Problems with Psi4 installation
25 replies · 6K views · last reply
Lotto
TL;DR
I can't install Psi4 on my Windows 10.
I wanted to install Psi4 on my Windows 10. Downloading itself was without any problem, but then, when I clicked on a downloaded .exe file, this occurred:
Windows error dialog titled NSIS Error with a red X icon, reading: Installer integrity check has failed. Common causes include incomplete download and damaged media. Contact the installer's author to obtain a new copy. An OK button.
Eventually, I overcame the problem by using Command Prompt and then the installation started. But at its end, this occurred:
Windows installer dialog for Psi4conda 1.6.1 (64-bit) showing a green progress bar at Creating Psi4conda menus, with a warning box reading Failed to initialize Anaconda directories and Abort, Retry and Ignore buttons.
I know it can be caused by a name of destination folder, but I tried everything I could and the problem persists. I don't have any Python or something like that on my PC. When I chose "Install for all users", then it didn't work at all. I tried to download the .exe file again, even an older version, but it was in vain. Do you have any ideas how to fix the problem?
I think you need to clean out all references to anaconda and redownload the package. Cleaning up anaconda install, you may need to search for how to do that as it may have installed registry keys and in other directories besides its own.
I am a little concerned that the exe is malware so you should do a google search to see if others have run across a similar problem.
Well, I don't think it is a malware, since it is a file from the official Psi4 website. Moreover, when I ran an antivirus test, nothing was found.
But it is true that my antivirus programme warns me against this programme, but that is because it is from an unknown source.
jedishrfu said:
Heres the Psi4 install instructions for windows and it says to install anaconda first.
https://psicode.org/posts/psi4education_setup/
Is this what you are trying to do?
I tried that when I had Anaconda on my PC, but the result was the same. Now I have Anaconda removed (I removed everything that had something to do with it).
I installed Anaconda3 and used this command: conda install psi4 python=3.8 -c psi4 -c conda-forge (that is from here https://psicode.org/installs/v17/). I suppose that Psi4 should install now, but it doesn't completely work, since this occurred:
Anaconda Prompt window showing a conda package download list, with several packages at 100% and python-3.8.15 stalled at 47%, followed by repeated CondaSSLError messages about decryption failing or a bad record MAC.
So it started to install, but then this error happened. I had had similar SSL error before, but that should be already fixed. But this error I can't fix. What should I do?
I don't think I can be of much help here, but for the sake of others who might be able to help, the screen shot you posted is too small to read. It would be helpful if you could copy the text of the error messages, and then post that stuff directly in your post, rather than as an image.
I have recently had several sites that will not connect due to SSL incompatibility. One of those is an e-mail account that requires advertisement display from a 3rd party before allowing access.
There must be a "New-And-Improved" SSL level that some sites insist on using exclusively. :cry:
Anyone have a solution?
Ok, so this is the whole report:
Code:
(base) C:\Users\Beda>conda activate p4env
(p4env) C:\Users\Beda>conda config --set ssl_verify false
(p4env) C:\Users\Beda> conda install psi4 python=3.8 -c psi4 -c conda-forge
Collecting package metadata (current_repodata.json): done
Solving environment: failed with initial frozen solve. Retrying with flexible solve.
Solving environment: failed with repodata from current_repodata.json, will retry with next repodata source.
