Problems with Paper on QM Foundations
  • Level: Undergrad
  • Thread starter Thread starter bhobba
    Foundations Paper Qm
90 replies · 13K views
A. Neumaier said:
Moreover, starting from a physical Hilbert space, one does not recover the same Hilbert space by contracting several projective measurements, concatenating the resulting quantum instruments, and constructing the ancilla for the resulting POVM. Thus the construction is physically spurious.
I don't really understand what you are saying here. Can you elaborate a bit, or give a reference where this is explained in more detail?
vanhees71 said:
... demonstrated by the clear observation of the violation of Bell's inequalities, which are predicted for local deterministic hidden-variable theories. Of course one way out might be a nonlocal deterministic hidden-variable theory, but I haven't seen any convincing one yet, at least not taking into account relativity.
For a non-local theory, taking into account relativity means accepting a preferred frame. For SR this is simply going back to the pre-Minkowski interpretation used by Lorentz and Poincare. How to generalize this to gravity is also known, that's Schmelzer's generalized Lorentz ether.
Once a preferred frame is accepted as unproblematic, the remaining question is the choice of the configuration space. Here, a standard reference is
Bohm.D., Hiley, B.J., Kaloyerou, P.N. (1987). An ontological basis for the quantum theory, Phys. Reports 144(6), 321-375
The field ontology for the bosons I find convincing. The standard relativistic field-theoretic Langrangian can be used, so that relativistic effects are not a problem at all.
I believe that @vanhees71 thinks that it's obviously wrong, despite the fact that it makes the same measurable predictions as the standard Einstein-Minkowski interpretation of SR.
I lost the thread, what you are referring to, but you said above that the Bohmian reinterpretation of QED is gauge dependent and thus acausal, i.e., it is intrinsically inconsistent. Violating a local gauge symmetry makes the corresponding QFT always intrinsically inconsistent, and of course that's a serious flaw. Pauli would have said "it's not even wrong".
You misunderstood what I said. Bohmian QED consists of a two set of equations. One set is standard QED written down in a fixed Lorenz gauge, that's something what physicists like you do every day and there is nothing inconsistent with it, despite the mathematical acausality of the ##A^0## field. The second set of equations, which are the Bohmian field evolution equations, that's something that standard QED has nothing to say about.
There is no acausality in standard QED, no matter which gauge you choose, and that's the key point. Everything observable like S-matrix elements are gauge invariant and do not contain any "contamination" of the unphysical degrees of freedom. That follows from the Ward-Takahashi identities which are a direct consequence of gauge invariance, and they hold order by order in perturbation theory ("loop expansion").
If these Bohmian field evolution equations are acausal they cannot have any physical relevance, because they cannot refer to observables.
So the difference between Bohmian mechanics in 1st-quantized non-relativistic QM and this Bohmian field theory seems to be that the former just adds unobservable elements (the particle trajectories) to the theoretical picture but it is still mathematically consistent while the latter contradicts fundamental properties like causality and thus is inconsistent already as a theory.
You assume that only observables (self-adjoint operators) can be physical, which is true in standard quantum theory, but does not need to be true in any conceivable theory.
vanhees71 said:
... contradicts fundamental properties like causality and thus is inconsistent already as a theory.
Newtonian gravity is a counterexample, which is acausal (in the sense you mean it) and consistent as a theory. If property A is fundamental, it does not imply that negation of A is inconsistent.
That's the point. In Newtonian physics causality is not a strong restriction, and instantaneous actions at a distance are consistent with the space-time structure. That's why Bohmian mechanics is consistent within Newtonian physics.
The challenge for Bohmian physics or any other approach to nonlocal hidden variable theories within relativistic physics is to obey still causality. The solution in classical relativistic physics is the field picture to make the interactions local and fulfill causality. It still seems to be a problem to find non-local but causal dynamics within relativistic physics.
