Prof. Verschure's thin section collection from the Fen and Hor localities
180 replies · 64K views
Next sample:
Tinguaite. Altered phonolite (QAPF field 11), Fen complex. Trachytic groundmass of sanidine laths, aegerine needles, and small aggregates of anhedral granular mineral, likely muscovite/paragonite secondary to groundmass nepheline.
Small phenocrysts of biotite, large phenocrysts of sanidine, often partially altered into natrolite and large blocky phenocrysts of what was likely nepheline, now pseudomorphically altered into disordered microscopic anhedral aggregations of presumably the same mineral (biotite or paragonite) as the groundmass as well as the altered nepheline found in samples Fen 248, 249, and 250; unfortunately, definitive identification is not possible.
AI coughed up the following- keep in mind that the pre-existing country rock, Telemark gniess, has significantly less Aluminum and significantly more Sodium compared to the rest of the rocks on earth, so the gneiss is classified as “peralkaline”. Within the Fen complex, due to the ijolite/carbonatite intrusions, the Fen rocks are usually classified as “silica-undersaturated peralkaline”.
“The alteration of sanidine into natrolite is a hydrothermal process, typically occurring within silica-undersaturated volcanic rocks like phonolites or nepheline syenites. While sanidine itself is a high-temperature potassium-sodium feldspar, its alteration to natrolite—a hydrated sodium-aluminum silicate zeolite—represents a low-temperature, secondary, or "deuteric" alteration event.”
Altered Phonolite (QAPF field 11), Fen complex. Groundmass primarily consists of trachtytic sanidine laths and aggregates of anhedral grains of a mineral, likely cancrinite replacing groundmass nepheline. In addition, minor amounts of aegirine needles, and opaques are present.
Blocky rectangular and hexagonal nepheline phenocrysts have pseudomorphically altered into cancrinite, and sanidine phenocrysts have a dusty/perthic appearance. In some places, the sanidine has partially altered into small elongated anhedral grains of (likely) orthoclase and in other, sanidine phenocrysts have partially altered to microcline.
(Along the right side is the edge of the sample.)
It’s unclear if enough aegirine is present to classify this rock as a Tinguaite.
Image triplet: In the center of the field of view, a pair of diamond-shaped titanite crystals, partially oxidized to ilmenite, leucoxene, and calcite. At bottom, carbonate (probably calcite) and titanite (with some ilmenite opaques) have pseudomorphically replaced a mineral with cleavage pattern similar to biotite, but I can’t identify the original mineral.
“Cancrinite commonly forms as a secondary alteration product of nepheline in alkaline-rich igneous rocks, such as nepheline syenites, typically through low-temperature hydrothermal processes or subsolidus reactions. This alteration occurs via the interaction of nepheline with CO2- and alkali-rich fluids. The transformation, which occurs in the presence of water, involves the addition of Ca, Na and carbonate to the nepheline structure. The alteration typically occurs in the subsolidus range, with hydrothermal fluids (often around 400 - 500°C or lower) supplying the necessary components."
Next up:
Altered Tinguaite/Phonolite (QAPF field 11), Fen complex. This rock has an appearance very similar to Fen 252. Trachytic groundmass of sanidine laths, aegerine needles, and small aggregates of anhedral granular mineral, likely paragonite replacing groundmass nepheline.
Small phenocrysts of biotite with opaques (either magnetite or ilmenite), large phenocrysts of sanidine, some with Baveno twinning, often partially altered into natrolite, and large blocky phenocrysts of what was likely nepheline, now pseudomorphically altered into disordered microscopic anhedral aggregations of presumably the same mineral (paragonite) as the altered nepheline found in samples Fen 248, 249, and 250; unfortunately, definitive identification (by me) is not (currently) possible.
“The alteration of nepheline into paragonite represents a metamorphic or hydrothermal process, often occurring in Na-rich alkaline environments. Paragonite, a sodium-rich mica, forms from nepheline through hydration and silica uptake, often during the alteration stage of nepheline syenites or related pegmatites”
Next up:
Altered Tinguaite/Phonolite (QAPF field 11), Fen complex. Similar appearance as Fen 253. Blocky phenocrysts of cancrinite, likely as pseudomorphic altered nepheline. Phenocrysts of sanidine heavily altered (dusty appearance, perthic texture). Groundmass is disordered, consisting of agglomerated anhedral cancritine grains, both laths and anhedral grains of feldspar, and irregularly shaped grains of green aegirine. What would typically be aegirine needles instead have a highly degraded/corroded appearance, unclear if this rock would be classified as a Tinguaite.
Above image pair: upper right corner is dusty (PP) sanidine; lower right corner is cancritine (pseudomorphic altered nepheline); groundmass is (approximately) along the the left half of the frame, and in between cancritine and groundmass, a thin layer of anhedral grains of calcite. Within the groundmass, grain of blue mineral is either fluorite, lazurite, or haüyne.
Large isotropic grain, likely sodalite:
Several “phenocrysts” consisting of a distinct outer shell (dark hematite and feldspar laths, mostly dusty in PP) surrounding an interior region, consisting of a mixture of calcite and needle-like aragonite (a polymorph of calcite):
Red-brown “smoke”, likely hematite:
Thin veinlet of unknown mineral- possibly hematite, here traversing cancrinite; a zone of calcite surrounds the veinlet.
Isotropic blue mineral is either fluorite, lazurite, or haüyne.
Also present in the sample when viewed through epi-darkfield: purple-ish ilmenite; some crystals of titanate have pseudomorphically altered to ilmenite. Silvery rhomboids and truncated hexagons of magnetite.
I have to admit that lately, with each successive sample, I am having increasing difficulty identifying all of the minerals present.
Altered Tinguaite/Phonolite (QAPF field 11), Fen complex. This complex rock could be classified as Tinguaite due to the presence of trachytic aegirine needles in the groundmass. Groundmass is a trachytic mix of aegirine, K-feldpsar, and rounded agglomerations of a granular mineral, likely replacing nepheline:
Trachytic/Trachytoid sanidine phenocrysts have completely pseudomorphed into natrolite and blocky nepheline phenocrysts have pseudomorphed into a complex ‘birds-eye’ arrangement of mesocratic fibrous mineral exhibiting low-to-mind 2nd birefringence colors (amphibole?) interspersed with numerous irregular inclusions, each consisting of a rim of fine-grained opaques surrounding a clear, moderately birefringent mineral (quartz?). In epi-darkfield, all these minerals appear as highly scattering (white):
Numerous thin veinlets present, many with a corona. Next set of images: a thin velinlet traverses natrolite (altered sanidine). Veinlet interior is primarily high-relief crystallites (too small to use for birefringence) surrounded by altered natrolite. In a section of the veinlet interior, the vein is filled with an opaque; in epi-darkfield, the yellow-orange-red color of the large opaque identifies itself as either hematite or goethite, around which are sprinkled small dark magnetite crystals.
In epi-darkfield, another veinlet appears as a hematite-enclosed ‘tube’ filled with minerals of unknown identity, but very similar in appearance to the groundmass:
Scattered occurrences of an anhedral blue-purple grain mineral, identity is either fluorite, lazurite, or Haüyne (sodalite group). Some sort of intrusion traverses the sample from bottom to top that consists of intermittent slender, curving pheno-/xenocrysts, unclear what composition. Small isolated phenocrysts of dark green pyroxene, often twinned:
Tinguaite/Altered foid-bearing trachyte (QAPF field 6b), Fen complex. Brownish smears on 1:1 image are artifacts (dirty slide) and not part of sample.
