Projectile Motion Leap Question
A tiger leaps horizontally from a height of 6.5 meters with a speed of 3.5 m/s, and the time of flight calculated is 1.15 seconds. The horizontal distance the tiger will land from the base of the rock is determined using the formula distance = velocity × time, resulting in approximately 4.025 meters. A follow-up question involves Romeo throwing pebbles to Juliet's window, requiring a horizontal velocity calculation for the pebbles to hit the window, which is determined to be 5.6 m/s. The calculations involve using the equations of motion to find time and distance. The discussion highlights the importance of understanding projectile motion principles in solving these problems.
umkat
QUick Question:
A tiger leaps horizontally from a 6.5 m high rock with a speed of 3.5 m/s. How far from the base of the rock will the tiger land?
I started this problem by trying to find the vert. and horz. components, but I was not given an angle to use sin and cos with...how do i start this problem? :confused:
Draw a picture, something that will help you.
i did that already...and it didnt help
would the angle be 90 degrees since the tiger is jumping horizontally?
no, it will be 0 degrees, of course I'm assuming max height is his initial position, it seems like that to me.
thanks.
i found how many seconds it will take (1.15)
but i still don't know how to find out the distance
sorry for being dumb =)
Well at the beginning he only has a Vx component, and remember it's always constant from the beginning to the end, so why don't you use it to calculate the distance?
would the final answer be V(initial)*t = 3.5 m/s (1.15s) = 4.025 m...
so 4 meters away??
If that's the time when it lands, then yes.
Thanks for your help...I just found this site tonite and signed up and it is real helpful. Thanks some much for the help, I'm sure I will continue to visit it again. Thanks
I've too found this site recently :smile: and yes i believe it is a great resource for students and teachers alike, it's always great to be of help.
okay I have one more question: Romeo is chunking pebbles gently up to Juliet's window, and he wants the pebbles to hit the window with only a horizontal component velocity. He is standing at the edge of a rose garden 4.5 m below her window and 5.0 m from the base of the wall. How fast are the pebbles going when they hit her window? I worked it out and got 5.6 m/s...is that what the answer is if anyone out there wants to work it out? thanks.
i said that D=1/2(9.8)(1.15) which equals 5.63
to find t i did t =square root of 2d/g or 2(5.63)/9.8 which equals 1.15
did you finish it, umkat?