Here you assume that relativity must be a fundamental principle obeyed by everything. But we don't know that with certainty. Maybe it's true, maybe it's not. So far experiments found no counterexample, but it doesn't imply that they never will. In principle it's possible that relativity is emergent rather than fundamental, but you don't accept that even as a possibility.
Well yes, but then you Bohmian field theory should provide testable predictions, contradicting the principles of relativity, and then experiment has to decide. Then it would be a new theory making predictions contradicting standard local QFT, which obeys the principles of relativity.
  • Love
Yes, and that's exactly what in "BM for instrumentalists" I propose. More specifically, I suggest that future collider experiments (with energies higher than currently available) might see signs of Lorentz-invariance violation.
  • Wow
bhobba said:
I was on you-tube and saw a video from Oxford on QM foundations. I didn't agree with it, but that is not an issue - I disagree with a lot of interpretational stuff. The video mentioned a paper they thought essential reading:
https://www.mathematik.uni-muenchen.de/~bohmmech/BohmHome/files/three_measurement_problems.pdf
Is it me, or has the author not shown the appropriate care? In particular, they claim theories that violate 1a are hidden variable theories. I thought - what - how does that follow. It may simply mean nature is fundamentally probabilistic. Or, in other words, the three assumptions are not inconsistent.
Specifically, I do not think the following is logically justified:
'And since we are interested in individual cats and detectors and electrons since it is a plain physical fact that some individual cats are alive and some dead, some individual detectors point to "UP" and some to "DOWN", a complete physics, which is able at least to describe and represent these physical facts, must have more to it than ensemble wave-functions.'
My response is - that might be your idea of what compete physics is, but it might be best not to assume that is everyone's idea of complete physics. Einstein, of course, thought QM incomplete, but I am not sure that is necessarily why.
Thanks
Bill
Isn't it one reason why Einstein thought QM is incomplete? It is one reason Schrödinger had problems with QM as we know from his famous paper. We also know Schrödinger and Einstein corresponded and that Einstein used a similar argument (it isn't clear to me who used it first). Einstein spoke of "bombs" instead of atomic decay and dead cats if I recall. We also have the EPR paper and writings of his to understand other (related) reasons why Einstein thought QM to be incomplete. But there can be more than one reason Einstein thought QM to be incomplete.
Maudlin defines what what he means by "complete" in the very sentence you quote and I can't find where he claims or implies that this is "everyone's idea of complete physics". It doesn't really matter in my opinion. Do you agree that if you define completeness in Maudlin's sense, then QM is incomplete? *
ETA:
Better yet...is QM incomplete in Maudlin's sense? There are people who use the word 'complete' in the same way and definitions don't come from On High.
Minnesota Joe said:
ETA: Better yet...is QM incomplete in Maudlin's sense? There are people who use the word 'complete' in the same way and definitions don't come from On High.
I think the discussion has answered my query. It has to do with what I was taking complete to mean and what Maudlin was. On that basis, I could close the thread but will leave it open if others have thoughts on the issue.
Thanks
Bill
What acausality of the ##A^0## field in the Lorenz gauge? It gives ##\square A^\mu = j^\mu## for all components, thus, looks quite causal. ##A^0## is acausal in other popular gauges. But in the Lorenz gauge?
There is no acausality in the Lorenz gauge, but Lorenz gauge is not a completely fixed gauge. Coulomb gauge, for instance, is completely fixed and can be thought of as a special case of Lorenz gauge.
Ok. But why would BM need a completely fixed gauge? It needs a well-defined evolution equation, anf it needs a potential because else the interaction cannot be defined. But it does not have the positivist prejudices against unobservables, thus, does not have to get rid of unobservables completely. As long as they follow a well-defined evolution equation (which they do in the Lorenz gauge) everything is fine.
