How Do You Calculate Projectile Motion and Vertical Displacement?
To calculate projectile motion and vertical displacement, the first problem involves determining the horizontal distance a baseball travels after being hit at a 30-degree angle with a horizontal velocity of 40 m/s. The time the ball is in the air must be calculated correctly to find this distance. For the second problem, when a bottle is thrown straight up at 15 m/s, the height after 2 seconds can be calculated using the equation y = v_o t - 0.5gt^2, ensuring the acceleration due to gravity is negative. The correct application of these equations is crucial for accurate results. Understanding the direction of motion and the effects of gravity is essential in solving these types of problems.
Coco12
A baseball player leads off the game and hits a long ball to right field. The ball leaves the bat at an
angle of 30.0o from the horizontal with a horizontal velocity of 40.0 m/s. How far will it travel in the air?
2) person throws bottle straight up in the air at velocity of 15m/s . How high is the bottle after 2 secs
Vy=Vyi +gt
Vy=Vyit +1/2gt^2
I found the time in total to be 4.08. However this is asking time IN the air. Isn't that different from finding Vxi and multiplying by time ? How do I find it?
2)can I use by y=15m/s* 2+1/2* 9.8m/s^2 * 2
Is that correct?
Vy=Vyi +gt
Vy=Vyit +1/2gt^2
Is that correct?
For (1), can you give details on how you found the time? Your value doesn't look quite right to me. I take it from the level of question that "how far it travels in the air" is referring to the horizontal distance traveled between leaving the bat and first hitting the ground.
For (2), you need to take into account the direction of motion versus acceleration. Is the acceleration due to gravity directed upwards or downwards. Also, don't forget to square the time on the acceleration term! Otherwise, you've chosen the right form of equation.
So for 2 I would be taking 15*2+ (.5* -9.8m/s2 * 2^2) right?
Right. Or symbolically:
##y = v_o t - \frac{1}{2}g t^2##
Likes 1 person
  • · Replies 21 ·