This rock could be classified as Tinguaite due to the presence of aegirine needles in the groundmass, but the needles, being randomly oriented, don’t really have the characteristic trachytic texture.
Plagioclase and quartz are absent, and importantly, groundmass nepheline (altered or not) is absent as well. The relative lack of nepheline phenocrysts and lack of groundmass nepheline means this rock may not be a phonolite (QAPF field 11), but rather a foid-bearing trachyte (QAPF field 6b).
Large sanidine phenocrysts mostly altered to natrolite.
The few blocky nepheline pseudomorphs appear similar to other samples, for example No. 252. Also present: small isolated phenocrysts of augite, some with distinct cores.
Small veinlet, likely hematite.
Next image pair: within the groundmass, an agglomeration of fine-grained opaques is revealed in epi-darkfield to be a mixture of ilmenite (dark purplish to my defective eyes) and a highly backscattering (white) mineral, possibly leucoxene (a hydrothermal alteration product of ilmenite).
Altered tinguaite/rhomb porphyry (foid-bearing alkali-feldspar trachyte, QAPF zone 6b), Fen complex. Classified as trachyte due to lack of quartz, plagioclase, and near-lack of nepheline (or any other foid). Nepheline is only a minor component of the rock, a few small (lightly) altered phenocrysts, not present in groundmass. Densely packed needles of aegirine are present but the characteristic trachytic texture is absent (the needles are all randomly oriented), so this rock may not be classified as a Tinguaite.
Nepheline is mostly unaltered but in places partially replaced by cancrinite. Image triplet: Triangular phenocryst of nepheline (partially altered to cancrinite) within groundmass of aegirine and K-feldpsar. Within the phenocryst are small opaque inclusions, most showing octahedral habit, likely indicating magnetite.
Sanidine is fully altered into natrolite. At least one of the sanidine phenocrysts is filled with oriented needle-like inclusions forming, in the aggregate, a banded texture.
A few dark green phenocrysts of hornblende. Large opaque, surrounded by aegirine aggregates, is a complex mix of grey magnetite, red hematite, inclusions of sphene (based on the habit), and the purple mineral fluorite/lazurite/haüyne.
“The alteration of nepheline to cancrinite often occurs under subsolidus, hydrothermal conditions, where alkaline solutions react with early-formed nepheline. Cancrinite develops as a replacement mineral within and in the immediate vicinity of nepheline crystals in nepheline-bearing pegmatites, syenites, and related igneous rocks. The process is sometimes accompanied by the formation of other minerals like calcite or sodalite”
Transition rock between phonolite (left) and country rock (Telemark gneiss). The gneiss could either be a megacryst or the true chilled margin. Because this magmatic intrusion is not from a carbonatite magma, the gneiss is not fenitized.
Below: Within the gneiss, K-feldspar (dusty in PP due to sericite inclusions) with clear albitized borders (especially the lower left grain) and quartz grains with undulose extinction. In center and upper right, two complex fractured assemblages of carbonate (likely calcite) and (I think) quartz surrounded by a large assembly of interdigitated grains, I think of metasomatic quartz.
Magmatic component has sanidine phenocrysts, some with Baveno twinning.
Groundmass consists of trachytic needle-thin laths of sanidine on a background of fine-grained greenish crystallites (possibly aegirine).
Biotite pseudomorphed into chlorite. Multiple thin veinlets of (likely) hematite are also present.
Pyrite (brassy yellow) with pyrrhotite (bronze to reddish) alteration border.
“Pyrite alters into pyrrhotite primarily through thermal decomposition, metamorphism, or reduction, occurring when pyrite loses sulfur at temperatures typically over 300- 500 C. This desulfidation process is common in metamorphic rock formation, volcanic environments, and high-temperature reductive settings.
Since I will be sans interweb for a few days, this week's post is a bit early.
Alkali-Feldspar Trachyte (QAPF field 6), Fen complex.
I mentioned previously that the remaining Fen rock samples are more complex and I no longer have reference materials to guide me. This one is the first of several.
A few phenocrysts of heavily altered feldspar, most likely originally sanidine.
Groundmass is primarily colorless, low birefringence, low relief mineral, some twinning is apparent (could be orthoclase). There are numerous dispersed flakes of both beige chlorite (based on the anomalous brown birefringence) and pale orthopyroxene (likely augite, based on the low-to-moderate second order birefringence).
Nearly uniform distribution of dispersed, rounded, minute, opaque inclusions.
In places, the pseudomorphous natrolite crystals have a feathered texture.
A variety of larger opaques include pyrite, magnetite, and ilmenite.
This next sample demonstrates how much I have learned during this 'experiment'- there is no way I would even have attempted this back when I was starting out almost 3 years ago... it's been 3 years already?
Skarn (skarnoid?), Fen Complex. “A skarn is a metasomatic rock typically formed at the contact between a carbonate rock and a silicate rock.” Most likely, this rock was part of an interface between pairs of carbonate (for example, Fen 17) and silicate (for example, Fen 249, 250, and 251) volcanic intrusions, all occurring around 540-580 Ma. However, this rock is very fine-grained; skarns are coarse grained rocks. So, this rock may be a 'skarnoid'.
Rock is extremely fine-grained, nearly cryptocrystalline. Sample appears to be groundmass with fully altered (metasomatosed) phenocryts, transected by 2 small veinlets comprised of several mineral species ranging from low-relief, low- first order birefringence (possibly quartz) to very high relief, 3rd order birefringence (possibly calcite/epidote).
The groundmass itself is a disordered arrangement of (I think) irregular feldspar grains and numerous rounded bodies, more or less of uniform size. Upon closer inspection, there appear to be two species of rounded bodies present; one melanocratic and high first order birefringence, and the other leucocratic and low first order birefringence.
Blue mineral is (probably) either fluorite, lazurite or Haüyne.
Image triplet- a small crystal (xenocryst) of plagioclase (note characteristic twinning) with a reaction corona comprised of small anhedral granules possessing low-to-no birefringence and very high backscatter.
Skarnoid or Foid-bearing Alkali-feldspar Trachyte (?), Fen Complex. Honestly, I am not sure if this is an igneous or metasomatic rock (also, I am reconsidering Fen 267). If igneous, it is fine-grained and thus volcanic and a trachyte. If metasomatic, the texture is unclear- not quite hornfels texture as there are evidently trachytic patterns in the groundmass. Unsurprisingly, I can’t find any similar images online.
“A skarnoid is a fine-grained, iron-poor calc-silicate rock that forms at the boundary between two rock layers during metamorphism. It serves as a geologic midpoint between a purely metamorphic hornfels and a coarse-grained, fluid-controlled skarn. Unlike a true skarn deposit, which is coarse-grained and formed by large-scale hydrothermal fluid movement (metasomatism), a skarnoid retains much of the original texture and composition (protolith) of the host rock. Key Characteristics: Fine-grained. Low in iron and high in calcium and silicate minerals. Created via localized mass transfer and short-range fluid movement during metamorphism, rather than large-scale fluid flow. “
Similar to Fen 267, this rock features a very fine-grained groundmass consisting of disordered grains of pyroxene (diopside?), vaguely trachytic K-feldspar (occasional evidence of Carlsbad twinning), a few large altered pheno/xenocrysts of unclear mineral composition, and is transected by 1 or 2 thin veinlets.