No manifest covariance is required, thus, the artificial Gupta-Bleuler approach with an indefinite metric is not necessary. And if already in the large space the metric is definite, there are also no problems with unitarity. Gribov copies? Ok, they may lead to some differences in the predictions. But I would bet they have not been distinguished by experiments.
Ah, you missed the context. The context is my lecture in which I used Coulomb gauge in classical (not Bohmian!) electromagnetism to demonstrate that you may violate Lorenz invariance at the ontic level without violating Lorenz invariance at the measurable level.
Thanks
Bill
Okay, thanks. This is an older paper of Maudlin's and I'd not read it before, so thank you for the link also.
Joe
There's no need for ##A^{\mu}## to be "causal", because it's not observable. What must be causal is the gauge-invariant electromagnetic field ##F_{\mu \nu}## which always is causal ("retarded solutions"), no matter in which gauge you calculate the potentials ##A^{\mu}##.
Fine that you accept this.
First of all, it follows that you accept that such non-observable things like potentials have a place in physics, even if they are non-observable. Field theory with ##A^{\mu}## is much much simpler than field theory with ##F_{\mu \nu}## given that there is not even a reasonable Lagrangian for the interaction with a Dirac field using the ##F_{\mu \nu}##.
The more problematic question is about their reality. The ##F_{\mu \nu}##, or whatever defines them, are real, given that they have observable consequences. But are the ##A^{\mu}## real? Positivists have problems with this. Realists not. They know and accept that realist theories are hypotheses and will remain hypotheses forever, that we cannot prove them, only falsify them. So, what is real is, as part of a realist theory, hypothetical too. Some criteria for preference are obvious: Simplicity, Ockham's razor. Giving reality to the ##A^{\mu}## gives much simpler realist theories than accepting only the ##F_{\mu \nu}## as real.
What are then the equations for the ##A^{\mu}##? They have to explain the equations for the ##F_{\mu \nu}## which we can test in a much better way given observations. So we have simplicity and explanatory power as unproblematic guiding principles. If the ##F_{\mu \nu}## follow well-defined evolution equations with Lorentz symmetry, the simplest explanation would be that the ##A^{\mu}## follow such equations too. This would be ##\square A^{\mu}=0##. Why would a realist consider some more complicate realist theory? Don't complicate things without necessity.
What is, therefore, behind the "no need for ##A^{\mu}## to be "causal"? It is good old empiricism - the wish to derive the theories of physics from observations. We obviously cannot derive the equation ##\square A^{\mu}=0## from observation, given that there are a lot of other imaginable equations for the ##A^{\mu}## which give the same Maxwell equations for ##F_{\mu \nu}##. So, ##\square A^{\mu}=0## cannot be part of a theory based on empiricism.
Why shouldn't I accept the electromagnetic potentials?
I've never denied this.
I don't use the word "real" anymore in discussions about Q(F)T, because I don't know its meaning anymore.
For sure ##A^{\mu}(x)## do NOT represent observables. They don't obey the microcausality principle and are not gauge invariant. Even within classical electrodynamics they don't represent observables directly. All observables must be gauge invariant in both the classical as well as in the quantized theory.
The equations of motion for the ##A^{\mu}## are of course gauge-dependent too. The ##F_{\mu \nu}## as gauge invariant fields are indeed the natural building blocks for local observables (fulfilling also the microcausality condition).
You need the ##A^{\mu}## to formulate QED as a manifestly local QFT. Particularly you need a four-vector to have the usual transformation properties under Poincare transformations.
Read your own quotations given below.
It is quite easy: It is what a realist theory defines as the ontology. If it does not define an ontology, it is not a realist theory.
Hm. They are not observables, about reality you refuse to speak, so what they are? Sort of something magical like "imaginary numbers" in the mind of Musil's Törless? Not real, not observable, only imaginable or so?
In the Lorenz gauge they would follow a local equation ##\square A^{\mu}=j^{\mu}## classically, so I would expect that microcausality would not be a problem too, not?
