Proof: Everywhere Tangent to Curve?
The discussion centers on proving that curves defined by the function psi(x,y) are everywhere tangent to the vector field v(x,y). It is established that the gradient of psi, denoted as ∇ψ, is normal to the surfaces of constant psi, leading to the conclusion that v·∇ψ = 0. This implies that the vector field v is perpendicular to the gradient of psi, confirming that the curves are indeed tangent to v. The relationship between v and psi is further clarified by recognizing that if v is derived from the curl of psi, it reinforces the concept of psi as a stream function. Ultimately, the proof hinges on the orthogonality of v and ∇ψ, establishing the tangential relationship.
bakra904
Proof: Everywhere Tangent to Curve??
If the function v depends on x and y, v(x,y) and we know there exists some function psi(x,y) such that
vx = partial w.r.t (y) of psi
vy= -(partial w.r.t (x) of psi)
show that the curves psi(x,y) = constant, are everywhere tangent to v.
Usually you are supposed to show effort to get there, but I think this is a case where either you get it or you don't.
\nabla \psi is normal to surfaces of constant \psi and v\cdot \nabla \psi = 0. Fill in the rest.
Thanks a bunch! I'm a new poster and did not know about the effort rule...I had worked on it but did not post what I had worked on.
I was trying to use the fact that if v = \nabla \times \psi,
then that would imply that \psi is a stream function, which in cartesian co-ordinates would reduce to:
Vx = \frac{\partial\psi}{\partial y} and Vy = - \frac{\partial\psi}{\partial x}
which is basically what the problem had to begin with. Then, since I know that \psi (x,y) is a stream function, doesn't it have to be tangent to v by virtue of the fact that its a streamline?
Are you trying to curl a scalar field??
oh right...i overlooked that part. thanks!
so basically v. \nabla\psi = 0 which proves that v and \nabla\psi are perpendicular (since their dot product is 0) and so \psi must be tangent to v
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