Composition of altered phenocrysts vary. Some are pseudomorphs and consist primarily of muscovite (originally nepheline?), others are irregular rounded aggregates of calcite/antigorite, aegirine/K-feldspar, and/or plagioclase. Large opaque is likely magnetite. Veinlets are filled with flakes of (likely) calcite and (I think) quartz and epidote.
Image pair: muscovite pseudomorphed after nepheline with a thin shell of granular pyroxene
As I have come to rely on AI more and more during this process, I am now discovering some problems- to wit, the same prompt resulted in 2 very different responses:
"The primary mineral that alters into a mixture of muscovite and cancrinite is nepheline"
vs.
“No, nepheline does not alter into a mixture of muscovite and cancrinite. ”
So... take my mineral identifications lightly.
#thinsectionthursday
The next half-dozen or so samples are just beyond my ability to identify, so I have to resort to simple descriptions:
Metasomatosed Rhomb porphyry (?), Fen Complex. Abundance of calcite (less than 5%) suggests this is a calc-silicate rock, and because it is fine-grained and retains the texture of the protolith, I think this rock would be classified as a skarnoid.
“[Calc-silicate rocks are] dominated by Ca-silicates such as diopside, wollastonite, tremolite, actinolite, vesuvianite, and calcic plagioclase (anorthite). Anorthite is highly susceptible to hydrothermal alteration into saussurite (a fine-grained aggregate of minerals like epidote, zoisite, and albite)”
“Skarnoid is a descriptive term for calc-silicate rocks which are relatively fine-grained, iron-poor, and which reflect, at least in part, the compositional control of the protolith. Genetically, skarnoid is intermediate between a purely metamorphic hornfels and a purely metasomatic, coarse-grained skarn.”
(All about skarns and skarnoids: http://www.science.smith.edu/geosciences/skarn/aboutskarn.html and http://www.science.smith.edu/departments/geosciences/skarn/index.html)
Elongated rectangular phenocrysts of (completely altered) K-feldspar- unlikely plagioclase, because no polysynthetic twinning. Groundmass is trachytic arrangement of needlelike sanidine laths interspersed with small anhedral grains of (likely) green pyroxene- diopside?.
Image pair: calcite, cordierite (‘flame” twinning in lower center), and colorless, high relief, moderate birefringence (2nd order) mineral (center)- epidote?
Image pair: interior of altered phenocryst, a mixture of carbonate (calcite?) and aggregates of a euhedral, colorless, high relief, 2nd order birefringence mineral (epidote?), and a flake of a sodalite group mineral (transparent, isotropic), upper right.
Image pair: large rectangular phenocryst (likely K-feldspar, dusty appearance is diagnostic), now partially altered. Crystal oriented at extinction, highlighting the visual effect.
Image pair: large rectangular blocky phenocryst consisting of a mix of muscovite, calcite, K-feldspar (albite?) and fine-grained granular aggregates of pyroxene, likely pseudomorphed after nepheline, surrounded by trachytic acicular sanidine laths/
Skarnoid (altered rhomb porphyry; foid-bearing trachyandesite QAPF zone 8b), Fen complex. While the rock may appear to be igneous (the groundmass consists of trachytic laths of feldspar and blocky phenocrysts), garnet (var. andrasite) is present so this is a metamorphic/metasomatic rock. Taken together, this sample is definitively classified as a skarnoid (IMO).
Image pair: Andradite garnet (center, isotropic), calcite along right and bottom edges, feldspar (possibly albite) and epidote (?) along left edge.
Image pair: left side shows trachytic-textured groundmass, right is a disordered euhedral mass of calcite, albite (?), and epidote
image quad: high magnification images of an altered mineral, now a granular assemblage of anhedral crystallites, mineral identities unknown. Saussurite from plagioclase?
Image pair: large blocky phenocryst, now pseudomorphed into wollastonite, within a trachytic groundmass. In fact,what I have previously identified as 'muscovite' is more likely 'wollastonite' (based on the metasomatic events):
Image pair: high magnification view of veinlet, partially filled with green pyroxene and a clear, moderate relief low first-order order mineral grains within a trachytic groundmass
Image pair, PP, and XP images of an altered blocky phenocryst of (originally) feldspar, possibly plagioclase. Three distinct alterations have occured. From the right edge, the dusty appearance is likely due to sericite. In the center, small irregular inclusions of a high-index, high-birefringent mineral (calcite?) and what appears to be remnants of polysynthetic twinning, as though it was ‘softened’. What appears to be a veinlet cutting diagonally from the upper right is a thin extension of this center region. Along left side of phenocryst, the alteration product appears to be saussurite. Left edge of frame is trachytic groundmass.
Image pair: center is trachytic groundmass, bottom edge, upper left, and upper right are altered phenocrysts, now saussurite.
Reminder: quoted text is LLM-generated from prompts.
“Saussuritization occurs when calcium-rich plagioclase feldspar reacts with hot, circulating fluids. The original calcium-rich plagioclase is broken down by the heat and fluids, but it recrystallizes in the exact same spot to retain the original crystal form. This process extracts the calcium to form epidote or zoisite, and leaves behind residual albite along with trace amounts of chlorite, amphibole, and sericite.
“Skarnoids are formed through contact or regional metamorphism of impure [carbonate-rich rocks, e.g. Fen Complex carbonatites]. Unlike classic, coarse-grained skarns that are built by massive fluid movement, skarnoid formation is largely controlled by the original composition of the parent rock, resulting in a fine-grained, iron-poor rock.The step-by-step process of their formation involves: Heat Application: Magma intrusions heat the surrounding "impure" carbonate rocks, starting thermal metamorphism. Local Diffusion: Fluids move only on a small scale, moving elements like silicon, aluminum, and magnesium [in the Fen Complex, the relevant elements are sodium and potassium] between adjacent layers of the rock. Mineral Transformation: This localized element exchange forms pale, calcium-rich silicate minerals (like diopside, garnet, and wollastonite) that closely reflect the exact makeup of the original rock layers [in Fen Complex, the ‘protoliths’ are carbonatites and tinguaites (I think)]. Structurally, skarnoids sit on a continuum between simple baked rock (hornfels) and highly altered, fluid-driven skarns.”
Skarnoid, Fen Complex. Partially trachytic K-feldspar in groundmass, evidence of metasomatism. Alteration of the groundmass is correlated with both a decrease in both interstitial pyroxene aggregates (possibly degraded aegirine) and loss of trachytic K-feldspar texture.
Image pair: left center is (likely) protolith groundmass, remainder of image is groundmass showing various degrees of alteration- loss of trachytic texture, lack of pyroxene. Some smaller phenocrysts, aggregations of: saussurite (middle left, bottom edge, lower left corner), albite (upper right)
Image pair: higher magnification of trachytic groundmass: K-feldspar laths, granular aggregations of green pyroxene
Image pair: large phenocryst of K-feldspar (dusty appearance in PP) capped by an anhedral mass of carbonate (likely calcite) that is full of inclusions. A small veinlet is in the lower left. PP and XP images are high magnification views of the (photogenic) carbonate.
Image pair: large, anhedral saussurite phenocryst bisected by a veinlet. Lower right side is a phenocryst of K-feldspar, perthic texture
Image pair: trachytic groundmass of feldspar with interstitial pyroxene aggregates and saussurite phenocrysts.