Collecting package metadata (repodata.json): done
Solving environment: done==> WARNING: A newer version of conda exists. <==
  current version: 22.9.0
  latest version: 23.1.0
Please update conda by running
    $ conda update -n base -c defaults condaWARNING conda.gateways.disk.delete:unlink_or_rename_to_trash(143): Could not remove or rename C:\Users\Beda\anaconda3\pkgs\libint2-2.6.0-h2e52968_4.tar.bz2.  Please remove this file manually (you may need to reboot to free file handles)
WARNING conda.gateways.disk.delete:unlink_or_rename_to_trash(143): Could not remove or rename C:\Users\Beda\anaconda3\pkgs\libxc-5.2.3-py38h91455d4_2.tar.bz2.  Please remove this file manually (you may need to reboot to free file handles)
WARNING conda.gateways.disk.delete:unlink_or_rename_to_trash(143): Could not remove or rename C:\Users\Beda\anaconda3\pkgs\psi4-1.7+6ce35a5-py38_0.tar.bz2.  Please remove this file manually (you may need to reboot to free file handles)
## Package Plan ##
  environment location: C:\Users\Beda\anaconda3\envs\p4env
  added / updated specs:
    - psi4
    - python=3.8The following packages will be downloaded:
    package                    |            build
    libint2-2.6.0              |       h2e52968_4        69.1 MB  psi4
    libxc-5.2.3                |   py38h91455d4_2        30.4 MB  conda-forge
    mkl-2019.1                 |              144        99.8 MB
    psi4-1.7+6ce35a5           |           py38_0        67.0 MB  psi4
    python-3.8.15              |h4de0772_1_cpython        15.5 MB  conda-forge
                                           Total:       281.9 MB
The following NEW packages will be INSTALLED:
  attrs              conda-forge/noarch::attrs-22.2.0-pyh71513ae_0 None
  bzip2              conda-forge/win-64::bzip2-1.0.8-h8ffe710_4 None
  ca-certificates    conda-forge/win-64::ca-certificates-2022.12.7-h5b45459_0 None
  cffi               conda-forge/win-64::cffi-1.15.1-py38h57701bc_3 None
  colorama           conda-forge/noarch::colorama-0.4.6-pyhd8ed1ab_0 None
  dftd3-python       conda-forge/win-64::dftd3-python-0.6.0-py38heb50f4f_1 None
  exceptiongroup     conda-forge/noarch::exceptiongroup-1.1.0-pyhd8ed1ab_0 None
  gau2grid           conda-forge/win-64::gau2grid-2.0.7-hcb41399_1 None
  gcp-correction     conda-forge/win-64::gcp-correction-2.3.1-ha368592_2 None
  importlib-metadata conda-forge/noarch::importlib-metadata-6.0.0-pyha770c72_0 None
  importlib_metadata conda-forge/noarch::importlib_metadata-6.0.0-hd8ed1ab_0 None
  importlib_resourc~ conda-forge/noarch::importlib_resources-5.10.2-pyhd8ed1ab_0 None
  iniconfig          conda-forge/noarch::iniconfig-2.0.0-pyhd8ed1ab_0 None
  intel-openmp       pkgs/main/win-64::intel-openmp-2019.1-144 None
  libblas            conda-forge/win-64::libblas-3.8.0-8_mkl None
  libcblas           conda-forge/win-64::libcblas-3.8.0-8_mkl None
  libffi             conda-forge/win-64::libffi-3.4.2-h8ffe710_5 None
  libint2            psi4/win-64::libint2-2.6.0-h2e52968_4 None
  liblapack          conda-forge/win-64::liblapack-3.8.0-8_mkl None
  libsqlite          conda-forge/win-64::libsqlite-3.40.0-hcfcfb64_0 None
  libxc              conda-forge/win-64::libxc-5.2.3-py38h91455d4_2 None
  libzlib            conda-forge/win-64::libzlib-1.2.13-hcfcfb64_4 None
  m2w64-gcc-libgfor~ conda-forge/win-64::m2w64-gcc-libgfortran-5.3.0-6 None
  m2w64-gcc-libs     conda-forge/win-64::m2w64-gcc-libs-5.3.0-7 None
  m2w64-gcc-libs-co~ conda-forge/win-64::m2w64-gcc-libs-core-5.3.0-7 None
  m2w64-gmp          conda-forge/win-64::m2w64-gmp-6.1.0-2 None
  m2w64-libwinpthre~ conda-forge/win-64::m2w64-libwinpthread-git-5.0.0.4634.697f757-2 None
  mctc-lib           conda-forge/win-64::mctc-lib-0.3.1-hd5c7e75_0 None
  mkl                pkgs/main/win-64::mkl-2019.1-144 None
  msgpack-python     conda-forge/win-64::msgpack-python-1.0.4-py38hb1fd069_1 None
  msys2-conda-epoch  conda-forge/win-64::msys2-conda-epoch-20160418-1 None
  networkx           conda-forge/noarch::networkx-3.0-pyhd8ed1ab_0 None
  numpy              conda-forge/win-64::numpy-1.22.4-py38h1d2777f_0 None
  openssl            conda-forge/win-64::eek:penssl-3.0.7-hcfcfb64_2 None
