Projectile motion on a hemisphere
The problem involves projectile motion, specifically analyzing the trajectory of a ball kicked from the top of a hemispherical rock. The goal is to determine the minimum initial speed required for the ball to avoid hitting the rock after being kicked horizontally.
  • Participants discuss the equations of motion and the geometry of the semicircle, attempting to find intersections between the projectile's path and the semicircle's equation. There are questions about the correct setup of the equations and the implications of the discriminant in a quadratic equation.
The discussion is ongoing, with participants exploring different mathematical approaches and clarifying their understanding of the relationships between the equations. Some participants have offered guidance on checking the equations and considering the implications of their results, while others express uncertainty about their interpretations.
There is a focus on ensuring that the ball does not touch the rock, leading to discussions about the conditions under which this occurs. Participants are also reflecting on the implications of their calculations and the assumptions made in their reasoning.
Bread18
A person standing on the top of a hemispherical rock of radius R kicks a ball (initially at rest on the top of the rock) to give it horizontal velocity [itex]v_i[/itex]
What must be it's minimum initial speed if the ball is never to hit the rock after it is kicked?
[itex]v=v_i+at,\\ v^2=v_i ^2 + 2ar, \\ r=v_i t +\frac{1}{2}at^2[/itex]
I'm not sure how to do this one as a parabola and a semicircle are 2 different shaped curves, a little nudge in the right direction would be helpful, thanks guys.
Hi Bread18! :wink:
Bread18 said:
… a parabola and a semicircle are 2 different shaped curves, a little nudge in the right direction would be helpful, thanks guys.
Write out the two equations, and see where they intersect …
what do you get? :smile:
Hmm ok...
Well the eqn of the semicircle is [itex]y=\sqrt{R^2 - x^2}[/itex]
The eqn of motion is [itex]y = \frac{1}{2}at^2 \\ x = v_it \\ y = \frac{1}{2}a(\frac{x}{v_i})^2 \\ 2yv_i^2 = a x^2?[/itex]
Bread18 said:
[itex]2yv_i^2 = a x^2?[/itex]
= a(R2 - y2) ? :wink:
[itex]ay^2 + 2yv_i^2 - aR^2 = 0 \\ 4v_i^4 +4a^2R^2 < 0 \\ v_i^4 < -a^2R^2[/itex]
and that's not right...
Bread18 said:
[itex]ay^2 + 2yv_i^2 - aR^2 = 0[/itex]
after that, you've lost me :redface:
Solve the quadratic, they don't touch so the discriminate needs to be < 0 (typo in the other post, I'll fix it)
ah, sorry, i'd forgotten what the question asked for! :redface:
yes, that's fine :smile:
remember, your "a" was negative! :wink:
Yes but it's a^2, so it cancels out the negative, leaving me with -g^2R^2?
hmm … you're right! :redface:
ok, let's go back and check your original equations …
ah! should be y = R + 1/2 at2 ! :smile:
(no wonder it couldn't avoid hitting the circle! :biggrin:)
Haha well spotted :smile:
So, now with that fix, I get [itex]2v_i^2(y-R)=ax^2 \\ 2v_i^2(y-R)=a(R^2 - y^2) \\ 2v_i^2 = -a(R+y) \\ v_i^2 = \frac{g}{2}(R+y)[/itex]
looks good! :smile:
(but on my recent performance, i could be missing something! :blushing: :rolleyes:)
tiny-tim said:
looks good! :smile:
Haha yeah, we've all been missing simple things..:rolleyes:
I don't see how this ties in with it not hitting the semi circle though.
because …
Bread18 said:
[itex]v_i^2 = \frac{g}{2}(R+y)[/itex]
gives you the y-coordinate where it hits the circle
for example, if v = 0, the ball drops straight down, and hits the circle at y = -R !
ok, now what happens to y as you increase v ? :wink:
(btw, the other solution, y = R for any value of v was eliminated from the equation when you divided it by (y - R) :wink:)
So I want y = 0?
in a moment, I'm going out for an hour or so
draw yourself some diagrams of a parabola touching and cutting a circle, and see what happens as the parabola changes shape :wink:
(also, think how many times can a parabola touch and cut a circle?)
Ok, thanks for your help, I think I'm going to go to bed now (2am here). Hopefully When I wake up it'll all become obvious...
  • · Replies 53 ·
  • · Replies 23 ·
