k}][/tex]
or
[tex]\frac{b}{1+a}[(-1)^k+a^{k+1}] - \frac{ab}{1+a}[(-1)^{k-1}+a^{k}][/tex].
(Notice the power of the second (-1) term.)
Hi Thompson, yes the first step is indeed to rewrite the difference equation in the standard form, which is y(k) - ay(k-1)
Thanks.
Unsure if this proof is correct
I completed this proof in the attachment but can someone please check my working
The aim was to show that the height of P above floor after the crate is tilted is h(cosb+2sinb)
From the rectangles you can work out
Length of OP=h√5
sin(a)=1/√5
cos(a)=2/√5
therefore
height=h√5.sin(a+b)
=h√5.(sinacosb+cosasinb)
=h√5.(1/√5cosb+2/√5sinb)
=h(cosb+2sinb)
  • Hand-drawn diagram of a rectangle with corner O at bottom left, corner P at top right, sides labelled 2h and h, and angle a between diagonal OP and the base; beside it a tilted rectangle resting on a horizontal line at O, with corner P at top and angle b marked at O.
Yes, that's perfectly correct!:smile:
But why did you open a new thread for this?
(I'm merging the two threads.)
Hmmm.. excuse me? What is this proof all about?
LOOOL
how is this relevant to my difference equation problem?
anyone? still haven't figure it out yet. Thanks, and sorry for the bump.
Darn it! The first expression I posted had an error! It should be
[tex] \frac{b}{1+a}[(-1)^k+a^{k+1}] + \frac{ab}{1+a}[(-1)^{k}-a^{k}][/tex]
Sorry about that. I'm new to doing math via computer, and usually make silly errors.
These two threads were apparently merged by mistake- okay, so let's take the first form of [itex]y(k)-a(yk-1)[/itex] that I posted
multiply out the terms in the numerators..
[tex] \frac{b(-1)^k +ba^{k+1}}{1+a} + \frac{ab(-1)^{k}-ba^{k+1}}{1+a}[/tex]
then simply group the terms appropriately. In the reduced form you posted (the second step) they got
[itex] \frac{b(-1)^{k}[1+a]}{(1+a)}+\frac{ba^{k}(a-a)}{1+a}[/itex]
from grouping terms immediately instead of expanding the numerators, but you can do it either way.
It's also important for you to see where
[tex] <br /> \frac{b}{1+a}[(-1)^k+a^{k+1}] + \frac{ab}{1+a}[(-1)^{k}-a^{k}]<br /> [/tex]
comes from.
[tex] y(k)-ay(k-1)=\frac{b}{1+a}[(-1)^k+a^{k+1}] - \frac{ab}{1+a}[(-1)^{k-1}+a^{k}][/tex]
[tex]= \frac{b}{1+a}[(-1)^k+a^{k+1}] - \frac{ab}{1+a}[\frac{(-1)^{k}}{(-1)}-(-a^{k})][/tex]
[tex]= \frac{b}{1+a}[(-1)^k+a^{k+1}] -(-1)\frac{ab}{1+a}[(-1)^{k}+(-a^{k})][/tex]
Does that make sense?
hey JThompson, thank you very much. Your explanations are very clear. Thanks!
