Calculating Projectile Velocity to Clear 11m Wall
The discussion focuses on calculating the projectile motion of a rocket fired at 75.0 m/s at an angle of 66.4° to determine how much it clears an 11.0 m wall located 20.0 m away. Participants clarify the horizontal and vertical components of motion, emphasizing that horizontal motion maintains constant speed while vertical motion is affected by gravity. The correct approach involves calculating the horizontal velocity (30.02 m/s) and using it to find the time to reach the wall, followed by determining the vertical displacement using the formula for projectile motion. Ultimately, the calculations lead to a successful understanding of the problem.
  • Understanding of projectile motion principles
  • Ability to perform trigonometric calculations (sine and cosine)
  • Familiarity with kinematic equations for motion
  • Basic knowledge of gravity's effect on vertical motion
  • Learn how to apply kinematic equations in projectile motion scenarios
  • Study the effects of angle on projectile trajectories
  • Explore the concept of air resistance in projectile motion
  • Investigate advanced projectile motion problems involving multiple forces
Students, educators, and physics enthusiasts interested in mastering projectile motion calculations and understanding the dynamics of objects in motion.
scw287
A rocket is fired at a speed of 75.0 m/s from ground level, at an angle of 66.4° above the horizontal. The rocket is fired toward an 11.0 m high wall, which is located 20.0 m away. The rocket attains its launch speed in a negligibly short period of time, after which its engines shut down and the rocket coasts. By how much does the rocket clear the top of the wall?
I'm really stuck on this question not positive on my work
-4.9 t^2 +75 t sin 66.4 +0
horizontal component 75*cos(66.4) and a vertical component (75*sin(66.4))
I don't know how you would find time
Consider the horizontal motion. You have the distance and velocity.
I know it relates to time...but I am not sure how to tie the two together
What's the simplest relationship between velocity, distance, and time?
What's the difference between vertical and horizontal motion for a projectile?
v=change x/change of time
the horizontal component doesn't have acceleration?
Exactly right on both. The horizontal component is constant speed motion: Distance = speed X time. What's the horizontal speed and distance traveled?
Horizontal speed:750m/s
Distance traveled:
Distance=speedXtime
29cos66.4=750m/sXtime<<?
The total velocity is only 75 m/s--find the x-component of that.
Distance traveled:
is given--no calculation needed.
oops i meant 75.0 m/s, would it be 29.0
That's close, but with a caculator you should be more accurate.
V_x = 75.0 m/s * cos(66.4 degrees) = ?
How does the 11.0 m wall come into play do i have to subtract it from 30.0262
Not yet, you've so far got the horizontal velocity (30.02). We're on to finding the time it takes to travel 20.0m (horizontally).
Then we can start on the vertical components.
so I would just multiply 30.02m/s*20m
V_y=75m/s*sin(66.4)
then I use the formula (V_y*t-9.80*t^2)/2
then subtract that answer from 11m right?<<<am I'm on the right track I just keep getting a very large numbers for answers
Not quite. Remember the relationship between velocity, time and distance?
Well i think i messed up on the time it should be .666 i think b/c of the formula v=change of x/change in time?
so if i calculated v_y right and t right my equation would be 68.727*.666+(-9.80m/s^2*(.666)^2)/(2)
YES I GOT IT THAT TIME! so i guess i have learned something today
  • · Replies 53 ·
  • · Replies 21 ·
