Projectile Launcher, large current, closed loop, magnetic field
The discussion focuses on calculating the constant current required to accelerate a bar in a projectile launcher setup. Given a bar length of 0.22 m, mass of 0.0015 kg, and a magnetic field strength of 1.7 T, the necessary current can be determined using the equation F = ILB, where F is the force, I is the current, L is the length of the bar, and B is the magnetic field strength. The acceleration needed to reach a velocity of 28 m/s over a distance of 1.0 m can be derived from kinematic equations, allowing for the calculation of the required current. The magnetic field direction must be established using the right-hand rule.
  • Understanding of Newton's second law (F=ma)
  • Familiarity with magnetic force equations (F=ILB)
  • Basic knowledge of kinematics
  • Application of the right-hand rule for magnetic fields
  • Calculate the required current using F=ILB and the derived acceleration.
  • Explore kinematic equations to understand motion under constant acceleration.
  • Study the right-hand rule in detail to determine magnetic field directions.
  • Investigate the effects of varying magnetic field strengths on current requirements.
Physics students, electrical engineers, and anyone interested in electromagnetic applications in projectile systems will benefit from this discussion.
thermocleanse
A projecticle launcher is shown in the attachment. A large current moves in a closed loop composed of fixed rails, a power supply, and a very light, almost frictionless bar touching the rails. A magnetic field is perpendicular to the plane of the circuit. If the bar has a length L=0.22 m and a mass of 0.0015 kg and is placed n a field of 1.7 T, what constant current flow is needed to accelerate the bar from rest to 28 m/s in a distance of 1.0 m? In what direction must the magnetic field point?
F=ma
F=ILB
I'm having a hard time conceptualizing this problem and would like any assistance. Thank you.
Current is simply protons moving in one direction. Moving charges in a magnetic field experience a force. Consequently the bar experiences a force. You've basically solved 90% of the problem with the two equations you wrote down.
BIL = ma
You can easily use the information given and kinematics to figure out the acceleration. Then just solve for I.
Use the right-hand rule for the second question.
16K