The other problem is why are you so sure? Our QFTs are effective theories, and it follows essentially automatically that their symmetries may appear approximate symmetries. Approximate symmetries play an important role in QFT too, what is the problem of only approximately gauge invariant gauge fields?
Except that Bohm Aharonov shows that not all observables can be computed locally from the ##F_{\mu \nu}##.
Except that the theory with the ##A^{\mu}## in the standard BRST approach is not even a quantum theory, but a physically meaningless mathematical exercise in an indefinite Hilbert space.
I know, but all these words have no clear meaning. I want to discuss physics not gibberish.
The electromagnetic potentials are calculational tools. They don't represent observables directly but enable you to define operators that represent observables. That's standard textbook QFT.
In classical physics microcausality doesn't make sense. Of course in the Lorenz gauge you get the wave equation for the potentials and you can choose the retarded potentials, and you can choose the retarded solutions. This alone doesn't imply that they are directly observable. They are not but the electromagnetic field ##F_{\mu \nu}=\partial_{\mu} A_{\nu}-\partial_{\nu} A_{\mu}## is.
If you break gauge invariance, no matter how weakly, the entire theory becomes inconsistent. A gauge symmetry (in contradistinction to global symmetries) means that you use more degrees of freedom in your mathematical description than physical degrees of freedom. If you break gauge invariance the non-physical degrees of freedom become interacting, and fundamental features of QFT as a physical theory are violated, including the unitarity of the S-matrix, microcausality, Poincare invariance etc.
Sunil said:
Except that Bohm Aharonov shows that not all observables can be computed locally from the ##F_{\mu \nu}##.Except that the theory with the ##A^{\mu}## in the standard BRST approach is not even a quantum theory, but a physically meaningless mathematical exercise in an indefinite Hilbert space.
I have no clue what you want to say with this statement.
I am not advocating Bohmian mechanicsm in any way, but I do agree with this point.
This is an important point and a special case of the question of observer equivalence vs observer democracy. What may be fundamental, could be democracy - not equivalence. The equivalence may well be emergent only, is the sense of an evolutionary steady state. Allowing oneself to relax fundamental things, and instead focus on observer democracy may add explanatory value to why the effective equivalence is observed, but also why they aren't perfect. It's like a "noise" at the level of physical law, but it need not be a bad thing.
I even think that anyone that thinks about the logical arguments of which relativity builds, may find that the observer democracy condition is most certainly more obvious, but a weaker conditions than equivalence. The equivalence condition is handy, but may simply be wrong. (I obviously think it is, but one does not have to buy into something I think to at least see that it's a logical possibility that is perfectly rational and sound)
/Fredrik
No, the meaning is very clear. A realistic theory has to define an ontology. If it has a Lagrange formalism, the ontology of the system is defined by the trajectory in the configuration space ##q(t)\in Q## of the theory, in the Hamilton formalism by the trajectory in the phase space. And so on. These are quite well-defined things. If philosophers talk about realism and reality in a theory-independent sense, the result may be confusion, but the same holds for everything they talk about.
In other words, they have no status at all. A "calculational tool" can be things with no relation to the theory at all.
No. The Gupta-Bleuler formalism, resp. BRST quantization, which starts with a physically nonsensical indefinite Hilbert space for the ##A^\mu## fields, breaks down. One would have to start with real fields ##A^\mu##, and without exact gauge symmetry they would plausibly be observable. So, they should be handled in the mathematical formalism like usual observables. That means, they have to live in a well-defined (not indefinite) Hilbert space. This automatically clarifies problems with unitarity. You don't have to consider a factorization of some indefinite Hilbert space which may fail, but have to start from a definite Hilbert space. This gives some QFT. If gauge symmetry is approximate, then plausibly relativistic symmetry is approximate too, thus, causality will go back to classical causality in a preferred frame (which will be only approximately unobservable), and Poincare invariance will be only approximate too. No problem with QFT as a consistent physical theory.
