Projectile Angle and Distance problem
  • Thread starter Thread starter Nate-2016
    Angle Projectile
The problem involves a projectile launched from the top of a 100m tower at an angle with an initial velocity, requiring the determination of the angle of projection and the maximum height reached. The context is within the subject area of kinematics.
  • Participants discuss the separation of horizontal and vertical components of motion and the application of kinematic equations. There are attempts to rearrange equations to solve for the angle of projection, with varying interpretations of the algebra involved.
Some participants express uncertainty about the correctness of their algebraic manipulations, particularly regarding the treatment of the vertical distance in relation to time. Multiple interpretations of the equations are being explored, and there is no explicit consensus on the angle of projection yet.
Participants note the challenge of solving the problem without complete information, as the instructor has not provided any answers. There is also a mention of the constraints imposed by the problem setup, including the time of flight and the height from which the projectile is launched.
Nate-2016
A projectile was launched from the top of a 100m tower upward at an angle theta to the horizontal with an initial velocity of 36m/s. The time of flight of the projectile was 8 seconds.
Determine:
i) The angle of projection
ii) The maximum height reached by the projectile
S=ut+1/2at^2
I am used to solving these questions when i am not given time but given both the horizontal and vertical distances. At which I use the quadratic formula to solve for theta. However in this case I can not do that as when i split my horizontal and vertical components and apply the above equations I am left with these.
Horizontally
S=36cos(?)*8
Vertically
-100=36sin(?)*8+0.5*-9.81*64
I have tried rearranging the vertical formulas to solve for theta
-1/2*-9.81*64-100/8=36sin(?)
301.42 = 36*sin(?)
sin-1(36/301.42) = 6.85 degrees
I really don't think that the answer is correct. The lecture who set the question will not give any answers.
Nate-2016 said:
Vertically
OK
You have only the 100 being divided by 8. But is that correct?
Yeah. Only the 100 divided by 8. I am thinking that maybe 6.85 degrees is the correct angle for a projectile to fall from 100 metres in 8 seconds.
Check the algebra on this. I don't think it's correct to have just the 100 divided by 8.
Im not exactly sure on the rerrangment to solve for U. As i thought my 1st rearrange was correct.
I tried the rearrange dividing the whole thing by 8 = sin-1(26.74/36) = 47.96 degrees.
I tried the rearrange dividing by 16 from 1/2*8 under everything = sin-1(36/60.76) = 36.33 degrees
s = ut + 1/2at^2
ut = s - 1/2at^2
u = (s - 1/2at^2)/t
36sin(?) = (-100-1/2*-9.81*64)/8
Sin(?)= 26.74/36
Sin-1(26.74/36) = (?)
Nate-2016 said:
s = ut + 1/2at^2
ut = s - 1/2at^2
u = (s - 1/2at^2)/t
Sin(?)= 26.74/36
That looks correct.
