Solving Projectiles: Kinematics Equations & Variables for Grade 12 Physics 12 BC
  • Thread starter Thread starter link2110
    Projectiles
In projectile motion, the key to solving problems lies in separating the horizontal and vertical components of motion, as they are independent of each other. For the given problem involving a golf ball hit diagonally, the initial velocity must be broken down into horizontal (Vx) and vertical (Vy) components using trigonometry. The time to maximum height can be calculated using the vertical component and the acceleration due to gravity, which is -9.80 m/s². The equations of kinematics, such as V2 = V1 + at, can be applied to find maximum height and other variables. Understanding these principles allows for accurate calculations of projectile motion parameters.
link2110
Hi I am a grade 12 student in Physics 12 in BC, and I was wondering for projectiles, what equations you use, and what variables you use to solve. For example, in our notes our teacher gave us and example and completed it for us, but I don’t get why he used the equations he did. I do know that you use kinematics equations, and you have to change the initial velocity of the object into its 2 components Vy and Vx using component method, but other than that I don’t get why you use an equation and not another one.
Here is the problem, and any help at all would be appreciated.
A golf ball is hit diagonally (37o) off the top of a 15m cliff at 40m/s.
Find:
a) Time to max height
b) Max height achieved
c) Entire time in air
d) Range
e) Velocity at 1.0 seconds
f) Velocity at impact
Here is the picture that I drew to start.
http://img23.imageshack.us/img23/556/physicsquestion.th.png
Then I found the Vx and the Vy.
http://img3.imageshack.us/img3/1953/physicsquestion1.th.png
Now I'm stuck to find the first thing...because I don't know how to get it.
Help please?
The answers to the question are:
a) 2.46 sec
b) 44.6 m
c) 5.47 sec
d) 175 m
e) 35.0 m/s @ 24.1o above horizontal
f) (do not have b/c notes are incomplete)
The key to these problems is in the assumption that each independent dimension of motion is unaffected by the other. That is to say, if, parallel to the x-axis, the ball has no horizontal acceleration, then you can use kinematics equations assuming that the ball has no acceleration and get the correct horizontal component of the ball's velocity irrespective of what is going on in the y-direction. The same holds for the y-component analysis.
So if we look at question a) [time to max height], realize that the height of the ball has nothing to do with the horizontal velocity of the ball, and thus we need only know the y-component of the velocity and whether the ball is accelerating in that component. Use trigonometry to get vy and note that the acceleration in y is -g, where g is the scalar acceleration due to gravity at sea level. In the y-direction, the projectile is simply going up and down, just as if you were to throw it straight up with velocity vy without any horizontal component. You should already know the proper equation for this setup from your study of one-dimensional kinematics.
so I am assuming that's -9.80 m/s - accelleration due to gravity.
then i'd use an equation just like the ones in kinematics where the ball is thrown straight up (V2= V1 + at), and assume that at V2, the max height the velocity of the ball is 0m/s. the V1 is the inital accell of the ball, which is the Vy. Am i right?
Sounds good! :smile: You will also need an equation involving distance, as you need height.
how do you find the max height?
Use an equation relating distance to acceleration and time. Find the time it takes for the object to decelerate to 0 using the equation you gave before. When it reaches 0 velocity it has attained its maximum height and will start falling (negative velocity).
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 23 ·
