Proof of continuous. f(x+y)=f(x)+f(y)
  • Thread starter Thread starter Unassuming
    Continuous Proof
The discussion revolves around proving that a real-valued function f, satisfying the condition f(x+y)=f(x)+f(y) for all x,y in R, is continuous at every point in R if it is continuous at one point p. The proof begins by establishing continuity at p, leading to the conclusion that for any ε>0, there exists a δ>0 such that if |x-p|<δ, then |f(x)-f(p)|<ε. Participants clarify the manipulation of expressions involving f and discuss the implications of f(0)=0, which arises from the functional equation. Concerns are raised about the use of specific function properties, but the logic is affirmed as consistent with the properties of continuous functions. The conversation emphasizes the importance of understanding limits and continuity in the context of the given functional equation.
Unassuming
Let f be a real-valued function on R satisfying f(x+y)=f(x)+f(y) for all x,y in R.
If f is continuous at some p in R, prove that f is continuous at every point of R.
Proof: Suppose f(x) is continuous at p in R. Let p in R and e>0. Since f(x) is continuous at p we can say that for all e>0, there exists a d>0 such that if 0<|x-p|<d implies that |f(x)-f(p)|< e/2.
I know that |f(x)-f(y)| = |f(x)-f(p)+f(p)-f(y)| <= |f(x)-f(p)|+|f(y)-f(p)|.
I also know that |x-y|=|(x-y+p)-p| <= |x-p|+|y-p|.
Help: I am confused on how to show that f is cont. at every point in R. I appreciate any help little or big! Thank you
So if |x - y| < d, then |(x - y + p) + p| < d. Then...
Now use the fact that f(x + y) = f(x) + f(y).
Proof: Suppose f(x) is continuous at p in R. Since f(x) is continuous at p we can say that for all e>0, there exists a d>0 such that if 0<|x-p|<d implies that |f(x)-f(p)|< e.
Let y be a real number and fix 0<|x-y|<d.
Then |(x-y+p)-p|<d
So |f(x-y+p)-f(p)|<e.
or in other words, |f(x-y)+f(p)-f(p)|<e.
or, |f(x)-f(y)|<e.
I have a concern that I used f(x-y)=f(x)-f(y). Does this work because f(-y)= -f(y) ?
I also changed my e/2 into just e.
I also included a "let" before the manipulating.
Does this look better? I appreciate the help mutton.
You don't need to go back to the basic definition of limit. A function, f, is continuous at x= a if and only if:
f(a) is defined
\lim_{x\rightarrow a} f(x) is defined
\lim_{x\rightarrow a} f(x)= f(a)
Suppose f is continuous at x= a. Then \lim_{x\rightarrow a} f(x)= f(a)
Let h= x- a. Then x= a+ h and as x goes to a, h goes to 0:
\lim_{x\rightarrow a} f(x)=\lim_{h\rightarrow 0} f(a+ h)= \lim{h\rightarrow 0}f(a)+ f(h)
What does that tell you about f at x= 0?
(It is important to recognize that if f(x+ y)= f(x)+ f(y), then f(x)= f(x+ 0)= f(x)+ f(0) so f(0)= 0.)
Now let b be any other value and go the opposite way.
It works because f(x) = f(x - y + y) = f(x - y) + f(y).
But what you say is also true because f(-y) = f(0 - y) = f(0) - f(y) = -f(y), as HallsofIvy showed that f(0) = 0.
f(a) is defined
I was just wondering what you meant by "let b be any other value and go the opposite way."
do you mean let h=x+b?
Thanks.
Actually, h= x- b. If b is any real number, then then \lim_{x\to b} f(x)= \lim_{h\to 0}f(b+ x)= \lim_{h\to 0}f(b)+ \lim_{h\to 0}f(h)= f(b)+ \lim_{h\to 0}f(h)= f(b).
Thanks!
What is the exact difference between the h = x-a and h =x-b step? What is the point of doing both steps?
  • · Replies 18 ·
  • · Replies 20 ·
