Homework Helper
Dearly Missed
- 24,752
- 795
Five new papers by Thomas Thiemann and Bianca Dittrich
http://arxiv.org/abs/gr-qc/0411138
Testing the Master Constraint Programme for Loop Quantum Gravity I. General Framework
42 pages
"Recently the Master Constraint Programme for Loop Quantum Gravity (LQG) was proposed as a classically equivalent way to impose the infinite number of Wheeler-DeWitt constraint equations in terms of a single Master Equation. While the proposal has some promising abstract features, it was until now barely tested in known models. In this series of five papers we fill this gap, thereby adding confidence to the proposal. We consider a wide range of models with increasingly more complicated constraint algebras, beginning with a finite dimensional, Abelian algebra of constraint operators which are linear in the momenta and ending with an infinite dimensional, non-Abelian algebra of constraint operators which closes with structure functions only and which are not even polynomial in the momenta. In all these models we apply the Master Constraint Programme successfully, however, the full flexibility of the method must be exploited in order to complete our task. This shows that the Master Constraint Programme has a wide range of applicability but that there are many, physically interesting subtleties that must be taken care of in doing so. In this first paper we prepare the analysis of our test models by outlining the general framework of the Master Constraint Programme. The models themselves will be studied in the remaining four papers. As a side result we develop the Direct Integral Decomposition (DID) for solving quantum constraints as an alternative to Refined Algebraic Quantization (RAQ)."
http://arxiv.org/abs/gr-qc/0411139
Testing the Master Constraint Programme for Loop Quantum Gravity II. Finite Dimensional Systems
23 pages
"This is the second paper in our series of five in which we test the Master Constraint Programme for solving the Hamiltonian constraint in Loop Quantum Gravity. In this work we begin with the simplest examples: Finite dimensional models with a finite number of first or second class constraints, Abelian or non-Abelian, with or without structure functions."
http://arxiv.org/abs/gr-qc/0411140
Testing the Master Constraint Programme for Loop Quantum Gravity III. SL(2,R) Models
33 pages
"This is the third paper in our series of five in which we test the Master Constraint Programme for solving the Hamiltonian constraint in Loop Quantum Gravity. In this work we analyze models which, despite the fact that the phase space is finite dimensional, are much more complicated than in the second paper: These are systems with an SL(2,R) gauge symmetry and the complications arise because non-compact semisimple Lie groups are not amenable (have no finite translation invariant measure). This leads to severe obstacles in the refined algebraic quantization programme (group averaging) and we see a trace of that in the fact that the spectrum of the Master Constraint does not contain the point zero. However, the minimum of the spectrum is of order hbar^2 which can be interpreted as a normal ordering constant arising from first class constraints (while second class systems lead to hbar normal ordering constants). The physical Hilbert space can then be be obtained after subtracting this normal ordering correction."
http://arxiv.org/abs/gr-qc/0411141
Testing the Master Constraint Programme for Loop Quantum Gravity IV. Free Field Theories
23 pages
"This is the fourth paper in our series of five in which we test the Master Constraint Programme for solving the Hamiltonian constraint in Loop Quantum Gravity. We now move on to free field theories with constraints, namely Maxwell theory and linearized gravity. Since the Master constraint involves squares of constraint operator valued distributions, one has to be very careful in doing that and we will see that the full flexibility of the Master Constraint Programme must be exploited in order to arrive at sensible results."
http://arxiv.org/abs/gr-qc/0411142
Testing the Master Constraint Programme for Loop Quantum Gravity V. Interacting Field Theories
20 pages
"This is the final fifth paper in our series of five in which we test the Master Constraint Programme for solving the Hamiltonian constraint in Loop Quantum Gravity. Here we consider interacting quantum field theories, specifically we consider the non-Abelian Gauss constraints of Einstein-Yang-Mills theory and 2+1 gravity. Interestingly, while Yang-Mills theory in 4D is not yet rigorously defined as an ordinary (Wightman) quantum field theory on Minkowski space, in background independent quantum field theories such as Loop Quantum Gravity (LQG) this might become possible by working in a new, background independent representation."
42 pages
23 pages
33 pages
23 pages
20 pages