What I mean with the reference to the Bohm-Aharonov effect should be clear even from Wiki-Level information https://en.wikipedia.org/wiki/Aharonov–Bohm_effect which claims "The Aharonov–Bohm effect shows that the local E and B fields do not contain full information about the electromagnetic field, and the electromagnetic four-potential, (Φ, A), must be used instead. By Stokes' theorem, the magnitude of the Aharonov–Bohm effect can be calculated using the electromagnetic fields alone, or using the four-potential alone. But when using just the electromagnetic fields, the effect depends on the field values in a region from which the test particle is excluded."
Where do you disagree with "Except that the theory with the ##A^\mu## in the standard BRST approach is not even a quantum theory, but a physically meaningless mathematical exercise in an indefinite Hilbert space."? In BRST, you start with an indefinite Hilbert space where the ##A^\mu## are defined, not? Together with the ##A^\mu##, which is IYO only a "calculational tool", this part of the BRST approach can be nothing more serious than a "calculational tool" too. In particular, it cannot be a quantum theory, because Hilbert spaces in QT are always Hilbert spaces and have a definite scalar product, and they have to have it because negative probabilities make no sense.
martinbn said:
@Sunil What does it mean for ##A^\mu##(or anything else) to be real?
To be described by a realistic theory which we can reasonably believe that it is true (that means, in particular, not falsified yet, but other criteria count here too) as part of the ontology of that theory.
In a theory with Lagrange formalism the ontology of the system is described by the trajectory in the configuration space Q ##q(t)\in Q##. What actually exists is, then, ##q(t_0)## together with some (usually one is sufficient) derivatives ##\dot{q}(t_0)##, the other parts of the trajectory define what existed at some time in the past and what will exist in some time in the future.
So, for the classical field theory, the configuration space trajectory is defined by ##A^\mu(x,t)##. In a realist interpretation of quantum theory, like Bohmian field theory, it means that the Bohmian trajectory will be ##A^\mu(x,t)##.
It is not necessary that the ##A^\mu(x,t)## are fundamental objects. Chairs are also real, that means only that they consist of things which are real.
vanhees71 said:
For me the issue is solved with the results of all the high-precision Bell tests.
We have different perspectives, but IMO, Bells inequality is not the key anymore I think. Bells theorem is clear, but the ansatz is makes on equipartitioning has no place in how I understand things these days anway. It's good to kill of the original, old times objections to QM. But I see more modernt objections, where Bells theorem does not help.
But as Neumaier said, the main issue seems to be the point of view here. But I think from the perspectives of multiple observers, both perspective makes sense, but the confusion arises when one simply assymes that the perspectives ought to be equivalent, or that one is right and the other one is wrong.
If one instead embraces that different observers (agents, not humans!) makes their own independent inferences(given their respective resources of information processing), and that the difference inferences are correlated or dependeng depends to the extent of mutual interaction, then one can merge the two views. Ie. there can be, from one agents view, hidden information that one could call "real". But it is also true that this hidden information is not inferrable to all other agents, this is exactly what the external agent can NOT make the equipartion ansatz in Bells theorem, and make predictions based on averaging the hidden variable. This is because the hidden variable is not intrinsic to the external observer!
For me this is not a contradiction! This is paradoxally why I, while superficially at the opposite camp of Bohmian mechanics, connect and symphatize with Demystifiers solipsist HV idea. I keep bringing this up, as I think it's more fruitful to find commmon denominators where we can agree, than to focus on all the things we can argue forever in circles about.
So in a nutshell, I think what some call solipsist views, is paradoxally the best way to save "reality", while escaping the Bell argument, and without requiring other pathological mechanism that violates locality etc. The soluton is that reality is real, but hidden, but not in the naive sense of "ignorance" because this assume the interacting nearby agents are informed about each other, but in the sense of beeeing non-inferrable. Ie. it's not possible to construct the measurements required to get the answers. And in an agent view, agents actions are independent of such things, this is why the ansatz in bells theorem does not hold.
