PROJECTILE MOTION - Given values are Horizontal & Verticle distance when time = 4s
The discussion revolves around calculating the initial velocity of a projectile given its vertical and horizontal distances covered during the fourth second of its motion. The correct interpretation of the problem reveals that the distances pertain to the time interval between seconds three and four, not the entire four seconds. The vertical velocity is calculated using kinematic equations, leading to a value of approximately 54.3 m/s, while the horizontal velocity is determined to be 25 m/s. By applying the Pythagorean theorem, the initial velocity of projection is found to be around 59.8 m/s at an angle of approximately 65.3 degrees. The confusion initially stemmed from misinterpreting the time frame for the distances involved.
MusePhysick
An object fired with a velocity of Vo covers a verticle distance of 20.0m and a horizontal distance of 25.0m in the 4th second of its motion. Determine the following:
a) Its velocity of projection, Vo
(the rest I am not going to worry about cos if i get part a) started then i should be fine i just don't know what I am doing wrong)
ucosθ = x
usinθ = y
v = u + at2
s = ut + 1/2at2
v2 = u2 + 2as
v = s/t
ok so I've tried many a times but i think i have a misconception or not seeing what is happening etc.
i know the answer as it is given which is Vo = 59.8 m/s 65.3o (angle between ground and vector)
so it takes 4 seconds for the projectile to be displaced horizontally by 25 m
so by v=s/t
v=25/4
v=6.25
which v is also known as x
so i have x=6.25 m/s
the verticle velocity i found by many ways or tried to but here's one way
s=ut + 1/2at2
s = 20
a = -9.8
t = 4
20 = 4u + 1/2.(9.8).42
98.4 = 4u
u = 24.6 m/s
and in this case u = y
so y=24.6
by pythagoras
Vo2 = y2 + x2
Vo2 = 24.62 + 6.252
Vo = 25.2815
clearly not the answer but i proceeded to find the angle
y = usinθ
θ = 14.255
angle between ground and vector = 90 - 14.255
angle = 75.745 degrees
which is clearly not the case
if you see where I've gone wrong please do tell :)
ive tried many many wasy of getting the projected velocity and nothing seemed to work, I've tried 4 times and that takes a long time
sorry i used all caps for the topic, diddnt read the rules properly till it was too late, i do not wish to offend anyone soz
I don't know, but I did the exact same thing as you.
me too. there's seems to be nothing wrong with your method. i can't think of another way of doing it
yeah i found out what was wrong
it says in the 4th second meaning between t=3 and t=4 so it takes 1 second for the ball to reach 20m high and 25m horizontally haha damn english, ill post the answers soon
1. Homework Statement
An object fired with a velocity of Vo covers a verticle distance of 20.0m and a horizontal distance of 25.0m in the 4th second of its motion.(Meaning second 3 to second 4) Determine the following:
ucosθ = x
usinθ = y
v = u + at
s = ut + 1/2at2
v2 = u2 + 2as
v = s/t
3. The Solution
Vertical Velocity
s = ut + 1/2at2
when t=3
s1 = 3u + ½ X (-9.8) X 32
when t=4
s2 = 4u + ½ X (-9.8) X 42
s2 – s1 = 20m
s2 – s1 = (4u + ½ X (-9.8) X 42) – (3u + ½ X (-9.8) X 32)
20 = 4u – 78.4 – 3u + 44.1
20 = u – 34.3
u = 54.3 m/s
let u = y
y = 54.3 m/s
Horizontal Velocity
v = s/t
v = 25/1
v = 25 m/s
let v =x
x = 25 m/s
Vo
Vo2 = y2 + x2
Vo2 = 54.32 + 252
Vo = 59.779 m/s
tanθ = 54.3/25
θ= 65.278o
Therefore
Vo = 59.779 m/s 65.278o (angle of elevation)
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
