Projectile Motion Help: Launch Velocity and Distance Calculation
  • Thread starter Thread starter Aldy
    Projectile
The problem involves a ball launched vertically from a spring-loaded pipe at ground level, which lands after 4.7 seconds. The objective is to determine the launch velocity and the distance the ball would travel if launched at a 45-degree angle.
  • The original poster attempts to calculate the launch velocity and distance using kinematic equations but expresses uncertainty about the formulas used. Some participants discuss decomposing the initial velocity into horizontal and vertical components and suggest using kinematic equations for both directions.
Participants are exploring different approaches to the problem, with some providing guidance on decomposing velocity and applying kinematic equations. There is a recognition of the need for careful proofreading and clarification of the original poster's statements.
There are indications of potential confusion in the original poster's calculations and assumptions, particularly regarding the expected distance the ball should travel and the accuracy of the initial velocity calculated.
Aldy
a ball is launched vertically from a spring loaded pipe at ground level, and it lands in 4.7 seconds. We need to figure out the launch velocity and how far the ball will land if fired at 45 deg angle.
I am using the following formulas, not sure if they are the correct ones to use.
V= -1/2gt
dy= Voyt + 1/2ayt (squared)
dx = Voxt + 1/2axt(squared)
I calculated the launch velocity to be 23m/s
however I am having trouble calculating how far the ball lands if launched at 45deg angle.
The answer should be between 50-60 meters but I get an answer of 155.
Could someone please help me figure this out, please show work so I can understand. Thanks
Erasing this for confusing language and a mistake:redface:, sorry
Erasing due to incorrect info
How about this, I think I need to proofread my posts a little better, I actually might have made a mistake in that one :redface:
Do you agree that, for a projectile launched at an angle theta, you can decompose an initial velocity as such:
v_{0x}=v_0cos(\theta)
v_{0y}=v_0sin(\theta)
Well, then, from the equation to follow we can calculate the initial y velocity (because initial y location is known, it is 0, y acceleration is known, it is g, and t is known, it is 4.7s, and its final location is known, which is when y is equal to 0 again, you should graph this function, it is a parabola)
y=y_0+v_{0y}t+\frac{1}{2}a_yt^2
Then, with that figured out, we can get the total velocity using and then the x velocity in a few steps using those first two equations I gave you.
After solving for the initial x direction velocity, you can use the equation
x=x_0+v_{0x}t+\frac{1}{2}a_xt^2
to find the total x displacement. We also know the initial x location, 0, and the x acceleration, 0 (because we have no air resistance), and now we know the initial x velocity from the work before.
Does that help?
It is important to realize that velocity is a vector, it has magnitude and direction. In a kinematics problem we can treat the x and y directions as independent and decompose a velocity vector into its constituent x and y components with the first two equations I gave you, and then use them in independent kinematic equations.
Thank you, that is very helfpul.:smile:
Please delete that quote so we don't confuse anyone who might end up here
  • · Replies 38 ·
  • · Replies 39 ·
  • · Replies 21 ·
  • · Replies 36 ·