  optking            psi4/noarch::eek:ptking-0.2.1-pyhbc12335_1 None
  packaging          conda-forge/noarch::packaging-23.0-pyhd8ed1ab_0 None
  pint               psi4/noarch::pint-0.17-pyhd8ed1ab_0 None
  pip                conda-forge/noarch::pip-22.3.1-pyhd8ed1ab_0 None
  pluggy             conda-forge/noarch::pluggy-1.0.0-pyhd8ed1ab_5 None
  psi4               psi4/win-64::psi4-1.7+6ce35a5-py38_0 None
  psutil             conda-forge/win-64::psutil-5.9.4-py38h91455d4_0 None
  py-cpuinfo         conda-forge/noarch::py-cpuinfo-9.0.0-pyhd8ed1ab_0 None
  pycparser          conda-forge/noarch::pycparser-2.21-pyhd8ed1ab_0 None
  pydantic           conda-forge/win-64::pydantic-1.10.4-py38h91455d4_1 None
  pytest             conda-forge/noarch::pytest-7.2.1-pyhd8ed1ab_0 None
  python             conda-forge/win-64::python-3.8.15-h4de0772_1_cpython None
  python_abi         conda-forge/win-64::python_abi-3.8-3_cp38 None
  pyyaml             conda-forge/win-64::pyyaml-6.0-py38h91455d4_5 None
  qcelemental        psi4/noarch::qcelemental-0.25.1-pyhd8ed1ab_1 None
  qcengine           psi4/noarch::qcengine-0.26.0-pyhd8ed1ab_0 None
  scipy              conda-forge/win-64::scipy-1.8.1-py38h9bf8e03_0 None
  setuptools         conda-forge/noarch::setuptools-66.1.1-pyhd8ed1ab_0 None
  simple-dftd3       conda-forge/win-64::simple-dftd3-0.6.0-hd5c7e75_0 None
  tk                 conda-forge/win-64::tk-8.6.12-h8ffe710_0 None
  toml-f             conda-forge/win-64::toml-f-0.2.3-hd5c7e75_0 None
  tomli              conda-forge/noarch::tomli-2.0.1-pyhd8ed1ab_0 None
  typing-extensions  conda-forge/noarch::typing-extensions-4.4.0-hd8ed1ab_0 None
  typing_extensions  conda-forge/noarch::typing_extensions-4.4.0-pyha770c72_0 None
  ucrt               conda-forge/win-64::ucrt-10.0.22621.0-h57928b3_0 None
  vc                 conda-forge/win-64::vc-14.3-hb6edc58_10 None
  vs2015_runtime     conda-forge/win-64::vs2015_runtime-14.34.31931-h4c5c07a_10 None
  wheel              conda-forge/noarch::wheel-0.38.4-pyhd8ed1ab_0 None
  xz                 conda-forge/win-64::xz-5.2.6-h8d14728_0 None
  yaml               conda-forge/win-64::yaml-0.2.5-h8ffe710_2 None
  zipp               conda-forge/noarch::zipp-3.12.0-pyhd8ed1ab_0 NoneProceed ([y]/n)? yDownloading and Extracting Packages
mkl-2019.1           | 99.8 MB   | ################################################################################################################################################################################################# | 100%
psi4-1.7+6ce35a5     | 67.0 MB   |        |   0% WARNING conda.gateways.disk.delete:unlink_or_rename_to_trash(143): Could not remove or rename C:\Users\Beda\anaconda3\pkgs\psi4-1.7+6ce35a5-py38_0\Lib\share\psi4\basis\dgauss-dzvp-autoabs.gbs.  Please remove this file manually (you may need to reboot to free file handles)
libint2-2.6.0        | 69.1 MB   |        |   0% WARNING conda.gateways.disk.delete:unlink_or_rename_to_trash(143): Could not remove or rename C:\Users\Beda\anaconda3\pkgs\libint2-2.6.0-h2e52968_4\lib\int2-cxx.lib.  Please remove this file manually (you may need to reboot to free file handles)
python-3.8.15        | 15.5 MB   | ####################################################8        |  27%
libxc-5.2.3          | 30.4 MB   | ##############################################################################7        |  41% WARNING conda.gateways.disk.delete:unlink_or_rename_to_trash(143): Could not remove or rename C:\Users\Beda\anaconda3\pkgs\libxc-5.2.3-py38h91455d4_2\Library\bin\xc.dll.  Please remove this file manually (you may need to reboot to free file handles)
libxc-5.2.3          | 30.4 MB   | #################################################################################        |  42%
InvalidArchiveError("Error with archive C:\\Users\\Beda\\anaconda3\\pkgs\\psi4-1.7+6ce35a5-py38_0.tar.bz2.  You probably need to delete and re-download or re-create this file.  Message from libarchive was:\n\nfailed with error: [Errno 13] Permission denied: 'C:\\\\Users\\\\Beda\\\\anaconda3\\\\pkgs\\\\psi4-1.7+6ce35a5-py38_0\\\\Lib\\\\share\\\\psi4\\\\basis\\\\dgauss-dzvp-autoabs.gbs'")
CondaSSLError: Encountered an SSL error. Most likely a certificate verification issue.
