Projectile Motion Water hose Question
The discussion revolves around a projectile motion problem involving a water hose filling a cylindrical storage tank. The hose shoots water at a 45-degree angle from the same level as the base of the tank, which has a diameter D and height 2D, and is positioned 6D away from the tank.
  • Participants discuss the appropriate equations for projectile motion, questioning the validity of using certain equations given the height of the tank. There are attempts to clarify the conditions under which specific equations can be applied.
Some participants have offered guidance on the limitations of the equations being used, while others are exploring different scenarios regarding the trajectory of the water stream. There is an ongoing examination of assumptions related to the problem setup.
Participants note the importance of understanding the context of the equations, particularly regarding the height of the tank and the distance from which the hose is positioned. There is a mention of constraints related to air resistance being ignored.
jasonchiang97
A water hose is used to fill a large cylindrical storage tank of diameter D and height 2D . The hose shoots the water at 45 ∘ above the horizontal from the same level as the base of the tank and is a distance 6D away
Vx=Vt
D=vit+1/2at^2
I tried plugging in the values into the
equation and I end up with√6dG<V<√√7dG
You should not apply equations without understanding the context in which they are valid. The equation you tried does not allow you to use the height of the tank, so it cannot be appropriate. When is it appropriate?
Right, okay I think I'm only allowed to use the equation when the object is landing at the same level ground as it started off on.
Right. Or, more precisely, when d is the distance to a point where it is at the same level it started at.
What is the question? What are you trying to find?
jasonchiang97 said:
A water hose is used to fill a large cylindrical storage tank of diameter D and height 2D . The hose shoots the water at 45 ∘ above the horizontal from the same level as the base of the tank and is a distance 6D away.
For what range of launch speeds (v0) will the water enter the tank? Ignore air resistance, and express your answer in terms of D and g .
Vx=Vt
D=vit+1/2at^2
oops. Sorry I thought I posted that.
Okay, so what are the scenarios for the water stream that you need to investigate? That is, what are the significant characteristics of the trajectory in each case?
OK. From where is the hose 6D away? From the centre of the tank? Or from where the tank begins?
Clever student's strategy: Unless the problem states a condition explicitly, choose the simplest situation to work with and declare it as an assumption. Just make sure that it's really undefined and not subtly implied somehow in the problem statement.
You can't use dg = v^2(sin∆) here as this is equation gives us the maximum range of the projectile.
See post #3.
So what equation should you use here?
I used the 2D equations and plugged in t=Vx/Vcos45 into d=vtsin45+1/2at^2 and solved.
Thanks
Thanks
So you got the answer?
yep
20K