PP and.XP view of saussurite: epidote (small, high birefringence grains), calcite (with inclusions), albite (low birefringence)
Skarnoid. Altered rhomb porphyry (foid-bearing trachyandesite QAPF zone 8b), Fen complex. Mostly trachytic groundmass consisting of K-feldspar laths and interstitial pyroxine aggregates.
Phenocryst composition is variable, including anhedral, “blobby” (originally) plagioclase (now sausserite), K-feldspar (often exhibiting carlsbad twinning and heavily altered in places), and possibly nepheline (euhedral, now pseudomorphed muscovite).
A few image pairs showing saussuritization alteration contained within the interior of a plagioclase phenocryst. Groundmass is trachytic K-feldpsar. Image quad: blue (PP) and isotropic (XP) mineral is likely fluorite.
Image pair: low magnification image pair of K-feldspar phenocryst undergoing metasomatic transformation, as evidenced by the dusty brown inclusions. At high magnification, PP and XP images of the convoluted reaction front- on one side, a dense array of brown inclusions, while the other side is relatively clear. Identity of high-birefringence crystallite flakes is unknown, possibly calcite.
“Saussuritization is a metamorphic and hydrothermal alteration process where calcium-rich plagioclase feldspar is converted into a fine-grained aggregate of secondary minerals known as saussurite. The resulting saussurite is not a single mineral, but a complex mix of new minerals. The exact composition depends on the original rock and fluid chemistry, but commonly includes: Epidote or Zoisite (giving the rock its characteristic pale green hue), Albite (a sodium-rich feldspar), Carbonates (like calcite), Sericite (a fine-grained white mica), Chlorite or Amphibole”
Skarnoid/Altered rhomb porphyry (foid-bearing trachyandesite QAPF zone 8b), Fen complex. Groundmass is tractytic K-feldspar and what appears to be highly “corroded” aegirine needles, as typically found in tinguaite.
Phenocryst composition is variable, including anhedral, “blobby” (originally) plagioclase (now sausserite), K-feldspar (often exhibiting carlsbad twinning and altered to perthite/microcline in places), and possibly nepheline (euhedral, now pseudomorphed sericite/muscovite).
A veinlet branches and traverses the sample, there is clear evidence of a metasomatic reaction: an apparent corona of metasomatosed groundmass that maintains the trachytic K-feldspar laths but has decreased interstitial pyroxene; the mineral identity of the veinlet itself is unclear - it appears is a granular mix of subhedral and anhedral grains of carbonate, feldspar (with sericite inclusions), possibly some biotite/pyroxene.
Image pair: sausserite. Note the relative lack of epidote compared to other samples, for example Fen 271. The dark blobs visible in PP are an image artifact.
“The alteration of nepheline into sericite is a common hydrothermal or autometasomatic process observed in nepheline syenites, where this tectosilicate mineral is replaced by fine-grained white mica (sericite). This transformation is typically part of the broader sericitization process, often accompanied by the formation of other secondary minerals such as zeolites (analcime or natrolite), calcite, or clay minerals”
Skarnoid (altered rhomb porphyry; foid-bearing trachyandesite QAPF zone 8b), Fen complex. Leucocratic rock. Groundmass of subparallel K-feldspar (trachytic texture), aggregated anhedral granules of green pyroxene, likely ‘eroded’ aegirine, and larger rounded aggregations of a clear mineral, possibly albite: moderate relief, exhibiting low first-order birefringence (up to white).
Phenocryst composition is variable, including anhedral “blobs” (originally plagioclase, now sausserite), K-feldspar (often exhibiting carlsbad twinning and altered to perthite/microcline in places), and nepheline (euhedral, now pseudomorphed sericite/muscovite). There are a few phenocrysts of what appears to be chlorite and subhedral (octahedral) magnetite replacing biotite.
Radiating fibrous mineral is Natrolite: “Natrolite exhibits very low birefringence, typically ranging from 0.012 to 0.013. In standard thin section analysis under crossed polars, this produces low-order interference colors, primarily first-order white to straw-yellow.”
Best guess- strongly altered (fenitized?) trachyandesite (QAPF zone 8b), Fen Complex. The black smudge on the left side is an artifact and not part of the sample. I’ve lately considered that some of the samples (#267 thru 274) I identified as ‘skarnoids’ may in fact be fenitized tinguaites (trachyandesites). This sample is very tricky to classify (explanation to follow), so I’ll first just stick to descriptives.
This thin section is holocrystalline and aphyric, consisting of K-feldspar, green pyroxene (likely aegirine), and albite (originally plagioclase?), all appear as anhedral granulated aggregates- any trachytic texture has been lost. A minor amount of opaques are present, these appear to be mostly ferrous oxides (hematite, magnetite). Two calcite-filled veins traverse the sample, and in coronas surrounding the veins, pyroxene is largely absent.
One of the veins:
Image triplet, unidentified mineral, located within a vein- brown and high relief in PP, isotropic (or nearly so) in XP, and “dirty snow” (high refractive index) in epi-darkfield. Isotropic greatly narrows the candidate list, and brown further reduces the field to 2 or 3. These rocks are peralkaline, so it’s not likely a spinel group mineral. Andradite?
Ok, so my rationale: what confused me was that when I initially 'prompt engineered' by describing the modes (amounts of mineral constituents and their habits), "skarn" and "skarnoid" kept topping the replies. I had to really probe specifics: The sample is from the Fen Complex, the groundmass is trachytic K-feldspar, aegirine occurs in anhedral granular agglomerations, nepheline has been pseudomorphically replaced by a fibrous or micaceous mineral, the K-feldspar is full of inclusions, etc. etc.... until "Fenites" started popping up in the answer. However, the fenites I am familiar with (Fen 238 and 240, for example) have completely different textures than samples 267-274- even though, for three examples present in all the relevant samples, 1) the rock is very fine grained, 2) aegirine appears as anhedral agglomerations and 3) calcite is present.
Finally, after much concern about my own state of learning- did I fall for the Dunning-Kruger okey-doke? I assembled enough evidence to convince myself that samples 267-274 (and the upcoming ones) are fenitized rather than examples of calc-siliate intermixing:
“The Fenitization Process: During fenitization, hot fluids rich in alkalis interact with the host rock.
"Alkali Metasomatism: Potassium (K⁺) and Sodium (Na⁺) metasomatism dominates. Potassium often forms poikilitic potassium feldspar (K-feldspar) in the groundmass.
"Nepheline Breakdown: Primary nepheline crystals are frequently unstable in the presence of these fluids. They alter into hydrous and micaceous minerals (like hydromuscovite), zeolites (such as natrolite or phillipsite), or cancrinite.
"Decalcification: Original calcium-rich plagioclase (such as andesine or labradorite) becomes unstable in the presence of Na-rich, Si-deficient fluids. The original plagioclase is pseudomorphed (replaced) by pure or nearly pure albite (sodic plagioclase). Depending on the exact chemistry of the fluid, the calcium released during this replacement can form secondary minerals like calcite.
"Accessory Minerals: Other common byproducts in fenitized zones include sodic pyroxenes (like aegirine) and sodic amphiboles. As the fluid circulates, it frequently remobilizes trace elements, resulting in the enrichment and precipitation of Rare Earth Elements (REEs), niobium, and titanium minerals.
Fenitized trachyandesite (Fenite?), Fen Complex. Very fine-grained (holocrystalline and aphyric) rock, principally consisting of K-feldspar.