Exception: [SSL: DECRYPTION_FAILED_OR_BAD_RECORD_MAC] decryption failed or bad record mac (_ssl.c:2633)
I deleted that files above, but then it occurred again. So what should I do?
jedishrfu said:
Did you turn off the ssl flag and try it again?
I suppose I did, these were my first three steps:
Or am I to do it differently?
jedishrfu said:
You could use conda to check if its set by listing the environment because it seems the error still occurred during install
And how to do it? When I do "conda env list" I see only my environment with a star.
Check your .condarc file. The url link I gave mentions that for setting this flag.
They also mention locating your ssl certificate and the setting the ssl_verify path.
In the .condarc file is it ok, I have there ssl_verify false.
I don't know how to do this, where am I to find that ssl certificate?
I don't think this is anything to do with SSL certificates (not any more, anyway). It is due to the installation process being unable to delete files, probably because they are locked by a crashed process.
Lotto said:
Code:
In my experience installing Python packages in Windows is a nightmare and I gave up years ago: I do serious Python work in a Linux virtual machine. It may be it works better in WSL but I haven't tried that approach.
Then show us the error report after "deleting that files above".
Well, unfortunately, that "WARNING" occurred only twice, now only this below occures. I installed OpenSSL, checked, that when I open .condarc, I have there "ssl_verify: false". But nothing works. I don't understand it, for the first time, it shows report above, and now it shows this report.
And installation via .exe doesn't work either.
Code:
## Package Plan ##
    - psi4
    package                    |            build
    libcblas-3.8.0             |            8_mkl         3.5 MB  conda-forge
    numpy-1.22.4               |   py38h1d2777f_0         6.1 MB  conda-forge
    scipy-1.8.1                |   py38h9bf8e03_0        27.3 MB  conda-forge
                                           Total:       318.9 MB
  zipp               conda-forge/noarch::zipp-3.12.0-pyhd8ed1ab_0Proceed ([y]/n)? yDownloading and Extracting PackagesCancelledError()
CancelledError()
@Lotto You really need to use code tags while posting output from the terminal. To do this, click on the icon below:
Toolbar of a forum text editor with bold, italic, color, code, list, alignment, image, emoji, subscript, superscript, link and undo buttons; the inline code button </> is circled in red.
paste your code, select a programming language (in this case, none), and click on Continue. Alternatively, append [CODE]...[/CODE] tags before and at the end of the code block section.
Yes. @Lotto -- the Mentors have been inserting code tags for you in your longer posts in this thread, but please do it for yourself from now on using the tip from @Wrichik Basu
Thank you.
  • Haha
This is really weird. Every day occures different reports
Code:
Solving environment: -
Found conflicts! Looking for incompatible packages.
This can take several minutes.  Press CTRL-C to abort.
failed
UnsatisfiableError: The following specifications were found to be incompatible with each other:
Output in format: Requested package -> Available versions
Package python conflicts for:
python=3.8
psi4 -> msgpack-python -> python[version='>=2.7,<2.8.0a0|>=3.10,<3.11.0a0|>=3.7,<3.8.0a0|>=3.8,<3.9.0a0|>=3.9,<3.10.0a0|>=3.6,<3.7.0a0|>=3.5,<3.6.0a0|>=3.8|>=3.7|>=3.6|>=3.5|>=3.6.0']
psi4 -> python=3.8
Ok, I tried that on my father's notebook and there it works, so I give up installing Psi4 on my PC, it seems to be a hard problem. But I can use the program there at least.
When you get a version mismatch you can either upgrade or downgrade things. In this case, it looks like you may need to downgrade your python to get it to work or install python 3.7 along with python 3.8 if possible.
I recall conda may allow multiple python environments.
