How is the Relativity Formula Proven for an Electron in an Electric Field?
The discussion revolves around proving the relativity formula for an electron in an electric field, specifically examining the speed function v(t) and its derivative. Participants engage in deriving expressions for acceleration and velocity, emphasizing the need to apply the product rule correctly. There is a focus on ensuring the final forms of the equations align with the expected results, particularly in terms of how they relate to relativistic effects as velocity approaches the speed of light. The conversation highlights the importance of algebraic manipulation and understanding the underlying physics principles. Ultimately, the participants arrive at a satisfactory conclusion regarding the relationship between the derived expressions.
Samkiwi
I'm having trouble finding the proof of the relativistic acceleration formula starting from the velocity formula, I've been working on it for a long time but I can't solve this question. :)
electromagnetism and relativity
It is an electron initially pushed by the action of the electric field. The vectors of force and velocity are parallel to each other.
Here's the questionA possible expression of speed as a function of time is the following:
$$v(t) = \frac{At}{\sqrt{1 + (\frac{At}{c})^2}}$$where is it $$A =\frac{qE}{m}$$
Taking into account that [2] can be written in the equivalent form.
$$\frac{dv}{dt}=\frac{qE}{m}(1-\frac{v^{2}}{c^{2}})^{-\frac{3}{2}}[3]$$
verify by deriving and substituting that the function v (t) defined by [2] satisfies [3]
What do you get when you differentiate ##v(t)##?
i get this
$$\frac{dv}{dt}=(1+(\frac{At}{c})^{2})^{-\frac{3}{2}}(\frac{At}{c})^2$$
Samkiwi said:
i get this
You need to use the product rule. I'm not sure how you got that. As a first step you should have something like:
$$\frac{dv}{dt} = \frac{A}{\sqrt{1 + (\frac{At}{c})^2}} + \dots$$
Likes Samkiwi
and i know that
$$A=\frac{qE}{m}$$
and
$$At=\frac{qE}{m}t$$
$$F=maϒ^3$$
then
$$A=aϒ^3$$
yes yes I was wrong I considered t a constant, when in reality it is a variable
Likes PeroK
I obtain this
$$\frac{dv}{dt}=\frac{Ac^{3}}{(c^{2}+A^{2}t^{2})\sqrt{c^{2}+A^{2}t^{2}}}$$
and now?o_O:rolleyes:
Samkiwi said:
I obtain this
That's correct, although you've changed the format of the term ##1 + (\frac{At}{c})^2## to ##c^2 + (At)^2##.
You can simplify what you have to the correct answer. But, it's not good technique to change things that start in the format required for the final answer to something else that looks different.
Likes Samkiwi
okay, now I try, anyway thank you very much yes it was very useful I don't know how to thank you
You can simplify what you have to the correct answer. But, it's not good technique to change things that start in the format required for the final answer to something else that looks different. :bow:
I see now there is a further step needed. What you should get, when you simplify that expresson is:
$$\frac{dv}{dt} = A(1 + (\frac{At}{c})^2)^{-\frac 3 2 }$$
And, what you are aiming for is: $$\frac{dv}{dt} = A(1 - (\frac{v}{c})^2)^{\frac 3 2 }$$
That means that you to show: $$\frac{1}{1 + (\frac{At}{c})^2} = 1 - (\frac{v}{c})^2$$
Likes Samkiwi
I didn't understand how I should demonstrate the last step
It's a relatrively simple piece of algebra. Just calculate, using the expression you have for ##v##, the quantity: $$1 - \frac{v^2}{c^2}$$
Likes Samkiwi
I may sound silly, but would you explain each step please, sorry I'm nagging
You have to make an effort yourself. The first step is easy, so I'll do that: $$v^2 = \frac{(At)^2}{1 + (\frac{At}{c})^2}$$
Likes Samkiwi
and after?
Samkiwi said:
and after?
That's up to you.
PeroK said:
That's up to you.
I'm not understanding anything anymore
differentiating I found this
$$\frac{dv}{dt}=A\frac{c^{6}}{(\sqrt{c^{2}+v^{2}})^{3}}$$
or this
$$\frac{dv}{dt}=Ac^{3}(1+\frac{v^{2}}{c^{2}})^{-\frac{3}{2}}$$
If $$v^2 = \frac{(At)^2}{1 + (\frac{At}{c})^2}$$ then what is $$1 - \frac{v^2}{c^2}$$?
$$\frac{c^{2}}{c^{2}+A^{2}t^{2}}$$
and now?
That's it, isn't it? Apart from changing the format of the expresson.
Likes Samkiwi
no, the form of the expression asking the question is this
$$\frac{dv}{dt}=\frac{qE}{m}(1-\frac{v^{2}}{c^{2}})^{-\frac{3}{2}}$$
See post #10. Note that ##A = \frac{qE}{m}##.
Likes Samkiwi
You should check this, as it should be $$\frac{dv}{dt}=\frac{qE}{m}(1-\frac{v^{2}}{c^{2}})^{\frac{3}{2}}$$
PS you can see that it must be this, as we need ##\frac{dv}{dt} \rightarrow 0## as ##v \rightarrow c##.
Likes Samkiwi
PeroK said:
$$You should check this, as it should be $$\frac{dv}{dt}=\frac{qE}{m}(1-\frac{v^{2}}{c^{2}})^{\frac{3}{2}}$$
I was able to find this formula
$$\frac{dv}{dt}=A(1+\frac{v^{2}}{c^{2}})^{-\frac{3}{2}}$$
the only problem is this part
$$(1+\frac{v^{2}}{c^{2}})^{-\frac{3}{2}}$$
I tried what you said. but I don't solve anything like that.
i should make sure that.
$$(1+\frac{v^{2}}{c^{2}})^{-\frac{3}{2}}=(1-\frac{v^{2}}{c^{2}})^{\frac{3}{2}}$$
but how do I prove it?
if I substitute v for the initial formula, I get
$$\frac{\sqrt{(c^{2}+v^{2})^{3}}}{\sqrt{(c^{2}+2v^{2})^{3}}}$$
That can't be right. Just take the limit as ##v \rightarrow c##.
Instead, we got as far as this:
You need to pick up from there.
Likes Samkiwi
Instead, we got as far as this:You need to pick up from there.
ok he succeeded, thanks a lot
  • · Replies 19 ·
