Deriving and Verifying the Relativity Formula for Electron Speed
The discussion focuses on deriving and verifying the relativistic speed formula for an electron influenced by an electric field. The proposed speed function is v(t) = At/√(1 + (At/c)²), where A is defined as qE/m. Participants are tasked with confirming that this function satisfies the differential equation dv/dt = (qE/m)(1 - v²/c²)^{-3/2}. The relationship between force and velocity is emphasized, noting their parallel alignment. The conversation aims to deepen understanding of relativistic effects on electron motion under electric fields.
Samkiwi
I'm having trouble finding the proof of the relativistic acceleration formula starting from the velocity formula, I've been working on it for a long time but I can't solve this question. :)
electromagnetism and relativity
It is an electron initially pushed by the action of the electric field. The vectors of force and velocity are parallel to each other.
Here's the questionA possible expression of speed as a function of time is the following:
$$v(t) = \frac{At}{\sqrt{1 + (\frac{At}{c})^2}}$$where is it $$A =\frac{qE}{m}$$
Taking into account that [2] can be written in the equivalent form.
$$\frac{dv}{dt}=\frac{qE}{m}(1-\frac{v^{2}}{c^{2}})^{-\frac{3}{2}}[3]$$
verify by deriving and substituting that the function v (t) defined by [2] satisfies [3]
Try this: $$v(t) = \frac{At}{\sqrt{1 + (\frac{At}{c})^2}}$$
thanks:bow:
  • · Replies 27 ·
