Projector with the greatest projection angle
The discussion centers on identifying the projector with the widest projection angle, highlighting the limitations of brightness in traditional film projectors. Current technologies, such as TI micro-mirror systems, show promise in overcoming these limitations. IMAX theaters utilize multiple projectors to achieve a hemispherical projection, but advancements in LED technology could enable single units to project larger areas without excessive heat loss. The conversation emphasizes the potential of LED-based projectors to enhance brightness and efficiency compared to incandescent sources.
  • Understanding of projector optics and projection angles
  • Familiarity with TI micro-mirror technology
  • Knowledge of LED lighting technology and its applications in projection
  • Awareness of film stock limitations and heat management in projectors
  • Research the capabilities of TI micro-mirror technology in projection systems
  • Explore advancements in LED projection technology and its impact on brightness
  • Investigate the design and functionality of IMAX multi-projector systems
  • Study heat management solutions for projectors, including visible light filters
Optics engineers, projector manufacturers, cinema technology enthusiasts, and anyone involved in the development or optimization of projection systems.
SAZAR
A bit about optics. I was wondering what is the film (slide, or motion picture) projector with the widest projection angle. What are the current limitations?
Science news on Phys.org
The limitation is on the source brightness; as the projection field increases, the lamp must be brighter and brighter, which approaches damage thresholds of the film stock. Possibly the newer direct projection technologies (like the TI micro-mirror based technology) can overcome this. The problem is not really the optics: there are lots of fish-eye designs that cover close to 180 degrees field of view.
There are IMAX theaters that cover a hemisphere, but those use multiple projector system, AFAIK.
Hmm... But, if projectors were using LED light instead of incandescent source, it could solve the problem, right?
LED brightness does not come anywhere near close to arc sources.
Quote:
"There are IMAX theaters that cover a hemisphere, but those use multiple projector system, AFAIK. "
It would be nice to have one unit which projects upwards and covers even more than half of sphere (some 15m diameter or greater)...
Incandescent light bulbs create more useless wavelengths (infrared) than visible light (somewhere they say that 90% is wasted on heat) - maybe the heat problem in projectors could be solved with filters which pass only visible light to film?
I like those micromirrors projectors... LED technology...
Maybe it's not much of a problem to make even larger surface - based on LED semi-conductors technology, but spread on a greater surface - tightly packed -- that could create strong light...
On the other hand - simple white LEDs could be spread on wide rectangular surface, and then their light could be concentrated on a film with some lenses - right? Hmm, I wonder how large surface would be needed for cinemas?