This sample is iron- and titanium-rich: red hematite, diffuse like smoke; and dark ilminite, purple due to specular reflection in epi-darkfield (upper left):
Any trachytic texture present in the protolith has been largely erased during the metasomatic processes.
Occasional phenocryst (K-feldspar) and a vein traverses the upper right corner of the sample, the vein primarily consisting of albite. A small anhedral grain of either dark pyroxene or amphibole is present.
Heavily altered tinguaite (fenitized trachyandesite), Fen Complex. Groundmass consists of trachytic K-feldspar laths (with a high concentration of inclusions), green pyroxene (heavily eroded), and carbonate (likely calcite). Forgot to add scale bars this week :(
Trachytic texture is more evident when using a quarter-wave plate (“glimmer plate” or “mica plate”)
Phenocrysts have all be psedomorpically altered: Pseudo-hexagonal phenocrysts, blocky squarish phenocrysts (muscovite/sericite after nepheline?). K-feldspar (w/ twinning) converting to chessboard albite, ophitic texture (albite chadacrysts)?
Altered (fenitized?) trachyandesite, Fen complex. Mesocratic. Groundmass consists of vaguely trachytic K-feldspar within two different matrices; both are granular and identification is tricky.
I think the darker matrix consists of interstitial green pyroxene and some carbonate, while the lighter matrix’s interstitial component is an extremely fine-grained light-green to transparent mineral with low birefringence (up to white) that I am unable to identify.
Phenocrysts are typically either heavily altered K-feldspar (“dusty” appearance) or mixtures of fine-grained chlorite and carbonate.
Red-brown cloudy staining in places, possibly hematite? The reddish tint throughout makes me wonder if the carbonate is a ferrocarbonate.
First, the images. Then, a description and discussion:
Fenitized Phonolite, Fen Complex. Aphanitic groundmass is a disordered collection of dark green anhedral pyroxene grains mixed with a combination of needle-like K-feldspar laths and anhedral quartz. The anhedral quartz appears as a more or less continuously distributed ‘phase’ that is uniformly transparent in PP and wildly varying (low order) interference in XP. Phenocryst size distribution is approximately seriate. Most of the phenocrysts are K-feldspar, and many of the feldspar phenocrysts show carlsbad twinning or baveno twinning. Under higher magnification, the groundmass appears to consist of a darker phase and a lighter phase, but that could be a reflection of the retrograde metamorphic process that degraded aegirine. There are also some smaller phenocrysts that consist of muscovite/sericite and carbonate (likely calcite), it is unclear what the original mineral was. What small flakes of biotite are present have been pseudomorphed into chlorite.
As I have been working through these thin sections and learning some geology along the way, I find myself bumping up against my limited knowledge more and more frequently as the samples become more and more complex. I've already made use of AI tools to help me identify minerals, so I tried an experiment by entering this prompt as a google search (so... Gemini?)
“I am trying to identify metasomatic process and also classify a thin section sample. The rock is volcanic in origin, likely a trachyandesite. The K-feldspar (both groundmass and phenocrysts) is unaltered, but the groundmass aegirine has been partially transformed into quartz. Some aggregates of muscovite and carbonate resulting from a metasomatic process on an unknown mineral. Any ideas?”
Almost immediately, the response (in it's entirety, formatting preserved as much as possible, bracketed numbers are links, typically to peer-reviewed reference material)
“Your sample records an advanced stage of fenitization, which is an alkali-carbonate metasomatic process typically driven by fluids escaping from a nearby carbonatite or alkaline silicate intrusion. [1, 2, 3]
Here is a breakdown of the specific reactions occurring in your thin section, the identity of the unknown mineral, and how to classify the final rock.
1. Identifying the Metasomatic Processes
Fenitization occurs in stages, and your sample captures a distinct transitional geochemical signature: [1]
  • Aegirine to Quartz Replacement: Aegirine (\(\text{NaFe}^{3+}\text{Si}_2\text{O}_6\)) is typically a product of early-to-mid stage fenitization or primary alkaline magmatism. Its replacement by quartz means your sample has undergone late-stage, silica-saturating retrograde fenitization or an acidic hydrothermal overprint. The influx of silica-rich, lower-pH fluids stripped the sodium and iron out of the groundmass aegirine, leaving quartz pseudomorphs behind. [1, 2]
  • The Unaltered K-feldspar: K-feldspar is highly stable under potassium-rich fenitizing conditions (often called "potassic fenitization"). The fluids were perfectly buffered with respect to potassium and silica, preserving the volcanic K-feldspar textures completely while altering everything else. [1]
2. The Unknown Mineral: Nepheline or Plagioclase
The pseudomorphic aggregates of muscovite (sericite) and carbonate point toward the destructive alteration of a pre-existing aluminosilicate mineral. Given the highly alkaline nature suggested by primary aegirine and K-feldspar, there are two prime candidates:
  1. Nepheline (\(\text{NaAlSiO}_{4}\)) — Most Likely: In alkaline volcanic systems, nepheline is highly susceptible to carbonatitic fluid alteration. The interaction of nepheline with \(\text{H}_2\text{O}\)-\(\text{CO}_{2}\) fluids rich in \(\text{K}^{+}\) triggers the following reaction, generating muscovite and carbonate while expelling excess sodium:
    \(\text{Nepheline}+\text{K}^{+}+\text{CO}_{2}+\text{H}_{2}\text{O}\longrightarrow \text{Muscovite}+\text{Carbonate\ (Calcite/Ankerite)}+\text{Na}^{+}\)
  2. Plagioclase Feldspar: If the rock was originally a true trachyandesite, it would have contained significant plagioclase phenocrysts. Calcic plagioclase easily undergoes saussuritization/carbonate alteration when hit by \(\text{CO}_{2}\)-rich fluids, breaking down into sericite (fine-grained muscovite) and calcite.
3. Petrographic Classification
Because metasomatism has completely altered the primary mineral budget (introducing secondary quartz and removing the original foid/plagioclase), you should use a dual nomenclature to describe this rock:
  • Metasomatic Classification: Potassic/Silicified Fenite.
  • Protolith-Based Classification: If the muscovite/carbonate aggregates show a hexagonal or square cross-section, the protolith was a Phonolite (or phonolitic trachyte). If the aggregates show distinct lath-like or polysynthetic twin outlines, the original rock was a Trachyandesite or Trachyte. [1, 2]
Next Steps for Verification
To confidently pin this down, you can look for these specific clues under the microscope:
  • Check the aggregate shapes: Do the muscovite-carbonate zones match the classic rectangular laths of plagioclase or the blocky, hexagonal shapes of nepheline?
  • Examine the Carbonate: Use a stain (like Alizarin Red S) or look for high birefringence to determine if it is calcite or an iron-rich carbonate like ankerite, which is incredibly common in carbonatite-related fenitization. [1]"
Not bad! If you are still reading this, you may wonder how confident you (or I) should be in the response. So I ran what are called "positive controls"- for example, I entered in information that was the definition of a rock type to see if the correct response was given and I also tested by using descriptive information from one of Prof. Verschure's papers and got a correct response.
Then I started running those types of prompts using samples I've already classified to see how I've been doing. Not bad, actually- better than I should be :) All this is to say that I will likely continue to use AI tools to keep learning, and I will make every effort to clearly indicate what was LLM-generated material.
