Programming language for satellites?
The discussion revolves around the programming languages used in satellite systems, exploring various languages and their suitability for different aspects of satellite operation and control. Participants consider both high-level languages and lower-level programming, as well as the tools used for development and simulation.
  • Some participants propose that C, C++, and Ada are commonly used in satellite programming due to their proximity to the processor.
  • Others argue that while Ada was designed for safety-critical applications, its adoption has been limited due to a shortage of skilled programmers and support tools.
  • A participant mentions that C++ is favored for its safety features, while C is criticized for lacking type safety.
  • It is noted that MATLAB/Simulink is often used for development in aerospace contexts, particularly for simulation and guidance, navigation, and control (GNC) design, with C/C++ code generated for onboard processors.
  • One participant shares their experience designing a satellite, indicating that the programming language used would likely be the simplest and least complicated, though specifics are unclear.
  • Questions arise about the programming language used for the Pumpkin Cubesat kit, with a belief that it is based on C programming language.
Participants express differing views on the prevalence and suitability of various programming languages for satellite systems, with no consensus reached on a single language or approach being dominant.
There are references to specific programming environments and tools, but limitations in knowledge about the underlying languages used in certain systems are acknowledged. Additionally, the discussion touches on the constraints imposed by orbital mechanics on data transmission.
This discussion may be of interest to aerospace engineers, software developers in embedded systems, and students studying satellite technology or programming languages used in critical applications.
Biosyn
Hello,
What programming languages are used in the majority of satellites? I was thinking it would be C,C++, and Ada because these languages are close to the processor. I'm sure ASM is also used too.
Am I correct? I don't think any satellite uses Java but I could be wrong.
Biosyn said:
Hello,
Ada was developed precisely for applications such as this, but it never quite took hold. The biggest problems are lack of good Ada programmers and lack of good support tools. The language of choice nowadays is C++, sans some keywords that are either verboten or whose usage is very restricted (register, volatile, mutable, new, delete, catch, and throw). Closeness to the processor is not a factor. Neither Ada nor C++ is a close to the metal language. The primary reason for choosing Ada and C++ is safety. C isn't used all that much because C is not type safe. It's not a safe language, period. The burden of safety lies solely with the programmer rather than being built into the language.
Under the hood, the RTOS may well have good amounts of C and assembly in it. But I don't think you're asking about the RTOS. You're asking about the software used to operate and control the spacecraft .
Although C/C++ are usually used for RTOS but the development (at least the type of dev that a non-software engineer likes) for these systems is done in MATLAB/Simulink. MATLAB has tools for computing euler angles and quaternion math easily which is used extensively in spacecraft simulation and GNC design.
Most Aero's are more interested in the physics than the details of the language, which is why MATLAB/Simulink are preferred over C. They do generate C/C++ code for the processors used on board.
I actually designed a satellite as part of a team for my design project. We used STK software. I am not sure what language it had under the hood though.
If you mean the actual language inside the satellite well I have no idea. It would be whatever is the simplest and least complicated. There are also strict guidelines (due to the orbit mechanics) on how much data can actually be sent to the satellite and what ground-stations actually receive. I remember X band was touted a lot and some other band which I forgot.
Thanks for the responses!
What programming language is used for the Pumpkin Cubesat kit?
Is it C programming language? I believe that's what the Salvo RTOS is programmed in.
Yes, it's C. More info here.
  • · Replies 0 ·
  • · Replies 102 ·
  • · Replies 41 ·
  • · Replies 23 ·
9K
