Proof by Induction: Prove Fn-1Fn+1 - Fn = (-1)^n
  • Thread starter Thread starter dirtybiscuit
    Induction Proof
6 replies · 2K views
dirtybiscuit
The fibonacci numbers are defined by F0 = 0 F1 = 1 and Fn = n-1 + Fn-2 for n >= 2.
Use induction the prove the following:
Fn-1Fn+1 - Fn = (-1)n
The attempt at a solution
Let P(n) = Fn-1Fn+1 - Fn2 = (-1)n where n>= 1
Show it holds for first natural number:
P(1) = F0 + F2 - F12 = -(1) = -1. So it is true
Now assume it works for some k and prove it works for k+1
This is where I'm really not sure what to do. I have tried putting
F(k+1)-1F(k+1)+1 - F(k+1)2 but it ultimately gets me no where.
Usually when I have done inductive proofs I start with some sequence of numbers 1,2,3,4...,n and show n+1 is there but this one seems slightly different and I'm not sure how to proceed.
Any help is appreciated.
dirtybiscuit said:
The fibonacci numbers are defined by F0 = 0 F1 = 1 and Fn = Fn-1 + Fn-2 for n >= 2.
F(k+1)-1F(k+1)+1 - F(k+1)2 but it ultimately gets me nowhere.
You want terms involving ##F_k##, ##F_{k+1}##, and ##F_{k-1}##, so use the defining relation to rewrite ##F_{k+2}##.
vela said:
You want terms involving FkF_k, Fk+1F_{k+1}, and Fk−1F_{k-1}, so use the defining relation to rewrite Fk+2F_{k+2}.
Thank you for your reply.
With that I get:
FkFk+2 - F2k+1
Fk(Fk+1 + Fk) - F2k+1
FkFk+1 + F2k - F2k+1
Fk+1(Fk - Fk+1) + F2k
I'm not really sure where to go from this point.
Just to verify that I am thinking of this the right way.
I am trying to find a spot that I can use the assumption made about k where (Fk-1Fk+1 - F2k) and link that to k+1 correct?
With that I get:
FkFk+2 - F2k+1
Yes, that's what you're trying to do. You need to play around with it a bit. The ##F_{k+1}^2## term isn't one you want around, right? What can you do with it?
Okay so this is what I got:
Fk+1(Fk - Fk-1) + F2k
Fk+1(Fk - Fk - Fk - 1) + F2k
-Fk+1Fk-1 + F2k
Multiply by -1 and get:
Fk+1Fk-1 - F2k = -(-1)k+1
So P(k) = -(-1)k+1
The part about the -1 on the right hand side threw me off at the end but I think it makes sense.
It seems unusual that this is proving k+1 though because it ends with P(k)
And again thank you for your help I have been looking at this problem for longer than I would care to admit.
I'm not sure what you did here. It looks like you introduced a term out of thin air.
I made a mistake when I was typing. It should have said Fk+1(Fk - Fk+1) + F2k
Then I used the defining relation on Fk+1 to get the next line.