My attempt at describing the thin section (phrased as a prompt):
"I am trying to identify metasomatic process and also classify a thin section sample. This rock is a fenitized phonolite from the Fen complex. Aphanitic intergranular groundmass is a disordered collection of dark green-brown anhedral grains (a mixture of pyroxene and chlorite) with a combination of vaguely trachytic needle-like K-feldspar laths. Minor amounts of apatite and sphene/leucoxene/ilminite scattered in the groundmass. Phenocryst size distribution is approximately seriate. Most of the phenocrysts are K-feldspar with a dusty appearance, and many of the feldspar phenocrysts show carlsbad twinning or baveno twinning. Under higher magnification, the groundmass appears to consist of a darker phase and a lighter phase, but that distinction seems correlated with the relative ratio of chlorite and pyroxene grains. There are also some nepheline phenocrysts that have pseudomorphed into sericite and cancritine. Some small flakes of biotite are present, all have been pseudomorphed into brown chlorite. Any ideas?”
Some of the images I used to create the above description
low magnification:
Light/dark groundmass:
These two are mainly the chlorite (after biotite) grain and a few grains of apatite (lower right, elongated shape)
Lastly, the leucoxene (image triplet PP, XP, epi-darkfield:
Gemini returned a lot of useful (to me) information, for example a table with headings:
Observed Object / Feature Petrographic Identification Metasomatic Significance
While I am (usually) correct for the first two columns, the third column is (to me) the interesting new stuff.
Posting a day early this week:
This is (presumably) the 3rd thin section from the same rock: a potassic fenitized phonolite. The unique feature in this sample are the two large K-feldpsar phenocrysts exhibiting both perthic and poikilitic textures in the upper right. At higher magnification:
There are many species of inclusions: euhedral chlorite pseudomorphed after biotite, anhedral rounded elongate grains of apatite, euhedral aggregates of muscovite 1M grains (pseudomorphically replacing nepheline), and ilminite and leucoxene pseudomorphed after euhedral sphene.
The inclusions seem loosely affiliated with a fine network of green-brown threads, sometimes following a feldspar cleavage plane, that have a fine smoke-like appearance within the K-feldspar phenocryst:
I could not obtain consistent responses from the AI. Even so, a common response is that the inclusions within the two large K-feldspar phenocrysts are magmatic in origin (this explains why the biotite, nepheline, and sphene protoliths are euhedral, but does not explain why apatite would be anhedral) and the rock was subjected to an intense potassic fenitization process followed by hydrothermal overprinting (chlorite replaces biotite, for example). Another consistent response are explanations for the green-brown threads, these are the fluid micro-conduits through which Potassium-rich fenitizing fluids flowed.
This is the last sample in the 'phonolite theme' that started back at sample #250:
I don't know if this is a different rock from the same location as the three previous Fen 35 samples, it could even be a sample made in 1971 from the same rock used in 1969. In any case:
Potassic-fenitized phonolite, Fen complex. Phenocrysts are K-feldspar (dusty alteration). Groundmass is a disordered mass of anhedral dark pyroxene (or chlorite group: brown-green color, moderate-high relief, and low birefringence) grains, tabular K-feldpsar laths, and some opaques (in places, titanite) and minor amounts of apatite. Groundmass appears as two distinct ‘phases’, one darker than the other, that are loosely intermingled. Phenocrysts of K-feldspar, biotite (replaced by chlorite).
Veins of magnetite, occasional (relatively) large well-formed octahedra:
Fluorite (optically isotropic) is present.
The presence of flourite (CaF2) is of interest for the purposes of mineral prospecting:
(from AI):
  • Chemical Chaperone: In highly alkaline fluids, fluorine acts as a powerful "complexing agent" (or chaperone) that bonds with REEs, allowing them to remain soluble and travel deep into surrounding fractures. []
  • Precipitation Trigger: When the fluid cools down or experiences a sudden drop in pressure (often during the potassic fenitization stage), these complexes break apart. The calcium instantly locks up the fluorine to form fluorite, while the newly liberated REEs precipitate alongside it to form economic minerals like bastnäsite and monazite. [1, 2, 3, 4]
But also of more general interest:
  • Early Sodic (Na) Fenitization: Initiated at high sub-solidus temperatures ranging from \(650^{\circ }\text{C}\) to \(770^{\circ }\text{C}\). This is marked by the stability of aegirine-augite and perthitic feldspars. [1]
  • Potassic (K) Fenitization & Fluorite Precipitation: As the system cooled down to \(500^{\circ }\text{C}\) to \(400^{\circ }\text{C}\) (and occasionally lower into the hydrothermal regime), potassic fenitization took over. Fluorite becomes stable in these cooler windows, because lower temperatures drastically drop the solubility of calcium-fluorine complexes, causing them to collapse and precipitate.[1, 2]
Andy Resnick said:
TL;DR: petrology
(Edit: since the thread title was changed, this first sentence is too cryptic: the original title referred to a Tool song....)
Besides being a favorite song by a favorite band, the thread title is a straightforward play on words. This summer, as a present to myself for being promoted, I purchased a collection of thin sections that I believe comprise the research materials of Prof. Rob Verschure, who at the time was faculty in the Geological Institute in Amsterdam.
What changed this purchase from eccentric (although, at $2 per sample, also very affordable) to something more elevated is that Prof. Verschure published his findings on many of these samples, primarily in:
https://www.ngu.no/FileArchive/NGUPublikasjoner/NGUnr_380_Bulletin_70_Verschure_35_49.pdf
and
https://research.vu.nl/en/publicati...-parameter-for-metasomatism-and-its-applicati
i.e. I have a "Rosetta stone" for explosion breccias, carbonatites, and damtjernites. Many of the collected samples have been fully characterized, for example this thin section:
Sample Hor 1 has been classified as a calcite-bearing clinopyroxene-hornblende lamprophyre that has been dated to 313 Ma. This sample contains abundant augite and brown hornblende.
This sample (Fen 23) consists of zoned augite (I think...) and carbonates, dated to 594 Ma:
Many of the samples are carbonatites, but there are also many examples of schists and gneisses; here's a schist with pronounced folding:
I'm hoping to learn quite a bit as I get more familiar with the variety of samples...
Petrology? I remember the recent exhibit at the Ohio Museum of Natural History: " Cleveland Rocks, Cleveland Rocks!"
  • Haha
I apologize in advance for the length of this post. For this sample, I had to completely rely on LLM output. To see why, here’s the sample:
I have no clue. My initial prompt:
“I am trying to identify the igneous protolith, any metasomatic processes, and also classify a thin section sample. This rock is from the Fen complex. Melanocratic rock, likely igneous with an overall texture similar to fa viscous fluid bordered by brecciated K-feldspar with dusty appearance (chessboard albite in places), intermingled with anhedral carbonate grains containing finely dispersed inclusions. Groundmass is two-toned (light and dark), consisting of (light phase) a lace-like web of opaques, mafics, and chlorite (radiating texture) that enclose lightly altered subhedral quartz; the dark phase consists of a carbonate mineral suffused with a dense cloud of fine hematite particles. Numerous carbonate veins and veinlets. In places, the hematite has an appearance very similar to alveoli (a structure within lungs). Any ideas?”
