Projectile Motion basketball shot
The discussion focuses on calculating the initial resultant velocity of a basketball shot and the maximum height reached by the ball. The player shoots from a distance of 15 meters at a 55-degree angle, with the hoop height set at 3 meters. Trigonometric principles are suggested for rearranging equations to find the initial velocity. Participants express gratitude for the guidance provided in solving the problem. Understanding projectile motion is essential for accurately determining these values in basketball scenarios.
kara1434
eek.
I need help.
A basketball player shoots a basketball into a hoop to score a "point". The height of the hoop is 3m. The shooter stands 15 m from the basket and shoots the ball at a 55 degree andle from the horizontal. Assume the height of player is 0.
Need to find:
1) The baslketball's initial resultant velocity.
2) The maximum height of the basketball.
I think you need to use trigonometry and rearrange the equation for the horizontal component (because you have been given it) to get the inital resultant velocity (u).
hope that gives you a start
that helped alot! thanks
  • · Replies 18 ·
10K
10K