1A - is then wrong, just like the future is never COMPLETELY determined by the past. It never gets better than a best inference.
1B - This is problematic as one first has to by the same standards, analyse how the hamiltonian is inferred! We know how it's done for atomic physics, but try to do it for cosmology; or scale the theory of the lab down to the agent-perspective of a proton, and you should find the same principal problem.
1C - if one, as Demystifiers suggests, takes determiate to mean ontic, and we allow the ontolgoy to be agent-relative, then not all agents at all scales, CAN share the same ontology. But I take it to mean that the say, local or "nearby observer" is the ontologt that would represent some sortof naked ontologt. All other ontolgoies are screened with layers of more or less complex inferences.
/Fredrik
Nobody has yet made clear to me, what a clear definition of "ontology" is. I don't care for philosophy. Physics is about well defined observable objective facts. There are no trajectories in phase space in quantum mechanics or quantum field theory.
These are all mathematical formulations of the theory, which also clearly defines what is representing observables, e.g., S-matrix elements in "vacuum QFT", thermodynamical quantities for different kinds of media with there different phases in many-body situations (quark-gluon plasma, neutron stars, usual matter around us), transport coefficients, etc.
If gauge symmetry is not exact, the model doesn't make physical sense. There can be approximate global symmetries like chiral symmetry of QCD in the light-quark sector, which make physical sense, but if a local gauge symmetry is broken in any way, it doesn't make any sense anymore. This has nothing to do with Poincare invariance. You can have, e.g., non-relativistic QED or QCD, which is an approximation to the relativistic theory which is consistent and provides well-defined descriptions of observables, but as soon as the underlying local gauge symmetry is broken, it doesn't make any sense anymore. If you know the BRST formalism or Gupta Bleuler for QED, then this should be immediately clear!
That's wrong. What's observed in the AB effect is a non-integrable phase factor, which depends however on a gauge-invariant quantity only, i.e., the flux of the magnetic field through a surface intersecting the solenoid,
$$\Phi_B=\int_{A} \mathrm{d}^2 \vec{f} \cdot \vec{B} = \int_{\partial A} \mathrm{d} \vec{x} \cdot \vec{A}.$$
It's an integral over the vector potential along a closed path, and this is gauge invariant. There are no gauge-dependent observables. This was a contractio in adjecto!
The entire point of the BRST approach is to evaluate well-defined observables in a well-defined Hilbert space from a gauge theory, which by definition deals with a description with contains non-physical unobservable elements in the description. You introduce ghost fields. For an un-higgsed gauge symmetry these are the Faddeev-Popov ghost fields taylored such that in a given gauge-fixing the contributions of unphysical degrees of freedom of the gauge potentials ##A_{\mu}^a## to observables quantities are always precisely canceled by the contributions from the ghost fields. That makes that each "gluon" is described by 4 vector-field degrees of freedom, of which two are unphysical, and the contributions of the two unphysical fields to observable quantities is canceled by a corresponding contribution from the correponding two also unphysical degrees of freedom of the ghost fields.
For a higgsed gauge symmetry in non-unitary (e.g., the manifestly renormalizable ##R_{\xi}## gauges invented by 't Hooft) you have in addition also unphysical "would-be-Goldstone fields". For each Higgsed subgroup of the gauge group you have in addition to the Faddev-Popov ghosts a corresponding would-be-Goldstone ghost which together with the unphysical degrees of freedom of the corresponding gauge potential conspire such that only the physical degrees of freedom of the gauge field contribute to the S-matrix, and these are three field-degrees of freedom corresponding to the three polarization states of a massive vector boson. Since the S-matrix is gauge invariant you can take the limit to the unitary gauge, which shows that there are no Goldstone modes for any higgsed local gauge symmetry but massive gauge bosons instead.