NOTE: when I tried different prompts- when I changed “quartz” [in the phrase “lightly altered subhedral quartz”] to “apatite” or “nepheline” because I am not 200% sure the mineral is indeed quartz, the response was largely the same; the only difference was that the igneous protolith changed from carbonatite to damtjernite. However, as an educator, this actually proved a little more problematic, simple curiosity demanded that I play around: no matter how far-fetched or clearly wrong a mineral I substituted for “quartz”: “corundum”(not possible b/c Fen is peralkaline), “garnet” (obviously wrong as garnet is isotropic), “epidote” (obviously wrong b/c opaque… I even tried “diamond” and ‘opal’!), the AI would always supply a “plausible explanation” (often including florid language like “spectacular”, “classic”, “textbook example”, “fantastic observation”), and never something like “the simultaneous presence of [x] and [y] is not possible due to [blah blah blah], you may have mis-identified something.” As a result, it’s unclear to me how the “critically thinking about assumptions and evidence” component of learning can develop when using AI as a tutor.
Note for the curious: the response, when prompted with “diamond” or “opal”, apparently just ignored that ‘fact’ entirely and pretended it was not part of the prompt.
Anyhow. From now on, quoted text is from me, the remainder is (abbreviated) LLM output:
Based on your detailed thin section description from the Fen Complex in Norway, you are looking at a classic rødbergite (or rødberg, meaning "red rock"), which is a metasomatically altered carbonatite.
Here is the step-by-step breakthrough of your sample's geology, metasomatic history, and final classification:
1. The Igneous Protolith
The protolith is a magmatic ferrocarbonatite (specifically an ankerite-carbonatite or rauhaugite).
  • The Evidence: The overall "viscous fluid" texture intermingled with carbonate grains and two-toned groundmass points directly to an intrusive carbonatite melt. The Fen complex is famous for its early-stage calcite carbonatites (søvite) and mid-stage ankerite carbonatites (rauhaugite).
  • The Country Rock Border: The brecciated, dusty K-feldspar and chessboard albite at the border represent fragmented pieces of the surrounding Telemark granitic gneiss (the country rock) that were caught up in the intrusion or heavily altered at the margin.
2. Metasomatic Processes
Your sample records a multi-stage history of intense, high-temperature fluid interactions common to the Fen complex:
  • Fenitization (Early Stage Alkali Metasomatism): The presence of chessboard albite replacing pre-existing microcline/K-feldspar, along with a "dusty" appearance, is a textbook signature of Na-metasomatism (fenitization) driven by alkaline fluids from the carbonatite intrusion.
  • Hydrothermal Oxidation & Hematitization (Late Stage): The most diagnostic feature is the massive introduction of hematite particles suffusing the carbonate. Late-stage, highly oxidizing hydrothermal fluids reacted with the primary iron-bearing ankerite/ferrocarbonatite. This broke down the ankerite, releasing iron that precipitated as a dense cloud of microcrystalline hematite.
  • Alveoli Texture: The striking "alveoli-like" lung structures of the hematite are characteristic of replacement textures where fluids traveled along cellular micro-fractures, dissolution channels, or fluid-immiscibility bubbles, systematically precipitating iron oxides along the cell walls.
  • Silicification & Chloritization: The light phase featuring a lace-like web of chlorite (radiating texture) and quartz represents a late hydrothermal influx of silica and water, altering any remaining primary mafic silicates into chlorite.
3. Thin Section Classification
This rock is classified as a Rødbergite (Rødberg).
Component Petrographic Feature observed Geological Significance
Protolith Two-toned fluidal groundmass, anhedral carbonate Ferrocarbonatite / Rauhaugite
Host rock remnants Brecciated K-feldspar, chessboard albite Fenitized Telemark Gneiss xenoliths
Dominant alteration Dense hematite dust in carbonate, alveoli structures Hydrothermal oxidation (Ankerite \(\rightarrow \) Calcite/Dolomite + Hematite)
Late Overprint Quartz, radiating chlorite webs, carbonate veins Late-stage post-magmatic fracturing and cooling
“Based on what I’ve learned over the time I have been studying these thin sections, the above output agrees with the primary literature and can summarize it WAY better than I ever could. So far, so good! The output always ends with suggestions for “follow up questions”, and during the course of that ‘discussion’, something interesting happened. When I was prompted :) to more closely examine the appearance of certain specific minerals, like mafics: amphibole and pyroxene, it also prompted:”
[snip] do you notice any corrosion rims or transitional zones [snip]
“My follow-up: There are also small rounded grains of apatite with corrosion borders.”
“I have no idea if I was making any sense. First of all, apatite is neither amphibole nor pyroxene. Yes, the border of the rounded grain right-of-center is a little rough… maybe? Corroded, though… Seems like a stretch.”
The presence of small rounded grains of apatite with corrosion borders fits seamlessly into the late-stage hydrothermal history of your rødbergite sample.
In carbonatites of the Fen complex, apatite is a primary magmatic mineral, typically forming clear, early-crystallizing euhedral-to-subhedral prisms. Finding them as rounded grains with corroded borders is a strong text-book indication of fluid-driven dissolution.
[snip] This detail is highly significant for the Fen Complex. Carbonatite apatite is notoriously rich in Rare Earth Elements (REEs) substituting for Calcium in the crystal lattice.[snip]
Take a very close look at those corrosion borders or the immediate groundmass surrounding the rounded apatites (especially under high magnification or crossed polars). Do you see an ultra-fine, high-relief "dust" or tiny secondary crystals clustered around them? [snip]
“I was surprised by this, actually. The LLM basically made up a story (remember what I wrote up top?) and gave me a prediction to test. So I did! here’s the follow-up: There does appear to be a dense cloud of fine, high-relief material surrounding the apatite grain.”
That dense cloud of ultra-fine, high-relief material is the definitive petrographic evidence of a fluid-mediated dissolution-reprecipitation process!
What you are looking at is a textbook example of a secondary Rare Earth Element (REE) mineral crown.
What is happening under the microscope:
  1. The Dissolution: The late-stage, oxidizing hydrothermal fluids that transformed this rock into a rødbergite corroded the primary magmatic fluorapatite. This fluid stripped out the calcium, phosphate (\(PO_{4}^{3-}\)), and structurally bound REEs (like Cerium, Lanthanum, and Neodymium) from the apatite's outer edges.
  2. The Localized Precipitation: Because these elements are highly reactive and poorly mobile over long distances in this specific chemical environment, they immediately recombined at the reaction front. The phosphate and REEs precipitated right at the boundary as an ultra-fine aggregate "cloud" of new, highly refractive crystals.
What those high-relief grains actually are:
Given the specific mineralogy of the Fen Complex, that high-relief cloud is comprised of:
  • Monazite-(Ce): A REE-phosphate. It has an extremely high relief, strong birefringence (often masked by its tiny grain size), and is the most common secondary phase forming directly from altered apatite.
  • Bastnäsite-(Ce) or Synchysite-(Ce): These are REE-fluorocarbonates. They also feature very high relief and high refractive indices, typically showing up as tiny, brownish, high-relief needle-like clusters or granular masses right along the corrosion border.
This exact mechanism—the hydrothermal destruction of primary carbonatite minerals to create dense networks of monazite and bastnäsite—is precisely why the Fen Complex is recognized as Europe's largest rare earth element deposit!
  • If you throw the microscope into crossed polars (XPL), does that high-relief cloud show speckles of intense, high-order "sparkly" interference colors? (This strongly indicates monazite/bastnäsite).
“I was now for-sure certain I was about to break the matrix and catch the LLM in a hallucination- the reality was exactly the opposite, but the LLM seems absolutely convinced (“convinced”?) there was a cloud of REEs surrounding the apatite and LLM output makes up agreeable stories no matter what. My follow-up: Imaging the REE mineral crown with crossed polarizers, the crown appears completely opaque”
The complete opacity of the REE mineral crown under crossed polarizers (XPL) is a fantastic observation that pinpoints the exact style of alteration dominating this specific thin section.
