Projectile Motion man tosses object
4 replies · 2K views · last reply
Acnhduy
A man tosses object with initial velocity of 20 m/s into a room, and is 2.0 m above the ground. The room is 10.0 m above the ground.
In a provided diagram, the distance from man to room horizontally is 31.8 m.
I am required to solve for the angle of the object as it leaves the mans hand.
Big 5
vix= 20cosθ
viy= 20sinθ
To solve for θ, I must use the initial velocity given, broken up into components.
Since I am given the vertical displacement (8.0 m) and horizontal displacement (31.8 m) , I can use 2 formulas and substitute one into the other, by isolating t as it is common to both.
dx= vixt
31.8 = 20cosθt
t= 31.8 / 20cosθ
dy= viyt + 0.5ayt2
8.0 = 20sinθt - 4.9t2
8.0 = 20sinθ(31.8 / 20cosθ) - 4.9(31.8 / 20cosθ)2
8.0 = (31.8sinθ / cosθ) - 4.9(2.5281 / cos2θ)
8.0 = (31.8sinθ / cosθ) - (12.39 / cos2θ)
and now I'm stuck... I tried moving to one side and changing to common denominator...
0 = (31.8sinθ / cosθ) - (12.39 / cos2θ) - 8.0
0 = (31.8sinθcosθ - 12.39 - 8.0cos2θ) / cos2θ
0 = 31.8sinθcosθ - 12.39 - 8.0cos2θ
0 = 15.9sin2θ - 12.39 - 8.0(1 - sin2θ)
0 = 15.9sin2θ - 12.39 - 8.0 + 8sin2θ
0 = 8sin2θ + 15.9sin2θ - 20.39
but no luck...
i thought it looked like a quadratic at first, but I don't think it works with sin2θ
any suggestions? thank you :)
... so you have interpreted the question as asking about the direction of the initial velocity vector, given the ball passes through points A and B (going from A to B) and you know the speed at A.
... trig identities not helping you - you may be able to do it geometrically seeing ##2\sin^2\theta = 1-\cos2\theta## ... or is there another kinematic equation you haven't considered yet - that may be called into play?
i.e. have you used all the information at your disposal yet?
Notes:
do not put the numbers in until the end or you'll get turned around.
keep track of your reasoning all the way through.
Hmmm ... perhaps:
... go back to where it looks like you almost have a quadratic in ##\cos\theta##,
... multiply through by ##\sec^2\theta## ... from there, Pythagoras should get you a quadratic in ##\tan\theta##.
Mhm. Didnt even notice that it could be changed to secant. Thankyou
No worries.
The tan vs sec identities crop up a lot - especially in exams.
