Project Documentation
  • Thread starter aronclark1017
9 replies · 3K views · last reply
aronclark1017
Trying to package up a small bank account manager project that I have been tempering on for a while. One that is certainly worth something to me. Although I have created methods to whip up quick documents with all fields and properties. I would like something better to reference in order to express the mechanical functions. It is unclear to me about any standardized format for code documentation that exists. I have tried object orientated diagrams with shapes to try and express the mechanical flow of the code. But have settled on text methods using the code blocks and literature. Here is an example
Screenshot of C# class declarations drawn as boxes, including _date, _time, _phone, _transaction, _autoPayTransaction, _account, _bankAccount and _login, each listing its fields.
Annotated C# source code for a login form with callout boxes beside each method, explaining what _Flogin, load, showPasswordCheckBox_CheckedChanged, loginButton_Click and newUserButton_Click do.
Box-and-line diagram of a bank account manager's form flow: Flogin connects to FnewUser; Flogin leads to FbankAccountSelection, then to FbankAccount, which links to FsearchTransactions and FautoPayTransactions, with annotations describing data passed and refreshed between forms.
My first question is: Do you have programming/documentation standards for that project? If so, you need to satisfy those.
If not, you might want to look at Doxygen. If you format your code comments correctly, it can generate documentation and graphs. If you are already deep into your program, providing the correctly formatted comments might require a lot of work. You might want to add your own overview to the Doxygen documentation.
phinds said:
Is there a question there somewhere or did you just feel that we needed to know your technique?
What do you think of my personal documentation? Are diagrams such as UML a reliable standard for diagrams. If so any reference you have to code examples with UML diagrams would be appreciated.
I have created my own application where user can navigate class fields, properties, and methods. This application also generates files that simply just list all of that information. But in some projects that are large and complex there seems to be a need for a mechanical diagram especially when memory is low. Here this UML example communicates nothing to me as intended.
UML class diagram with stereotyped classes Frame, Window, Event, Shape, Rectangle, Polygon, Circle, Point, DrawingContext, ConsoleWindow, DialogBox and DataController, linked by generalization, aggregation, composition and dependency arrows, with pink annotations.
I have my own style of documentation for use in my own software. It's just blocks of comments as appropriate and not a formal system. If you wanted peoples opinion of your method, you should have ASKED, not make us guess whether or not you were asking a question.
I think you are going in a wrong direction. Good documentation requires more than a diagram. Trying to mix code, descriptive text, flows, call-trees, functional dependencies, variable definitions, structure definitions, class definitions, class inheritance, etc. in one diagram would turn into a mess for a moderately-sized program.
ADDED: I recommend that you become familiar with how to use a good documentation generator. I am only familiar with Doxygen. There are several others.
aronclark1017 said:
I think I am settling on this style hereView attachment 366120
This might be fine for a program under 100 lines, or an overview diagram. Keep in mind that successful, useful programs grow. What will this look like if the program is a thousand lines? What about ten thousand lines? There would be an enormous amount of details to document.
ADDED: That is a very good try and I applaud your desire to provide good documentation. You are doing much better than many beginning (and even experienced) programmers. What you have done would be good for a top-level overview. What you want, in addition to that, is some way to take care of the mass of tedious details of documentation without having to do it by hand. If you do all that by hand, it doubles the workload.
  • Agree
I also
For C++ code Doxygen is the standard.
If you want to add some diagrams giving an overview that's fine, but only once you have documented every public property and method.
If you use a relational database you should document that too.