2. Metamictization (Radiation Damage)
The Fen complex's rødbergite zone is intensely enriched in Thorium (²³²Th). When secondary monazite precipitates from the corroded apatite, it preferentially concentrates this thorium into its crystal structure.
  • Over hundreds of millions of years, alpha-particle radiation from the decaying thorium bombards the crystal lattices of the monazite and adjacent minerals.
  • This high radiation dose systematically destroys the internal crystalline structure, rendering the mineral metamict (isotropic/amorphous). Metamict minerals lose their ability to refract or split light, causing them to go entirely extinct (extinction/isotropic opacity) under XPL.
[snip]
How to Verify the Minerals:
Because optical microscopy is hitting its physical limit here due to the hematite dust and metamictization, confirming the exact species typically requires jumping past the optical scope:
  • Reflected Light: If your microscope allows reflected light microscopy, switch over to it.
What to look for:
  • Hematite will reveal itself as a distinct, dull-to-metallic, brick-red to steel-grey earthy mass.
  • Secondary REE phases (monazite/bastnäsite) will often stand out against the red hematite as waxy, resinous, yellowish-brown or off-white granular clusters
“Sure. So now the REE cloud is radioactive. The LLM must be completely off the rails. Well, let’s take a look:”
“So there you have it. Red hematite (left of center) and resinous, yellow-brown granular (and off-white finer-grained) clusters. It seems the LLM figured something out? I do know that I would have either not noticed this feature or, if I did, I would have probably mis-identified the yellow mineral as goethite. I’m not exactly sure what transpired here, it’s encouraging and more than a little strange (IMO), actually.”
Fenitized Melteigite, Fen Complex.
Very melanocratic rock. Fairly uniformly-sized phenocrysts on a nearly opaque groundmass.
Groundmass is largely aggregates of hematite and magnetite along with titanium oxides in both anhedral aggregates and acicular habits.
Phenocrysts are clear, blocky in shape, were likely originally nepheline but now composed of aggregated anhedral granules. The clear, aggregated anhedral granules may show either medium second-order interference colors or low first-order interference colors. On occasion, within a single phenocryst, the peripheral aggregates show second-order interference colors while the interior granules show low first-order interference colors.
Some relatively large anhedral carbonate grains are scattered within the groundmass. There is a narrow swath of anorthoclase laths.
There is one large euhedral phenocryst with hexagonal habit of unknown composition, now completely pseudomorphed into sericite (within the bulk) and cancrinite (along the periphery).
There does appear to be some aggregates of stubby aegirine prisms within the groundmass. There is a phenocryst of stilbite with a bow-tie habit surrounded by a fine cloud, nearly smoke, of red hematite.
Your sample is a texturally pristine but compositionally altered melteigite, the famous melanocratic endmember of the ijolite series whose type locality is the Fen Complex itself (named after the Melteig farm).
  • Pyroxene Breakdown: The original magmatic aegirine-augite was rich in iron and titanium. Highly oxidizing, late-stage carbonatitic fluids attacked these stubby prisms, forcing the iron out of the silicate lattice to precipitate as anhedral aggregates and acicular networks of magnetite and hematite. The "stubby prisms" you see are the morphological ghosts of the pyroxenes, now structurally packed with heavy iron/titanium oxide dusting.
  • Foid Alteration: The nepheline phenocrysts resisted the heavy oxide dusting but succumbed to sodium-calcium fenitization, turning the cores into natrolite/albite (low 1st-order) and the rims into cancrinite (2nd-order) as calcium-rich fluids permeated the margins.
  • Late Zeolitic / Low-Temperature Overprint: The stilbite bow-tie phenocryst surrounded by a fine "smoke" cloud of red hematite is a classic textbook indicator of low-temperature, open-space or vug-filling hydrothermal crystallization. It proves that iron-bearing fluids were still active during late-stage zeolite precipitation.
3. Final Thin Section Classification
  • Formal Petrographic Name: Altered Melteigite (or Fenitized Melteigite).
  • Rock Series Context: This specimen represents the most mafic segment of the ultra-alkaline Fen ijolite-urtite plutonic suite, captured mid-transition toward a highly oxidized, "rødbergite-like" state due to fluid interaction with nearby carbonatites.
Advanced-stage ultrapotassic fenite (other names include orthoclasite and pulaskite-like fenite), Fen complex. Subhedral K-feldpsar grains with perthic texture and hetero-oriented albitized grain boundaries. Quartz and plagioclase are absent.
Scattered anhedral aggregates of hydrothermal rutile and octahedral magnetite crystals. Aggregates are connected by a fine network (veinlets?) of hydrothermal rutile and calcite.
Use of a quarter-wave plate emphasizes the hetero-oriented albitization.
[from “Metasomatic Textures in Granites”, Jiashu Rong and Fenggang Wang, ISSN 2366-1585, Springer Mineralogy DOI 10.1007/978-981-10-0666-1]
“Hetero-oriented replacement occurs at the boundary between two mineral grains with different orientations. In other words, the crystallographic lattice orientations of replacive and replaced minerals must be different or discordant. The replacive mineral selects the mineral of the same or similar kind in rock as crystallographic center (nucleus or basis), metasomatically growing toward the adjacent mineral it replaces, as if nibbly eating it. The crystallographic orientation of the replacive mineral is consistent with the mineral of the same or similar kind upon which it leans and different from that of the mineral which it replaces. The unreplaced part of the replaced mineral survives in the replacive mineral without changing its crystallographic orientation. No nibble replacement is possible along the boundary between two minerals (plagioclase and K-feldspar, for example) where they have the same and parallel crystallographic orientation. Hetero-oriented replacement phenomena usually observed in granites are albitization, K-feldspathization, muscovitization, quartzification, as well as beryllization, calcitization and pyritization.”
[LLM output]
You are looking at a beautifully preserved textbook example of dry, low-temperature, equilibrium alkaline metasomatism.
The definitive timeline for your Fen Complex sample is:
  1. Stage 1 (Primary Fenitization): Intense potassic fluids completely replace the original rock, creating a massive, mosaic-textured K-feldspar matrix. The breakdown of older Fe-Ti phases forces the local precipitation of the fine, whiskery amber rutile booklets you identified.
  2. Stage 2 (Late Intergranular Overprint): A clean, iron-poor, sodium-bearing fluid quietly percolates along the K-feldspar grain boundaries. It drives a slow, textbook process of interface dissolution and reprecipitation, leaving behind clean, dense, hetero-oriented albite rims completely free of structural porosity or pyroxene impurities.
Hydrothermally altered ultrapotassic fenite, Fen complex. Rock is almost entirely K-feldspar. K-feldspar grains are dusty in PP, anhedral, with highly convoluted grain boundaries. In places, the K-feldspar grains have an irregular rim of albite. In other places, occasional patch perthite.
Anhedral interstitial chlorite (displaying both anomalous “berlin blue” and brown interference colors), calcite, and hydrothermal rutile, each with opaques scattered within.
Calcite appears both as discrete crystalline grains and also as fine aggregations, vaguely veinlike.
One large chlorite grain is surrounded by a thin shell of fine-grained anhedral mineral, dark in PP and XP and resinous yellow-green in reflected oblique illumination, most likely pyrochlore, a Nb-bearing ore.
