Projectile Fired by Burning Propellant: Gas Cycle?
  • Thread starter Thread starter Joe591
    Projectile
The discussion explores the concept of gas cycles in relation to projectiles launched by burning propellants, specifically using a potato cannon as a metaphor. It references the ideal gas cycles in thermodynamics, such as the Otto cycle, and questions whether a similar cycle exists for projectiles. Key points include the distinction between potato guns and traditional cannons, particularly regarding the use of oxygenated propellants and the resulting chamber pressures. The conversation emphasizes the broader implications of launching objects quickly and efficiently through combustion, rather than strictly adhering to gas cycle definitions. Overall, the thread highlights the complexities of interior ballistics and the thermodynamics involved in projectile motion.
Joe591
TL;DR
Pressure caused by burning propellant.
In thermodynamics you have ideal gas cycles. A example of this is the Otto cycle where there is adiabatic compression followed by constant volume combustion, followed by adiabatic expansion and then finally heat rejection at constant volume. What I'm wondering is whether there is a similar type gas cycle for a projectile being thrown out of a barrel by a burning propellant. Let's say there is a hypothetical potatoes canon with a small fuel reservoir. The fuel in the reservoir is ignited and the potatoes is launched through the barrel. Is there some sort of ''gas cycle'' for something like that? Please cite sources...
This is the Thermodynamics of Interior Ballistics. I am unable to find anything for a potato gun specifically. Try the graphic on p 16 to start. Plus, I'm not clear on what exactly you need for your definition of a gas cycle? Carnot?
Interior ballistics deals with all the aspects of your question, and a lot more I think.
One important difference is that potato guns, AFAIK, do not use oxygenated propellants, like nitrates in black powder. This creates lower chamber pressures than modern cannons that use black powder. Correct me if I'm wrong.
https://apps.dtic.mil/dtic/tr/fulltext/u2/a590866.pdf
Likes Lnewqban and Joe591
@jim mcnamara let's just say the potato gun is a metaphor for a more generalized type of problem. The problem of throwing something very far, very quickly by burning something else rapidly. Doesn't have to be a gas cycle if the ''industry norm'' isn't gas cycle oriented. Your link is fantastic! Thanks...
I need to anneal 5052 aluminum for a home project. Google has given me mixed results on how to do this. Short version is that I'm doing some heavy forming on a piece of 5052-H32 and I'm running into issues with it work hardening. I've tried the Sharpie trick with a propane torch. But I'm not sure this is doing anything. I'm also seeing conflicting opinions whether to quench or air cool. So I'm looking for some expert opinions. (Oven heating is not an option due to size.) Thanks. edit: The...
14K
